Question about Whirlpool Duet GHW9150P Front Load Washer
The rubber ring/seal has been punctured
The rubber ring/seal was punctured while attempted to unclog drain. Can the ring be patched or replaced? And generally how expensive to replce the rubber piece?
Deb Marshall
  • Whirlpool Master
  • 2,651 Answers
Heardof people repairing with limited succes with bicycle tire repair kits, the true solution would be to replace theboot, can be a abit of a pain in the but to get on but with time and some patiens it cann be done aprts problay 75-90 bucks
Posted on Mar 07, 2009
Clogged sunroof drain
there are 2 drain ports about the diameter of a pencil. these drains are connected to a rubber hose that runs all the way down to the sub frame. in the past I have unclogged them with compressed air, or water and a straw using good ol lung power. also where water drains from under vehicle there are rubber nipples you can run a wire through to help unclog. you do not need new sunroof those shops especially dealerships are trying to rip you off. sunroofs are designed to let water pass by seal to drains. the reason for this is because its to hard to keep a complete and true seal around a overhead window, but when the drains become clogged you experience what you and myself are dealing with, my own 2003 Yukon denali does the same exact thing, I just haven't had time to get to it yet. I have fixed plenty in the past, and all makes drain in almost the same way. as far as your headlight goes, a little silicone around edge of lens meeting place you will see old sealant from factory. hope this helps helps thanx
Jan 21, 2014 | Ford Cars & Trucks
Fiat punto radiator coolant leaking
could be coolant pipe or radiator its shelf has been punctured, you'll need to locate the source if its a the radiator then your aswell to replace the radiator. if its one of the pipes the you may be able to patch the puncture with solution or rubber repair kit
Mar 29, 2013 | Fiat Punto Cars & Trucks
Front door rubber seal
Fairly easy to do. It is held on with 2 wire rings, one on the outside edge of the seal when you open the door and when that is removed there is another one holding it to the outer drum. Removal of the lid may also help with removal of the inner ring. When refitting you press the lip of the seal over the outer drum edge and fit the retaining ring back and then do the same on the front where the door meets the seal. Just make sure the small drain holes in the seal are located at the bottom, best to look at the old one to see how it's fitted before you remove it.
Dec 27, 2012 | Electrolux Washing Machines
How do I fix a puncture in my sleeping pad?
The best way to fix a puncture is with gorilla glue and any sort of water proof material. Just make sure the patch is completely sealed around the puncture
Jul 09, 2012 | Camping, Backpacking & Hiking
Hi, can u show me how to clean my washer to get rid of that moldy smell. there's also mold around the rubber ring around the opening and it feels slimy. Can u please help
First you should reach deep into the front door seal and run your fingers around. There is probably slime in there. You will need to thoroughly clean this with a bleach water mix about 50-50. You might need to pull the seal almost inside out to get in there good. If after scrubbing you still have black in the rubber the mold will come right back, in that case you will need to replace the seal. They are not to hard to replace but a little tricky. Here is a link that should help if you need to replace the seal or if the wire ring pops off when cleaning. Now if all cleans up well or you replaced it be sure to wipe out the seal after each use (deep in there) and /or leave the door open.
If the seal is clean and no mold present and it still smells then you likely have a clogged drain pump filter or pump. Here is a link that should help cleaning a drain pump or try this one for cleaning a ge drain pump filter and this one for cleaning/replacing a Kenmore drain pump
Oct 07, 2010 | Maytag Neptune MAH9500A Front Load Washer
Leaking water when using my k cup
Long story short, it will leak from under the screw cap (rarely) and from the rubber ring around the puncture pin. The grounds clog the metal filter and creates pressure that escapes from under that rubber ring. I cut a thin styrofoam plate to fit under the screw cap. It's really snug for the first few times, then it will loosen up. Second is to tighten the seal between the top of the 'my cup' and that rubber seal. I used 2 styrofoam rings that sit between the 'my cup' and the hard plastic it sits on when you fit it in the hole. It bring the cup like 1/8 inch higher to the pin and increases that seal. I made many cups after that and it has never leaked. I'm looking for a good rubber ring to fit around the 'my cup' to replace the rings for the seat.
Apr 10, 2010 | Keurig 5048 My K-Cup Reuseable Coffee...
Radiator drain plug wont seal back up on my 05 dodge ram cummins
I have a 2004 Dodge Ram 2500 and to fix this problem I removed the drain plug being careful not to damage the plastic housing. I drilled through the center of the drain plug so that I would not have to use force to get it out and crack the plastic housing. After you get it out you will see that there is a rubber washer that is used to seal the drain. NAPA sells a drain plug that will work to replace the stock plug. The part #605-1278 comes on a card that says for Ford/GM. but it worked perfectly for me.
Jun 22, 2009 | 2005 Dodge Ram 2500 Truck
Final Spin Cycle Not Working
I unclogged the pump, it was really easy, and it fixed my problem (I have no mechanical know how)! let me explain how I did it!  I have the Frigidaire Front loader for two years, it was acting funny, wouldn't spin, wouldn't drain. My solution was quick and simple, per a solution already mentioned on this site.  In short, The rubber drain was clogged.  There were two cotton breast pads, that must have been in there for months.  Recently my washing machine would not drain, and therefore wouldn't even think about spinning fast.  To unclog, first take off the front bottom panel.  (There are two tight screws on the front bottom, next to the floor, I had to use a powerdrill to remove them, and tilt the machine against the wall to get to them).  Next, there was a black rubber accordian on the front right, where the water drains.  (remeber to unplug your washing machine, to avoid any shock or such!)  I simply unscrewed the big metal ring, (I think it's called a gasket). After unscrewing the metal ring, I could easily pull the rubber accordian down 2 inches, stick my hand in it, and pull out debris.  I pulled out debris for about 5 minutes, and was so excited because I knew my washer would work great again.  I simply put the rubber accordian part back on the lip, screwed the ring piece pretty tight. I used a towel to absorb a small amount of water, that got inside the washing machine.  Now, it is spinning a million miles per hour again.  I will put the rectangular bottom front panel back on in a few days, I just want to double check, there is no leak, which there is no reason to suspect, as removing and putting the metal ring back on was easy!.
Dec 10, 2008 | Frigidaire GLTF2940ES Front Load Washer
Leaking door due to the wire ring that holds rubber seal
Bosch Nexxt 500 WFMC3301 Front Load Washer how
to get the metal ring back on.
This video will show you how to change a door seal on this Bosch front loader washing machine and also how to replace the metal rings.
we have all bosch repairs in our channel.
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 06, 2008 | Bosch Nexxt 500 WFMC3301 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
265 people viewed this question
Dan Webster
Dan Webster
Sal De
