Question about Whirlpool Duet GHW9150P Front Load Washer
Heating element off a dryer
How do you test a heating elent to see if its bad
Check the element from end to end for continuity and check to ground from both ends for the same you should have cont. through the element but not to ground
Posted on Mar 06, 2009
Connect a tester to both wires on the bottom of element ,if good it should have a reading.if using a test light ,power should be on.if checking for continuity,power must be off.
DRYER NOT HEATING. Heat Element test good. No visible breaks. Tested the Thermal fuse it was bad so we replaced it. The dryer worked about 5 minutes. So we tested everything again and the Thermal Fuse and...
Somehow you are not getting enough air through the dryer to maintain a temperature below the thermal high temp cutout temp. or there is a control problem for the heating element so it may stay on the 5 minutes but like an oven the thermostat turns the element on and off. I hope you understand. There may be a relay that turns the element on and off, but the contacts have "frozen" or welded themselves together. If so that's your problem. Or there is another device with a similar problem. Unplug, trace the 220vac wires to controls and the heating element. Double check wiring. the Safety devices may be 110vac rated and 220vac is going through so won't hold the power flow. Hope this helps.
Mar 12, 2015 | Samsung DV209AEW Front Load Electric Dryer
Hotpoint wd420 shows error code f13 after replacing heater element for dryer.
Change electronic board it is what will cause this problem if you checked all ducts an fan and still heats board is bad
Oct 28, 2014 | Hotpoint Ariston Aquarius WD420 Front Load...
Washer heating elent doesnot come on
I would use a voltmeter and test the power to the element. If there is power than the element is probably bad.
Jun 05, 2012 | Asko W620
I have a Maytag Neptune Dryer that won't heat. we replaced the thermistor and the control board. What else could it be?
First unplug dryer and test your heating element for continuity with a multimeter if it has more than about 30ohms it is bad.Next check for 220v-240v at the heating element with the dryer running (This is not a test for an amateur. If you are not familiar with electricity I would recommend calling a service tech. If you have 220v-240v there and no heat the heating element is most likely bad. If not then trace the wires back to find the open circuit could be a thermostat or the thermal fuse or just a loose wire/bad connection.
Oct 28, 2010 | Maytag MDE9700AYW Neptune 174 Electric...
My he4T dryer is not heating at all. It is only cold air. What could this be so I know what part to order?
Hello there
If your dryer won't heat up, it's possible that it is not being supplied with the proper voltage. Here are three ways to make sure power is getting to your dryer: First, make sure your dryer is plugged in. Next, check the circuit breaker panel to make sure all the circuit breakers are in the correct positions. Finally, check to make sure no fuses in your fuse panel are blown. Any of these could explain why power is not getting to your dryer.
dryer_heating-element.jpg Heating Element
It is possible that your dryer isn't heating because its heating element is defective. Heating elements are irrepairable. If yours has ceased to function properly, you will have to replace it. Open your dryer's cabinet and locate the heating element so that you can test it.
dryer_thermal-fuse.jpg Thermal Fuse
Another possible cause for a dryer not heating up could be attributed to a faulty thermal fuse. Once a dryer's thermal fuse has blown, it is no longer of any use. If your dryer's fuse is blown, you will have to replace it. Open up your dryer's cabinet and locate its thermal fuse so that you can test it.
dryer_thermostat.jpg Thermostat
If any of your dryer's thermostats have become defective, they could be the reason that your dryer is not heating. Open up your dryer's cabinet and test each of your dryer's thermostats. If any are faulty, replace them.
dryer_timer.jpg Timer motor
A defective timer motor could also cause your dryer to not heat up. Test your dryer's timer motor. If it is no longer functioning as it should, replace either the entire motor assembly, or just its motor.
function isValidEmail() { var emailAdd; emailAdd = document.all.infobar_EmailAdd.value; if(emailAdd == "" || emailAdd.indexOf("@")
Feb 01, 2010 | Kenmore HE4t 3.8 Cu. Ft. King Size...
Dryer will not heat up, why?
Hello there
There are several reasons why a dryer will not heat up
i will do my best to explain them and i will add some links that you can use to help you out ok ?
If your dryer won't heat up, it's possible that it is not beingsupplied with the proper voltage. Here are three ways to make surepower is getting to your dryer: First, make sure your dryer is pluggedin. Next, check the circuit breaker panel to make sure all the circuitbreakers are in the correct positions. Finally, check to make sure nofuses in your fuse panel are blown. Any of these could explain whypower is not getting to your dryer.
Heating Element
It is possible that your dryer isn't heating because its heatingelement is defective. Heating elements are irreparable. If yours hasceased to function properly, you will have to replace it. Open yourdryer's cabinet and locate the heating element so that you can test it.
Thermal Fuse
Another possible cause for a dryer not heating up could be attributedto a faulty thermal fuse. Once a dryer's thermal fuse has blown, it isno longer of any use. If your dryer's fuse is blown, you will have toreplace it. Open up your dryer's cabinet and locate its thermal fuse sothat you can test it.
Thermostat
If any of your dryer's thermostats have become defective, they could bethe reason that your dryer is not heating. Open up your dryer's cabinetand test each of your dryer's thermostats. If any are faulty, replacethem.
Timer motor
A defective timer motor could also cause your dryer to not heat up.Test your dryer's timer motor. If it is no longer functioning as itshould, replace either the entire motor assembly, or just its motor.
Dec 30, 2009 | Kenmore Elite 45986 Front Load Washer
Does not heat- three of the temp sensors read 0 ohms, one is at 7.4 K ohms. Can it be the cause
Hello there
Here is a list of item for you to check Hope this is very helpful for you
Best regards Richard
My dryer will not heat up. Investigate these five areas if your dryer is not heating up:
Proper Voltage
Dec 15, 2009 | Whirlpool LTE6234D Top Load Stacked...
How do I replace the dryer element on my hotpoint auarius wd640 front load all-in-one
Before you replace dryer element, how do you now it is bad and what tells you it is the element and not 3 or 4 other items that could stop the element from heating? If oyu tested the element directly (and this of course is nearly the only way to know if it is bad) then you obviously has access to it and should see what is involved in removing it. So, I believe you do not actually know if the element is bad. You need to search and test all the controlling items that allow the element to heat before condemning it. I believe you need a skilled service person. Goodluck, macgivor
Nov 09, 2009 | Hotpoint Aquarius WD640 Front Load...
MY SPACEMAKER STILL DOESNT WORK AFTER I TRIED THE BREAKER
hell there:
did you replace the cored itself if not sounds like the cored is bad try that and plz let me know i will help you out on more stuff. you can get cored at any hardware store take the old one with you ok ty
Aug 17, 2009 | GE WSM2480DWW Unitized Spacemaker Washer...
Dryer tumbles won't heat
The problem could be related to one of the following; Not enough power from the house, a bad or broken heating element, a bad thermal fuse, or a brake in the wiring.
Solution
Check the house voltage for 220-240
Do a continuity test on the heating element.
Do OHM reading on thermal fuse.
Check wiring to heating element.
Aug 18, 2008 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
Dan Webster
Dan Webster
Richard Roth
Richard Roth
Mike Cairns
Mike Cairns
