Question about Yamata FY900 Mechanical Sewing Machine
Sewing machine-yamata-900 how to thread bobbin & machine to sew.
    Scholar:
  • 53 Answers
Http://pcmonkey.co.uk/jsm-download.com/manuals/English%20Maunals/pf2100%20english.pdf
found this in another post....link is to a downloadable users manual. Hope this helps!
~enov8
Posted on Mar 06, 2009
2 Suggested Answers
SOURCE: Yamata FY7568 Machine not sewing
Make sure the correct needle is installed on the machine. Domestic needles will have one flat and one rounded side on the shaft. Make sure the flat side of the needle is on the back and the groove on the needle also being to the back.
You might also want to make sure the tip of the needle is not broken.
Other than that, your machine could be out of timing.
Posted on Jul 23, 2008
The thread keep bursting as soon as i start to sew although machine is thread properly
Check your thread tension isn't too tight, try on a piece of similar fabric that you are going to use, try sewing a line of stitches, if the thread snaps, change your tension number, then sew another line with your different tension number, try this until you can stitch without the thread snapping, it could be that your bobbin tension is too tight. Can you check your machine manual, it could even be the needle or the thread that's wrong for your fabric. But I would say, check your tension.
Hope this helps.
Apr 02, 2014 | Yamata FY811 Mechanical Sewing Machine
Thread keeps breaking
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Jan 08, 2013 | Yamata Sewing Machines
THREAD COLLECTS UNDER MY YAMATA FY 760
try changing the needle
rethread the machine top & bobbin
clean under the needle plate & in the bobbin area for loose threads or lint
check to make sure the bobbin & bobbin case is not damaged
May 17, 2012 | Yamata Sewing Machines
I bought a yamata fy-900 from a thrift store. used it for a couple of days, it worked fine untill i tryed to sew a pair of jean pants and the needle got stuck and it hasent worked right sence it does not...
You have probably knocked out the timing on the machine. Most household machines, inexpensive machines especially will not sew denim without a fair amount of coaxing. Check the threading and do try on lighter fabrics first. to see if its just the denim.
Derek
Jan 17, 2011 | Yamata FY900 Mechanical Sewing Machine
I was using a Singer 9018 sewing machine, I rethreaded the bobbin, loaded it up and threaded the machine fine, but when I power up and start trying to sew, I can hear the machine motor going, but the...
Did you remember to tip the clutch on the end to being flat when you were done with the bobbin winding?
The disk tips to disengage the works while winding bobbins.
Dec 30, 2009 | Yamata FY101-1A
Bernina 1630 Thread works fine then goes in revese for a couple of stitches and then back to normal. Bobbin thread loose.
sounds like ur bobbin needs to be tighten, when loose the bobbon does not stop and you get more thred then needed hope this helps... Velz...
Jul 18, 2009 | Yamata FY700 Mechanical Sewing Machine
Don't have manuel with instructions on how to thread a bobbin & thread machine. need diagram on how to thread.
http://pcmonkey.co.uk/jsm-download.com/manuals/English%20Maunals/pf2100%20english.pdf
found this in one of our other post.. hope it helps...
Mar 06, 2009 | Yamata FY900 Mechanical Sewing Machine
Jun 19, 2008 | Sewing Machines
Bobbin case
Make sure there is no fabric or thread on the bobbin case shaft. Needle has to be in up position.
Feb 19, 2008 | Yamata FY811 Mechanical Sewing Machine
Yamata FY900 Mechanical Sewing Machine Logo
375 people viewed this question
Top Yamata Sewing Machines Experts
isaac johny
isaac johny
Michael Kovalik III
Michael Kovalik III
Cleverer2
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
