Question about Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe
Iomega mini max external HD slowing things down
I do video editing on my Mac Mini using my external iomega mini max and it worked fine when i first got it but it has been very sluggish as of late when i edit. when it slows down, it freezes for a second, then it freezes everything else up and i have to turn off my computer and turn it back on. when the hard drive is unplugged, everything works fine so i know it must be the HD. what can i do?
The hd external iomega 500 gb minimax have a litle noice and don't work dont conect whit my computer.
Posted on May 02, 2009
I have a sony handy cam DCR - DVD105, I want to know all the ways of being able to connect it to a laptop and extract the files to use in other softwares, like Window's Movie Maker, or Power Direct 09.
How to load Mini DVD to Mac
  • Though Mini DVD can not be played back in Mac slot loading player, we have other ways to load Mini DVD to Mac.
  • Method 1 If Mini DVD camcorder has FireWire or USB; just connect the Mini DVD camcorder to Mac using FireWire, or USB to load Mini DVD to Mac.
  • Method 2 If Mini DVD camcorder has not FireWire or USB; just shop for external mini-DVD drive that uses either a USB or Firewire connector cable, and then connect the external mini-DVD drive to your Mac and install any extra software that came with it. Insert the mini-DVD into the external drive, and then access the files on the mini-DVD as you normally would to load Mini DVD to Mac.
  • Method 3 If Mini DVD camcorder has not FireWire or USB; buy an adapter that converts a mini-DVD to a normal DVD by adding on a circular plastic piece that emulates the full size of a regular DVD. Attach the adapter to the mini-DVD and load it into the Mac's DVD drive to access the files. (Check the specifications of the adapter before purchasing, as several on the market do not work in vertical-loading drives like those found on the MacBook Pro.)
  • Method 4 If Mini DVD camcorder has not FireWire or USB and you don't want to buy a separate external drive or full-size adapter either, but you do have access to a PC, you can transfer the files on the mini-DVD onto the PC, then put them onto a USB flash drive, which will work on your Mac.
more detailed at http://www.bigasoft.com/articles/easy-solution-to-import-midi-dvd-into-imovie.html
Apr 21, 2011 | Sony Handycam DCR-DVD105 DVD Camcorder
Is it possible to boot from an Iomega eGo Blackbelt Mac Edition Portable HD and also use it to clone an existing drive? I want to upgrade an existing 160GB Internal HDD in a Macbook Pro 17" to a...
It's possible to clone to this drive, but over the USB interface, it will be very slow. Firewire would be faster. It's also possible to boot from it, but again, it will be slower than an internal. What you've described, however, IS possible.
Feb 28, 2011 | Iomega eGo BlackBelt Portable Mac Edition...
My mini max 500gb has just stopped working. i cannot hear the fan at all and all my other daisy chained mini max hard drives still work and register on my desktop
Your Imega external enclosure has malfunctioned. If you can, you need to take the enclosure apart and take the harddrive out and test it with a computer desktop that has sata connectable, if your computer is able to read, then your iomega harddrive enclose suffer malfuction, if the computer isn't able to read the harddrive through the sata connection, then your harddrive is bad.
Jan 30, 2011 | Iomega MiniMax (33464) 250 GB Hard Drive
Iomega external HD not recognized?
try to access the drive forme a live cd, like puppy linux, it should be regonised in the format tool called g parted.
if your are not familior with linux, you will need winpe mini cd, **** you need to be carefull about loosing data in the drive, coz you might want to format it and clean all the bad sectors and clusters before using it.
May 09, 2010 | Computers & Internet
Recording onto a mini dv tape from Mac computer Via firewire
I have successfully recorded to a mini Dv tape from my computer however I connected my PC to the VX2100 using the RCA inputs. I have an adapter that I purchased from best buy that provides the RCA input/output. If your able to connect that make sure to...
1. Turn you VX2100 to Play/Edit mode (not camera mode)
2. Insure the program on your mac has an external output otherwise you won't be able to record.
3. See if your video editing software (if your using one) has an option for record to tape or to camera. I use Vegas Studio and it has an option for that.
Hope this helps. Good Luck!
Jun 23, 2009 | Sony Handycam DCR-VX2100 Mini DV Digital...
Problems adding files onto the hardrive
This sounds as though the Iomega has got locked somehow.
Do a get info on its desktop icon and have a look at the lock checkbox. Also look at the write permissions while you are there.
May 10, 2009 | Iomega (33654) Limited Edition 500 GB USB...
Maxtor OneTouch 4 Mini 250GB External Drive Does not show up on my computer
Are you connecting Drive via a USB hub or direct into two separate USB sockets on PC?
May 05, 2008 | Maxtor OneTouch 4 Mini 160GB External USB...
Open Questions:
See all Iomega MiniMax Desktop - Hard drive - 500 GB - Questions
Iomega MiniMax Desktop - Hard drive - 500 GB - external - Hi-Speed USB - 7200 rpm - buffe Logo
301 people viewed this question
Top Iomega Computers & Internet Experts
Arora Singh
Arora Singh
Starnley Johnwells
Starnley Johnwells
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
