Question about ZT Group CISNET A7050 PC Desktop
How to get to cmos
Having ups problems
  • grayfoxmp Mar 10, 2009
    thanks again
  • Carlos Soto
    Carlos Soto May 11, 2010
    Setup can usually be reached by F1, F2, F10 or Delete. But can you clarify as to what you are trying to do with the UPS?
  • 916 Answers
When the computer is starting watch the bottom of the screen. There should be something that says <press this button> to enter the setup or bios when that comes up press that button.
Posted on Mar 06, 2009
Chek smos errer
You have described you problem incorrectly. I guess the error mess is "CMOS Cheksome error. " I guess.
This messenger comes due to following situations.
1. CMOS battery low. Check for the CMOS battery (most commonly CR2032) power if it is low this message can appear.
2. BIOS has been reset on purpose or by a fault. Set time date and other settings.
3. Motherboard problem. Rarely motherboard will have this issue with CMOS or with the battery powerline making it to lose CMOS Setteings. Change the motherboard or live with it.
Regards
Apr 01, 2014 | Computers & Internet
Reset cmos
Removing the CMOS battery for 15 mins will reset the CMOS.
The CMOS failure most likely is caused by a flay CMOS battery. replace the CMOS battery will fix this problem.
Oct 24, 2012 | IBM ThinkPad T41 Notebook
Start-up and shut down problems, When starting up it says, press f1 to continue, f2 to run set-up.... F1 works but I am getting tired of doing this. Now when the computer starts, it stops at...
Hi names Rui,
For your problem the computer may display a prompt to press F1/F2 or any other key to enter setup each time the computer boots as a reminder on how to enter CMOS. However, if the computer asks to press F1/F2 (or another key) to enter setup and does not continue, this may be caused by any of the below reasons.
  1. New hardware has been recently installed.
  2. Error or confliction with settings in CMOS.
  3. CMOS battery is bad or failing.
Solution:
If new hardware has been recently installed into the computer, it is likely that you are receiving the prompt "Press F1 or F2 to enter setup" because CMOS needs to verify that the new detected hardware is properly being setup in CMOS. Enter CMOS setup and save the settings and exit. If you continue to get errors continue to the next step.
If no new hardware has been added or you continue to get this prompt verify no error or conflictions exist in CMOS. Press the key to enter setup and verify that all settings are correct.
If your time and date are not set correctly, your battery is more than likely bad. Try setting the correct time and date, save the settings and then reboot. If after turning off the computer the time and date get reset again replace the battery.
If the time and date are correct and everything else appears to be correct try resetting the CMOS values to the defaults.
If you continue to receive the prompt to enter setup each time the computer boots up and you have attempted to follow the above suggestions, your CMOS battery is bad. We recommended that the CMOS battery be replaced.
hope this will help you.
Jul 20, 2011 | Dell Dimension 2400 PC Desktop
Cmos setting wrong on start up
are you able to enter the cmos to make changes?
depending on the brand, you may hit one of several keys to access the cmos. del, f2, f10, f11, f12.
then try resteseing the cmos to defaults.
Jan 06, 2010 | Intel Computers & Internet
No post screen, cant access cmos settings. but windows starts as usual just a blank screen til then?
Its possible that your cmos settings were changed prior to this problem so as not to display cmos settings options at boot up. Have you tried resetting your cmos settings to fix the problem? You can do this by a jumper which is usually found on the mother board named "clr cmos" (clear cmos).
Let me know if this is of help or not.
Regards,
Graemevm
Apr 25, 2009 | Dell Dimension 2350 PC Desktop
Acer Travel mate 517TE C MOS low battery warning msf at Power up
If you clear the cmos you are just loading the defalt bios settings but not solving the problem.
In this case you dont have to clear the cmos but instead replace the cmos battery.
Dec 12, 2008 | Acer TravelMate 517TE Notebook
Pvm 800 moterboard bios
some motherboards will switch on and run after removing the cmos battery also but in some motherboards it is not possible it depends on the manufacture design ...
try changing the cmos battery with the new one that cmos battery might have lost it s power ...
after that also if you face the same problem then there may be some dust particles accumulating in the processor fan due to that it might not be able start clean them and refit and try it ....
if you still face the same problem then if you are using UPS then remove the connection from that and give the direct connection this may solve your problem if there is some problem in the UPS battery ....
any doubts you can reply me
regards
-Dileep
Nov 07, 2008 | Intel Motherboard
CMOS problem! help!
Change M/board battery
if it keep going flat check all contacts are clean and not distorted
Oct 03, 2008 | Biostar M7VIG-400 (M7VIG 400-COMBO4)...
Problem with my BIOS CMOS Setting
Its due to your default CMOS setup does not match with your CPU configuration especially with CPU speed.
  1. To fixed the above problem goto BIOS and navigate settings of CPU, speed etc. Set the speed with the proper value as per manual. And save the settings.
  2. Infuture when you will load default, at that time also set the CPU settings.
  • The CMOS battery might not be connected properly or may be its not producing enough power as per needed by board. So have a look with another battery. Also clean the connection point of the CMOS battery.
Good Luck
Iqbal
Apr 22, 2008 | Biostar P4M80-M4 Motherboard
Comp probs
Remove the Thinkpad main battery. Look for a small yellow disk. This is the CMOS battery. It is connected to the motherboard with two (2) wires that plug into the motherboard. The plug is included on the wires of a new battery. Check EBay for Thinkpad CMOS batteries. I have also heard Radio Shack in some cases carries this battery.
Mar 25, 2008 | Computers & Internet
ZT Group CISNET A7050 PC Desktop Logo
61 people viewed this question
Top ZT Group Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Kyocera HP Expert
Are you a ZT Group Computer and Internet Expert? Answer questions, earn points and help others
