Question about Hotpoint 21.7 cu. ft. Side-by-Side No-Frost Refrigerator with Dispenser CSX22GRBWW
Every day we found floor water pond around the unit
Water on the floor
  • 20 Answers
I had the same problem -- it's answered by Peyton here: http://www.fixya.com/support/t1731426-leaking_hotpoint_21_7_cu_ft_csx22bc
Posted on Mar 08, 2009
Can you help me my garden pond keeps going murky i have 2 ultra violet lights in it i keep changing my water but does not get any bettter
26 fish is a lot unless it is a big pond. Cold water fish create a lot of detritus. Do you have a fountain to aerate the water? Margin plants will also help. You could also add a pump and filter. I found this unit for you.
http://www.hozelock.com/aquatics/filters-and-uvcs/easyclearfilter/easyclear-6000--1-240.html
Aug 23, 2015 | Garden
How long will it take for water to evaporate from a pond
This depends on several factors, eg cloudiness, wind speed, and atmospheric humidity. An average answer for your data might be 10-12 mm per sq metre per day, giving 23 - 27 mm per day.
Jan 21, 2014 | Garden
Puddle of water on driver side floor
The condensate drain hose is off, this happened on our 03 Vibe. After putting the hose back on I removed the seats and carpeting to dry up the mess. If the hose is no off, it is plugged up, try a coat hanger wire to push out any debrie.
Jul 17, 2013 | 2003 Buick Park Avenue Ultra
How often can I add pond clarifier to the water
I found an answer on another pond company blog. They recommend once a week for pond clarifier and the same for the algaecide
Jul 26, 2012 | Beckett Water Gardening Beckett Corp 16 -...
Water is leaking from it and is all over my garage floor. The temp outside has been below 20 degrees the past couple days. Do you all think it has something to do with that? Thanks, Tim
it sounds like the flue pipe that goes from the top of unit all the way up through roof may be leaking...possibly a poor seal around pipe on roof and it is running down pipe and into unit leaking on floor... this is a serious problem that you need to get a hvac technician out to look at to verify where the leak is coming from and may even require a roofer...1st get the unit looked at while it is doing it so that the problem can be found and fixed as water getting into unit can damage the heat exchanger rusting it out and release carbon monoxide into the home which is colorless and odorless but deadly if not detected early enough... please get a heater technician out to look at for your safety asap.... good luck to you
Jan 13, 2011 | Goodman GMS90703BXA Heater
Water on floor under unit & ice bottom of freezer
By going online, saw several posts re this problem. In short, the water drain was clogged and there was also a problem with the defrost timer. Service man blew out the drain line with compressed air and installed a new timer. Voila! Problem fixed. Interestingly, the serviceman found a wad of what looked like putty, but was sticky like gum in the drain area. He said he had never encountered anything similar.
Aug 04, 2009 | Jenn-Air JCD2295HES Side by Side...
I have an intertherm split unit and it is getting water all over
hot water heater has a relief valve on it and should have a pipe going down to the floor stick your finger in the pipe and if it is wet inside the pipe that is your source how old os the water heater dry up the floor with towels and leave a/c of for 24 hours not as wet then possible crack in new condensate pan
Jun 05, 2009 | Heating & Cooling
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
1998 Audi A6 Quattro with water at rear passenger seat floor only
Hi
Car A/C drain problem. Repair would cost you about $300
Vinay
Aug 05, 2008 | 1998 Audi A6
Refrigerators Logo
110 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
