Question about Epson Perfection 4990 Flatbed Scanner
My Epson Perfection 4990 indicator light is flashing red shortly after the scanner is turned on. The manual says that the light tube needs replacing. How do I do this or is it a professional repair?
I had the same problem and first checked the instructions in the Epson manual on the red flashing problem, read the following pdfs: Indicator light or problems
I saw the fluorescent lamp come on for a second before the indicator light started to flash red, so I knew that the lamp was ok and did not need to be replaced. Try this turn off the scanner and try unplugging the transparency lid from the back of the scanner, turn on the scanner and see if the light goes back to green. My issue turned out the be the mechanism inside the transparency lid, I kind of heard an awkward noise when I turned on the scanner, but thought it was coming from the base, I rlocked and unlocked the transportaion lock on both the base and lid, to see if that would fix it but it turned out it was coming from the lid, where there is also moving parts inside using a belt and wheels. On the end wheel closest to the front, the 2 little plastic pegs that hold down the square metal plate with wheel broke off, I could hear them inside when I lightly shook the lid, anyways I opened up the lid by removing the 5 screws and you need a screwdriver to put in each of the little openings around the edge to pry open the lid. I removed the belt and metal plate, watch out there is a spring attached to it, don;t forget how this part works when you put it back on, I found both of the little broken pegs and glued them back on with a strong plastic epoxy glue that I bought at Ace Hardware, I let that dry for 24 hours and then put the metal plate and wheel on then put the belt around the wheel, and now everything works fine.
Posted on Aug 02, 2009
How to clean the Epson Perfection 4990
I joined a free users group on Yahoo and downloaded the rememdy.
Jan 26, 2010 | Epson Perfection 4990 Flatbed Scanner
RED LIGHT FLASHING after local power cut in East London
I switched off the power, then I disconnected the lid from the base, put the power back on, the green light came on & then I reconnected the lid to the base & it has been working fine ever since
Aug 27, 2009 | Epson Perfection 4990 Flatbed Scanner
Need a document feeder for 4990 scanner
I don't believe it is possible to add a paper feed to this scanner. The only hopper fed scanner of which I'm aware is the Kodak s1220.
Jeff Underwood 1Scan.co.uk
Feb 13, 2009 | Epson Perfection 4990 Flatbed Scanner
Epson 4990 belt and pulley
HAVE YOU TAKEN IT APART AND LOOKED AT THE CONFIGURATION OF THE LAYOUT, CAMARA PHONE OR A PHOTOGRAPH OF THE ASSEMBLIY WOULD BE NICE OR
EPSON PERFECTION 4990 FLATBED SCANNER SERVICE MANUAL AND DRIVERS
MAY HELP WITH ALIGNMENT WHEN YOU FIX THE MACHINE.
ROD
Feb 09, 2009 | Epson Perfection 4990 Flatbed Scanner
Misalignment of scann after area selected
the 4990 often failed to detect automatically the film. Go manual, take the film zone, don't forget to specify it in the driver (the focus depends on it), and crop manually the picture. The result is perfect because it's yours. In many times, if the result is important to you, forget the automatisms.
Feb 24, 2008 | Epson Perfection 4990 Flatbed Scanner
Epson Perfection 4990 Flatbed Scanner Logo
1,483 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
