Question about Yamata FY900 Mechanical Sewing Machine
Don't have manuel with instructions on how to thread a bobbin & thread machine. need diagram on how to thread.
  • Eric  Pipes
    Eric Pipes May 11, 2010
    what is the name and model for your sewing maching?
  • Anonymous Mar 14, 2014
    I need a instruction Manuel. Especially for threading the machine
    Scholar:
  • 53 Answers
Http://pcmonkey.co.uk/jsm-download.com/manuals/English%20Maunals/pf2100%20english.pdf
found this in one of our other post.. hope it helps...
Posted on Mar 06, 2009
I need help putting the bobbin threader back onto a Nelco JA38 sewing machine and the springs are giving me fits. Any help?
Not sure if you are having problems with the bobbin winder or threading the bobbin. This may help:
Nelco JA 38 Sewing Machine Threading Diagram
To avoid awful thread nests under the fabric, be sure to ALWAYS RAISE the presser foot when threading the top thread.
Interestingly, the bobbin threading instructions (above) show the bobbin loading into the bobbin case so it turns COUNTER-clockwise. This is the opposite of instructions for most machines. You can probably try both, the clockwise or Counter-clockwise,and see if one works better than the other.
Be sure to use fresh, good quality sewing machine oil or Tri-Flow Synthetic Oil on your machine. Open it up, while gently wiggling the handwheel, drop a couple drops of oil every place that metal rubs against metal. Avoid plastic or rubber parts! You may even find little round holes throughout that are oil ports. Be sure to get the area around the needlebar, presser foot lifter, feed dogs, the bobbin area, and all the dial and selector mechanisms.
You can find manuals for your machine online (not free!).
Nelco Sewing Machine Manuals Instruction and Repair Manuals
Aug 07, 2017 | Sewing Machines
Bought machine at a garage sale. It works but no Manuel of instructions. Need to know how to thread it.
If you can't download the manual, try putting the thread on the spool holder with the thread coming off the spool toward the back of the machine. Be sure your fly wheel is turned toward you until the need is in its highest position. With the end of the thread, work your way across the top of the machine to the left, staying toward the back of the machine, threading through any thread guides as you go. There may only be one. Bring the thread toward the front of the machine and through the thread guide at the top front of the machine, then down on the right side of the tension knob and back up to the needle carrier. Then pull the thread down through any thread guides until you get to the needle. Thread the needle and pull the tail of thread to the back of your machine. Load your bobbin into the bobbin case, insert the case into the machine until you hear a click (you may need to rotate the case slightly to get it into the machine.) turn your fly wheel toward you while holding that top thread toward the back of the machine until the bobbin thread comes up. Pull the bobbin thread up and to the back of the machine an you are ready to go! Good luck!
Jul 22, 2014 | Sewing Machines
Threading the bobbin thread
try rethreading the machine top and bobbin--make sure to use every
thread guide
try changing the needle--make sure the needle is turned the right way
and inserted correctly into the needle holder
make sure the bobbin is turned the right way in the bobbin case
and if the machine still will not pick up the bobbin thread it would be a
good idea to have the machine checked to see if the timing is ok.
here is a link for a free manual just incase you don't have one
http://www.singerco.com/uploads/download/617_7258-instruction-manual.pdf
Nov 06, 2012 | Singer 7258 Sewing Machine
How to thread a bobbin
Which Singer machine do you have? I know how to wind and insert a full bobbin for some models.
Some wind the bobbin with it in the case. This is the case with my Touch & Sew. Inserting a full bobbin is simple. Open the slide plate and drop in the bobbin with the rings up. Make sure that to hold the bobbin thread so that it comes off at the left. Then close the slide plate and make sure that the end of the bobbin thread is coming through the notch. Hold onto the threads and turn the handwheel until the top and bottom thread come back up with a twist. To wind a bobbin for this machine, open the slide plate (some models have a little mark to line up the slide plate). Put in the empty bobbin and thread the top normally. Set the machine to straight stitch and push the bobbin wind button in. (This has a bulls-eye symbol on it.) Wrap the end of the top thread around the presser foot screw several times and hold onto the end. Step on the foot control to start winding. Keep winding until the bobbin is full. The thread wound onto the screw should break. Pull some extra thread and cut it to separate the top and bottom threads. Close the slide plate and set your desired stitch.
Other models are wound at the top of the machine. For some of with a drop-in bobbin, you need to bring the thread down to a catch and then off to the left to another catch. Some have a vertical bobbin. I don't remember if they all have a removable case. Those that do need the thread to come through a notch on the case that pulls the thread under a spring that keeps the bobbin tension. However you should check your manual. If you do not have a manual, check if one is available online. (http://www.singerco.com/accessories/instruction-manuals has many of the Singer manuals for sale or download.)
If you post a comment with the model of your machine, I'll give you a description of threading the bobbin or winding one.
Jan 19, 2012 | Singer Sewing Machines
My machine is jamming, the bottom threading gets way too loose. and jams the machine up. I dont have an manuel or any instructions.
Ironically, often times when the bobbin thread is knotting up, it's the top thread that needs the adjustment. Loos top thread thesion will tangle up in the bobbin cassing...Think about it for a minuted. Try a quarter turn to the right on your top tension and then go fro there. There could be a problem with the bobbon casing tension adjust screw and plate. but I doubt it...Nine times out of ten when the bobbon thread is tangles the top thread is too loose.
Sep 01, 2011 | Singer 3116 Simple
I need to know how to thread my tcm sewing machine as i have no instructions as it was given to me thank you
I do not know this model but why don't you visit www.about.sewing.com, there is good general threading information there as well as care and maintenance tips for sewing machines. Older machines need oiling, many modern ones have nylon parts or oiling wicks so not required so often. If you can see red marks on parts of the machine, these are usually oiling spots.
sewing machines are usually horizontal top loading bobbins where the bobbin goes into a bobbin holder and the thread gets clicked into a tension spring.
Or vertical front loading bobbins inside a removable bobbin case with a tension spring on the outside of the bobbin case.
Top threading up is usually through a number of eyelets, through a tension device of some sort, then down to the needle.
Remember, the scarf (cut out) of the needle should face to the back of the machine. Most domestic sewing machines use 130/704H needle system and the needle has a flat shank which goes to the back in the needle holder so you get this right.
You can also try www.sewingpartsonline.com or www.sewusa.com, both list some instruction manuals and threading diagrams for some makes and models.
Apr 26, 2011 | Sewing Machines
Can't balance top/bottom thread tension-model 158.Bottom thread is a straight line. Have increased top tension to the stop. No effect.Have reduced bobbin tension until bobbin and case fall freely when held...
I disassembled the top thread tension controller consisting of 12-13 pieces, including 2 springs. Since they all fell out on the table I spent about 2 hours learning the proper stacking order on the central shaft.
With a combination of reasoning based on each unique piece shape and trial and error I put it back together, adjusted top and bottom tensions according to the instruction booklet for the machine, tested some stitching, made final adjustments and all worked well.
I don't know what was changed in the process but it worked.
Don
Sep 03, 2009 | Kenmore Sewing Machines
My machine will not pick up the bobbin thread
how long have you had the machine?
I don't see what kind of machine you have?
does the bobbin drop in from the top, side, bottom?
email me at
monis_gifts@bellsouth.net
tell me what kind of machine and model number you have
I'll see if I can help
Sep 02, 2009 | As Seen On TV Sewing Machines
Thread keeps breaking and i can't get the stitch setting to go from stretch stitches to normal stitching
Be sure to check that the machine is threaded properly into the needle. Also look at the instruction book to be sure you have the bobbin inserted corectly and that the thread is place properly (threaded correctly) in the bobbin area. Some machines have a diagram on the machine, but if you do not sew frequently; it's easy to mis-thread the bobbin. Did your bobbin thread wind properly onto the bobbin (not loose or loopy). That too, can be a problem. Best of luck. Susan
Aug 04, 2009 | Kenmore 756A-30BH Mechanical Sewing...
Yamata FY900 Mechanical Sewing Machine Logo
182 people viewed this question
Top Yamata Sewing Machines Experts
Lyle Siemens
Lyle Siemens
Ellen Den Dulk
Ellen Den Dulk
Level 1 Expert
Douglas Plant
Douglas Plant
Are you a Yamata Sewing Machine Expert? Answer questions, earn points and help others
