Question about Mantis 4-Cycle Tiller
What is the cap setting on mantis coil - Mantis 4-Cycle Tiller
Mantis tiller qiuts after a short running time ,then cant pull the recoil rope
Anon, it sounds like you need to get your Mantis serviced. If you cant pull the recoil rope it sounds like the coil is overheating and obstructing the fly wheel.
Jul 11, 2014 | Mantis 2-Cycle Tiller
Mantis tiller no spark
Hi anon two thing's that it could be. Firstly it could be the coil is fouled by Corrosion or secondly the switch that you switch on could have failed.
Jun 08, 2014 | Mantis Tiller
My mantis tiller 2cycle: Iput new spark plug the on&off switch ok just not getting a spark to the plug. Think its the coil ?
I would say it is the coil, if you have a multimeter you can connect it to the coil and try to start it to see if it producing voltage. Hope this helps Tim
Apr 16, 2011 | Mantis Gas Mini Tiller/Cultivator, 2 -...
I have a manis tiller that wii not run rigth. i have put i a carber kit
My mantis tiller ran fine,I put it up for the winter and now it won't start,I checked to see if it was getting gas which it was, could it be the coil? I did check and they say its very rare that the coil goes out.I also check for any type of spark and nothing. Please help!!!! thanks ,Clay
Mar 26, 2011 | Mantis Gas Mini Tillercultivator 2cycle...
I Have a Mantis tiller that I can get NO spark
set the coil to the thickness of a dollar bill from the flywheel and tell me what happens. make sure kill wire isn't grounding somewhere else
Jun 07, 2009 | Mantis 2-Cycle Tiller
I had my 2 cycle tiller at a shop and he told me
Mantis Product Owners Information
spacer.gif arrow_red.gif Submit your Question spacer.gif Please Select a Category Below arrow_green.gif Mantis Tiller/Cultivator Gas Tiller FAQ (12) arrow_green.gif Mantis SprayPartner and SprayMate FAQ (7) arrow_green.gif Mantis Blower/Shredder/Vac Service FAQ (3) arrow_green.gif Mantis ComposT-Twin FAQ (10) arrow_green.gif Mantis Edger FAQ (7) PARTS
If you need parts, or wish to return a product, please call our Customer Service Department at 1.800.366.6268
Hours are Monday through Friday 8:00 AM - 5:30 PM Eastern time.
Mantis tiller sv-4 echo engine no spark from coil mantis 2cycle tiller i got it running tryed to start it 4hrs latter same old problem wont start, plug wet with gas wont start. coil was checked by shop...
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
May 31, 2009 | Mantis 2-Cycle Tiller
Item: Mantis Tiller Problem: wire to kill switch came loose from where it attaches under the cowling covering the engine. Question: where does it attach, I need to reconnect it
Hello:
The Shut Off Wire is Attached to the Ign Coil.
There is a Spade Lug on the Coil that the Wire Attaches to.
Hope this Helps.
Good Luck
Respectfully
John
May 10, 2009 | Mantis 2-Cycle Tiller
Mantis tiller sv-4 echo engine: no spark from coil
There are only 4 parts to the 2-stroke Mantis ignition system: the spark plug, the "kill button", the flywheel with embedded magnets, and the coil with integral plug wire. There are no "points" to clean or refurbish. If you've tried a new spark plug, unplugged the wire leading up the handlebars, and the magnets on the side of the flywheel are strong enough to attract a screw driver blade, then it must be a bad coil. That's all it could be. End of story.
Cruising the internet I see where these Echo coils go bad all the time. You can order the coil, but if the machine hasn't run in several years the carb will also need cleaning. So one thing leads to another. The gear box grease also needs replacing each year. What I'm trying to tell you is these are disposable tillers and due to length of time, incomplete care/ storage, ....whatever, this one's time is up.
Sorry.
Feb 26, 2009 | Mantis 2-Cycle Tiller
Mantis 4-Cycle Tiller Logo
149 people viewed this question
Top Mantis Garden Experts
paulfvincent
Jim Parker
Jim Parker
Mike Squire
Are you a Mantis Garden Expert? Answer questions, earn points and help others
