Shine a flashlight on the dark screen to see if you barely
see the icons on the desktop. If so, then the LCD Inverter is bad.
Plug in an external monitor and see if the display shows up on it. It can be
any kind of monitor even the old big fat crt monitors as long as it has a vga
cable to connect to your computer's vga port. If so that proves your
video card is ok. The video will show on most systems when you reboot
without you having to do anything. Some systems will require you to hit the FN
(Function key) + F1 thru F12. Hold down the FN key then hit the correct
key for displaying on the monitor (F1 thru F12). The correct key will
normally have CRT/LCD on it or it will have the icon of a display.
If you see no icons by shinning a flash light and the external monitor works,
then your screen is bad. If you see no icons by shinning the flash light
and nothing shows on the external monitor, then most likely your video card is
bad.
For a Desktop:
Try using another monitor on the computer. Borrow a
monitor from a neighbor, friend, relative or co-worker and connect it
to the computer. If the Borrowed monitor shows the display then your
original monitor is bad. If the Borrowed monitor does not show on the
display then you Video Card is bad.
test all leads that attach to your hard drive including electrical extensions
the leads from your ((motherboard to your hard drive)) Sata make sure they have dust free secure connection and are not faulty or just replace them they could be faulty
make sure all leads that are attached to your drives dvd\cd have secure connections and are not faulty or just replace them they could be faulty ?
even something as small as an electrical extension or a faulty fan lead can cause this problem follow the troubleshooting procedure a computer needs all of the data and electrical current to travel through every working device and to have an end for a computer to be able work properly
make sure your graphics card is securely seated with no dust
if you remove the graphics card to clean the socket replace it
restart the computer the found new hardware wizard should activate
hope this helps you
