Question about Toshiba Satellite A205-S4607 Notebook PC
My problem is: Description: Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 19. Problem signature: Problem Event Name: PnPDeviceProblemCode Architecture: x86 Hardware Id: IDECdRomSONY_DVD_RW_AW-G540A____________________1.74____ Setup class GUID: {4d36e965-e325-11ce-bfc1-08002be10318} PnP problem code: 00000013 Driver name: cdrom.sys Driver version: 6.0.6001.18000 Driver date: 01-19-2008 OS Version: 6.0.6001.2.1.0.768.3 Locale ID: 9225
Pnpdeviceproblemcode 19
I would manually un-install, and then reboot so the system could re-install. Also do a complete system virus scan, just to be sure
that a bug isn't operating.
Sep 17, 2012 | Dell Latitude D630 Laptop Computer PC...
Description Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 31. Can you please help me?
Method One
  1. Remove the Upperfilters and Lowerfilters values completely from the following registry key: HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318}NOTE: If you are getting a code 39 message, it may be that additional third-party filter drivers were added to UpperFilters and LowerFilters values in addition to Adaptec filter drivers. In that case, you may try to remove the non-Adaptec filter drivers first, leaving the Easy Creator filters in place to see if the Code 39 goes away. If you still receive an error code 39, 32, or 31 message, remove the Upperfilters and Lowerfilters values completely in the preceding key.
  2. Restart your computer.
Sep 14, 2011 | Acer Aspire 4720 Notebook
Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 10. what this mean and how to solve it
A Code 10 error usually occurs due to:
  • Missing device driver
  • Malfunctioning device driver
  • Incomplete device driver files
select the System option from the Control Panel. In the System Properties dialog box, select the Hardware tab, and then select the Device Manager button. Scroll through the Device Manager window and identify the faulty hardware device. Right-click on this device and then select the Update Driver command. Next, follow the screen instructions to update the driver of the selected device.
If you need more information, reply me soon.
Thanks
Feb 20, 2011 | Acer Extensa 4220-2346 Notebook
The web-cam is not working. I only get "web-cam driver open fail. Please restart camera or computer". I have dine this many times without success.
Re-install the driver for the webcam.
Follow these steps to re-install the driver for the webcam. You will need to be logged in as an Administrator or have an Administrator password ready. 1. Click the Windows Start button. 2. Click Control Panel, System and Maintenance and then Device Manager. 3. Right-click on Chicony USB 2.0 Camera and select Update Driver Software. A yellow exclamation point indicates that the camera is recognized by Windows but is not working properly, probably because of problem with the device driver 4. Select Browse my computer for the driver software. 5. Select Let me pick from a list of device drivers on my computer. 6. Select USB Video Device from the list, and click Next. 7. If the message “Windows encountered a problem installing the driver software for your device” appears, click Close. 8. Restart Windows. The webcam should now work properly.
Thanks
Jun 14, 2010 | Toshiba Satellite A300-0CF035 Notebook
Windows was able to successfully install device driver software, but the driver software encountered a problem when it tried to run. The problem code is 31. Problem signature Problem Event...
Your device has a conflict with another one. Open your device manager and go to the tab for your Audio/sound (that is the device your error message above shows is having the problem). Go to the drivers page and look at its properties. You should see a box that shows the device is in conflict with another and lists its IRQ. You can either TRY to assign the IRQ manually (which usually doesn't work) or you can remove the offending device, restart Windows and let it reinstall the device automatically and see if Windows can fix itself.
Feb 14, 2010 | Acer Aspire 4720 Notebook
Problem Event Name: PnPDeviceProblemCode Architecture: x86 Hardware Id: PCIVEN_8086&DEV_2A42&SUBSYS_01761025&REV_07 Setup class GUID: {4d36e968-e325-11ce-bfc1-08002be10318} PnP problem...
Problem signature:
Architecture: x86
Hardware Id: USB\VID_0421&PID_0355&REV_0490
Setup class GUID: {4f919108-4adf-11d5-882d-00b0d02fe381}
PnP problem code: 00000027
Driver name: ccdcmb.sys
Driver version: 7.1.32.68
Driver date: 05-18-2011
OS Version: 6.0.6001.2.1.0.256.0
Locale ID: 1033
Oct 02, 2009 | Acer Computers & Internet
Toshiba Satellite A205-S4607 Notebook PC Logo
350 people viewed this question
Top Toshiba Computers & Internet Experts
Brian Sullivan
Brian Sullivan
joecoolvette
joecoolvette
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
