Question about Kenmore 62602 Electric Dryer
Kenmore Dryer 62602 Won't Start
Tumbler spins freely, no burning odor previous to stopping. When you push the start button it simply clicks, no response at all. We have worked at pressing the door button, and have cleaned all vents and hoses. Any suggestions?
  • long72 Apr 28, 2009
    my kemore electric dryer 70 series won't start. i have cleaned all vents and checked voltage at source. checked start button and when button is pushed i have continuity. what is my problem?
  • 107 Answers
Thermal fuse or motor relay. Make sure you have proper power at plug as well.
Posted on Mar 23, 2009
Kenmore dryer model 110.74994300 push start does not stay on
Lastly check ur DOOR SWITCH for continuity with a meter when the button is pushed in the (on/Door closed position,) it may have gone bad.
Kenmore Whirlpool Dryer Won Start Easy Fix
Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Jul 01, 2014 | Kenmore 62602 Electric Dryer
Kenmore dryer won't start
Spin the drum by hand to see if you feel resistance. The belt may have broke.
Oct 21, 2012 | Kenmore Dryers
Dryer heats but drum does not turn when the start button is pushe
You need to check the drum belt. With dryer empty, reach in and give it a spin. If the belt is good, it will stop in 1/2 turn or less when released. If the belt broke, it will spin almost a full turn.
Oct 25, 2009 | Kenmore 62602 Electric Dryer
Frigidaire dryer hums when button is pushed in but won't start
ok can u turn the tumbler freely,
if no well there is something stuck in you blower like a sock or something
if the tumbler turns freely
keep the door open and hold the door switch
try pushing the start button
and tuning the tumbler, yes all three at the same time lol you may need a hand
try tuning the tumbler when you hear a hum
if it takes off bad news your start winding on the motor is bad or the capacitor depending on your model
if it does not turn, but the hum continues longer than 1-2 minutes it could be just a belt
Oct 19, 2009 | Frigidaire Electric Dryer
Kenmore dryer will not start. is it the door
since to push button is a contct relay,
i would suspect, the door switch first
Oct 13, 2009 | Kenmore 62602 Electric Dryer
Kenmore electric dryer stopped and wont start when button
Make sure there is 240vac then check the door switch, the start switch. Beyond the obviouse it is basic troubleshooting to work down to the failed component. Eric
Aug 08, 2009 | Kenmore 62602 Electric Dryer
The dryer doesn't tumble
first see if your belt has broken on drum and then see if motor is working
Jun 12, 2009 | Kenmore 62602 Electric Dryer
Dryer stopped in mid cycle.
Sounds like you might need a new motor.
Mar 06, 2009 | Kenmore 62602 Electric Dryer
Dryer will not start.. Here clicking sound when i push start button but nothing happens
Did you clean the lint screen and replace? Also - all lint should be cleaned from back of dryer and the duct...many dryer manufacturer have safety sensors that will not light dryer due to there being too much lint, not enough air flow...(safety feature) ...
Oct 09, 2008 | Kenmore 62602 Electric Dryer
Wont start
try turning the drum by hand...is it jammed? if not, then: the motor will not turn due to a number of reasons: 1.) simply burned out copper windings 2.) switch not turning on motor or not turning on motor starting circuit-depending on design ...if jammed, then try to find the interference to turning
May 31, 2007 | Estate TEDX640JQ Electric Dryer
Kenmore 62602 Electric Dryer Logo
213 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
