Question about Dell Inspiron 1525 Notebook
My dell Crashes within minutes of turning it on!
I bought my dell inspiron 1525 in october and it has been fine until only yesterday. I turned it on and then it froze within about a minute and a half, after about another minute of just a frozen screen it turns itself off. I have tried rebooting it, shutting it down then turning on again but nothing, it just does the same. Just Freezes! What Do i Do?
  • 2 more comments
  • Anonymous Mar 09, 2009
    My dell 1525 freezes at times. It is not consistent. Forces me to shut down the system and restart. I have had Dell run the diagnostics and says there is nothing wrong with the hardware.
  • jemma_ash Apr 02, 2009
    my 1525 laptop shuts down randomly as well... had it for not even a year and contacted Dell support... they told me to run the diagnostics test...it froze while doing that... so they sent me a new hard drive... now a month on from the new hard drive the same thing is happening again! i'm not even doing anything major on the laptop at the time.
    therefore it cannot be a hard drive problem because i have had a new hard drive in... i noticed when it shut down on me yesterday the fan was a bit louder than usual but thats the first time the fan has done anything like that...
    (i thought i would just repeat this from another problem post... it seems to me to be a model problem and not a Vista or Hard drive problem... i've now seen at least 3 people with the same problem...strange...)
  • Jennifer Pet Apr 02, 2009
    I turn on my dell laptop and when I do it freezes up and I can not do anything else only turn it off.
  • lmais04 Apr 27, 2009
    I have the same problem and have had to do a factory image restore. It is still happening. My laptop is 1.6 years old but the hard drive is only 6 months old.
  • 463 Answers
This could be a multitude of things, but the first thing that comes to mind is an overheating problem.
To rule out other things, remove and reseat the RAM, HDD, CD/HDD drive, Battery, Wi-Fi/BlueTooth mini adapters, etc.
Also, for further clarification, is there any error indicated on the screen prior to the machine turning off?
Thanks,
Rob
Posted on Mar 06, 2009
  • 3,940 Answers
Boot to the 1 time boot menu (F12 button at Dell Screen) and run diagnostics on the system.
You could have a failing hard drive or other hardware malfunction.
If Diagnostics pass,Try booting to the SAFE MODE (F8 at Dell Sceeen) and try running system restore to before the errors started.
I have a Dell Inspiron 1525. I bought it in August, 2008. It has been working fine until recently. Now the problem is that it only charges upto 32%. and then it says "Plugged in, charging" but it does not...
the problem is batteries wear out. You will most likely need to replace it
http://www.fixya.com/support/r3743571-long_will_battery_in_portable_computer
Sep 01, 2010 | Dell Inspiron 1525 Notebook
My inspiron 1525 will shut down every 15mins or so. i don't what is wrong with it.
Most likely, if you have not set the power settings in the control panel to do this, you have a heat problem.
This can be tested by turning on the computer and using it until it freezes or turns off. Wait a few minutes and if it turns on again, it is most likely heat. Check to see if the cooling fan is running. Also, with canned air, blow out the dirt that accumulates in the case.
Jul 18, 2010 | Dell Inspiron 1525 Notebook
Dell inspiron 1525 laptop screen goes dark @3minutes after turning on and then when I shut the lid and reopen lid the screen turns back on for 15sec then turns back off...repeat steps and you see my...
Sounds like a loose connection or bad capacitor. If it's a loose connection then after the initial three minutes of warming up the connection separates that's why you only get a picture for 15 seconds after rebooting. If it's a bad capacitor the same is true but for a different reason. The bad capacitor will work until it gets too hot then you're out of luck again. It could be the LCD or the video card.
Feb 13, 2010 | Dell Inspiron 1525 Laptop
My laptops backlight turns off when i plug it in.it works fine when running off batt power
Maybe you select the save-power mode when using your Dell inspiron 1525 battery. So it auto turn off your backlight.
Jan 13, 2010 | Dell Inspiron 1525 Notebook
Computer Freezes
I recommend downloading a registry repiar program and system optimzer like glary utilities from glaryutilites.org It is free and help out tremendously.
Make sure you avast antivirus or whatever you use is up to date. Run a scan for all viruses.
Lastly, if needed, format HD and reinstall windows
Sep 03, 2009 | Dell Inspiron 1525 Laptop Jet Black
I have an Inspiron 1525 Notebook and I turn it on and it starts like it is suppose to and then Right before I get to my sign on page it goes to a blank gray screen, What could be wrong
it could be corrupt windows or your resolution in windows was set to high that your monitor does not support or you may have installed the wrong video driver or if you have daul video outs the secondary may be enebled thru windows causing the monitor on laprop to turn off thinking its on ext video!
Sep 01, 2009 | Dell Inspiron 1525 Notebook
Blue Screen Comes and Computer (Dell 1525) Keeps Restarting HELP!
are you using windows? just reinstall your operating system, this may keep it back to normal
Jul 15, 2009 | Dell Inspiron 1525 Laptop Jet Black
Dell Inspiron 1525 not turning on
hi. I suspect that you have either a dead battery or just need a reset. unplug the power cord and then remove the battery. wait two minutes and reinstall the battery.
this will reset everything. now try turning it on. if it won't come on plug in the power cord and charge the battery for 30 minutes before attempting to power up.
Jun 29, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 Notebook Logo
933 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
