Question about Toshiba 65H82 65" Rear Projection Television
Opening the back panel of Toshiba 65H82 rear projet tv
I need to clean the mirror and I forgot how to open the back panel to have access to the mirror.
Thanks
  • timbick45 Mar 30, 2009
    need inf on how to clean mirror and blow off dust and cat/dog hair. left it my moms and it just is not like i remember it. what do you remove? the card board part in back or the gray frame that holds the screen???
    its a 50h82 i took a peek in the front behind the cloth front cover and i saw the bulbs in front. i thought they were in thr rear??
    please help.
    My home email is
    timbick@comcast.net
    thanks
    tim
  • Shahid Electronics
    Shahid Electronics May 11, 2010
    Below image might help you to open TV to clean mirror.
2 Suggested Answers
SOURCE: I have a toshiba 50inch rear progetion tv. I was
There is one mirror inside. It is easy to remove the front plastic screen by removing the bottom fabric grill (snaps off by pulling outward like a removable speaker grill). Remove several wood screws along bottom edge of screen. Lift up the whole plastic screen frame and pull it away from the TV; but be careful with the control wires that go to the center panel, which snaps off the big screen frame easily. The mirror is right there.
Posted on May 26, 2009
INNER SCREEN NEEDS CLEANING
Here is a picture that shows you how to remove the front screen to get access to the mirror as well.
Aug 15, 2008 | Toshiba 51H84 51" Rear Projection...
I have a Toshiba 65H82 and at first the picture was blurry but would clear up after about 10 mins now the picture just stays blurry. Can you tell me what the problem could be and if it is worth fixing it?...
Try adjusting the focus block this requires opening the back and front bezel of the TV. If it doesn't clear up after adjustment attempts then the liquid coolant inside each of the tubes need to be emptied and refilled with new coolant. Over time the coolant gets cloudy and can cause a blurry image with a white sheen. Contact me at the link below so I can help you further.....if this helps please rate:-)
Thank you:-)
http://tvtechwork.webs.com/
Oct 21, 2010 | Toshiba 65H82 65" Rear Projection...
I have a toshiba 65H82 tv i need to move to my new house. can i lay it down or does it have to be upright?
Move it upright best for the tv.These tvs have chemicals in it three CRT tubes colors guns.
Sep 08, 2010 | Toshiba 65H82 65" Rear Projection...
Cleaning mirror and how to get in there
Hello timbick45,
You want to remove the top rear panel. Remove the screws and the top, along the sides, and along the middle of your TV (from the rear). Onec that is done be very careful because the mirroe is attached to the rear panel of the TV. set the back down and with a clean cloth and a can of air remove the dust off of the mirror, use a light window cleaner, after removing the dust. To clean the bulbs just use air to blow the dust off (not not attempt to clean the bulbs with any solvent.
I hope this helps
Thank you,
Shuttle83
http://www.electron-age-technology-llc.com
Mar 30, 2009 | Toshiba 50H82 50" Rear Projection...
I need to clean mirror
Most rear projection sets the screen will pop off the front. Usually a couple of hidden catches. Get another person for this.
Once off you can clean the mirror but not the inside of the screen.
Unplug tv first
Mar 13, 2009 | Toshiba 43A10 43" Rear Projection...
Spider web inside tv
You need to open and clean it carefully.
  1. remove the back bottom panel
  2. Remove the top back panel (carefully the mirror is on it)
  3. Clean the mirror and the lenses (on the mirror don't use products with ammoniac) "a good tip is to use same staff to clean photographic cameras"
  4. Place back the top rear panel
  5. place back the bottom rear panel
Nov 09, 2008 | Samsung PCH521R 52" Rear Projection...
Dark color
Have you tried polishing the projection mirror and changing the coolant in the CRTs. The mirror alone can make the picture dull. Do not use windex to clean the mirror, just a soft damp cloth then dry. You can access the mirror hrough the back panel its a bit of a reach but its do able from the rear the mirror is directly above the rear acess panel.
Jan 19, 2008 | Philips 43P8341 43" Rear Projection...
Open Questions:
See all Toshiba 65H82 65" Rear Projection Television Questions
Toshiba 65H82 65" Rear Projection Television Logo
238 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
