Question about Hobart 24 in. LXIH-3 Built-in Dishwasher
LX-18 error code E4 what is the problem? Replaced motor runs great.
The water does not seem to be pumping to wash the dishes....could something be plugged? I can hear the pump and it pumps the water out at the end...
Posted on Mar 06, 2009
Hw do i remove error code E4
E4: Indicates lack of refrigerant, or the compressor is not running, or the thermistor is out of
Action: Check that the compressor is running by listening.
If it is apparent that the compressor is running, then check the
temperature difference across the evaporator.
i.e. Measure temperature of return air at inlet filters and
measure temp. of discharge air at grilles. This temp diff.
should be 14 to 18 C. with fan on hi speed. If temp diff. is less than this,
suspect lack of refrigerant.
Fit a suction gauge to access valve at rear of unit. See fig 12. On a 35C
outside temp. then suction should be 380 to 450Kpa.
Good luck
Feb 14, 2015 | Heating & Cooling
E4 error on screen
Check out door unit. May be weak in Running capacitor/Fan motor capacitor/Condensor coil dust blocked. First clean and run, if still problem check speed of fan motor, if less replace fan-capacitor.
May 07, 2014 | Midea 24,000 Btu 17 SEER Inverter Mini...
E4 error code beautyrest electric blanket
beauty rest electric blanket error code - akaQA > Uncategorized
beauty rest electric blanket error code. What does error code E4 mean? Answer this. 0 Views: 2487 Answers: 1 Posted: 3 years ago. Comment this question.
E4 error code beautyrest electric blanket - Fixya
Dec 13, 2013 - E4 error code beautyrest electric blanket One side works the other returns an "E4" error code - Simmons Beautyrest Microfleece question.
Dec 13, 2013 | Simmons Beautyrest Microfleece Electric...
I have a kirby lester KL15 pill counter that gives an E4 error code, any help would be greatly apprecicated.
Tablet dust or residue on detector windows. Clean glass detector windows thoroughly.
Sep 12, 2012 | Office Equipment & Supplies
What is error code e4 on vision fitness t9350?
I have an HRT9450 that is showing an E4 error code - but when I run the auto calibration it doesn't seem to finish.
It runs up the speeds and back down but then stops without ever showing 'end'.
When i then take the safety key off and replace it the E4 error code shows again.
The treadmill was working fine until I moved it a foot and then the error code shows - meaning I'm suspecting a lose cable but I don't know where to start looking for it.
Any advice?
Feb 18, 2012 | Exercise & Fitness
My Singer stylist 7258 is giving an E4 error code. It wont work at all, just give an odd sound and a high pitched sound then stops, flashing E4 on the display screen. It is only 2 months old and I live...
the brand new stylist I just bought at a thrift shop for $15.99 had a sticker on it stating, "Broken, you fix, parts in back"... I got the lady to get the parts in the back, which was the box it came in and all the accessories. Took it home plugged it in and E4 came up. I took of the nose guard with the one screw on the side, reached in and turned the coggs gently, viola, it works great.. The little servo or motor if you will got stuck when turned off in a zig/zag decorative mode. eazy fix, great machine,
hope this helps..
Michaelalan Quilting
Oct 26, 2011 | Sewing Machines
I get a E4 errror code.
The broken water tank flipper will directly cause the unit to not function and the E-4 message will appear on the display screen.
Jul 15, 2010 | Soleus LX-140 Portable Air Conditioner
Riso ks800
e4-ink over flow. solution-clean ink sensor.
e3-clamp motor locked. solution-use code 64
Sep 21, 2008 | Office Equipment & Supplies
Error code 4
check the sub code , it would read E4-? , such as E4-10 is fuser fan, E4-01 is low fuser temp, sometimes hold the print key after in code and sub code may appear. Then you can go to next step of repair.
Jan 30, 2008 | Panasonic FP-7735 Black and White Copier
Hobart 24 in. LXIH-3 Built-in Dishwasher Logo
371 people viewed this question
Top Hobart Dishwashers Experts
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
