SOURCE: keyboard/mouse not working
You need to restore to a previous date before you installed the wireless mouse / keyboard.
If that dont work then your only solution is to format and reinstall since it might be you could have damaged a few vxd files window's needs to use those devices
(THIS IS ASSUMING THE MOUSE AND KEYBOARD WERE CONNECTED PROPPERLY) AND THEN THE SYSTEM WAS TURNED ON
if that wasnt done
shut down compuer
2.) plug mouse into green ps2 port and keyboard into the blue one
3.) turn on computer
SOURCE: labtec wireless desktop.
Could be radio interference from somewhere. I tracked my similar mouse problem down to emissions from the ethernet adapter that connects over the house mains wiring. Try the using the mouse close to the receiver, if it works ok interference is likely.
SOURCE: wireless keyboard numbers on right not working and wireless mouse light not on
My Dell wireless keyboard doesn't work. I replaced the batteries in it and pressed the green button on the back of it then the button on the wireless thing plugged into the computer. That light blinks for a few seconds then stops but the keyboard still doesn't work. My wireless mouse works fine.
SOURCE: Wireless mouse and keyboard not working
If you have got a USB receiver for the wireless keyboard and mouse, then the solution might be with the receiver. Normally we know that to play a USB thumb drive, we simply plug in and play. But some model of Acer computer require us to press the button on the thumb drive to activate it. The model I had (an Aspire model) set the press button same as the blicking light bulb. So (a) turn on computer, (b) plug in thumb drive receiver (c) press button on the drive, (d) press "contact" button on the mouse and keyboard. That works for me.
SOURCE: wireless keyboard not functioning
I unplugged the usb connector and took out the batteries for both the keyboard and mouse for 30 seconds. Then I plugged everything back in.
i have a Typhoon Cordless Navigator Deluxe Keyboard Model No. 40300. The mouse works fine but the keyboard doesn't work at all. I'm running Vista. Are there drivers available for this keyboard for Vista??
