Question about Sewing Machines
Needle thread does not pick up bobbin thread it keeps skipping stitches.
  • 26 Answers
Clean it using a can of air to make sure there is not any fabric or dust caught in the under area. the needle could be bent slighly just replace it.
these are the two things I look for when this happens with my machine. needle is the one most offten causing the problem.
Posted on Mar 08, 2009
My machine is skipping stiches it seems its not picking up from the bobbin
Install a brand new needle and confirm it is inserted with the flat side facing the proper direction.. A bent, damaged needle will sometimes cause skipped stitches or even needle strikes inside the machine. A new needle is the least expensive cure for a lot of sewing machine problems. The needle should be changed about every 8 hours of sewing or at least when starting a new project.
Remove the top thread. ALWAYS RAISE the presser foot and rethread from the beginning. Verify the thread path is correct.
Sometimes, skipped stitches will occur if the needle, thread, and fabric are incompatible. Be sure to use the correct needle for your project. Use a good quality thread--AVOID old or bargain bin thread!
If the machine continues to skip stitches, then it may be out of time. Search for sewing machine timing or take it for service.
Basic Maintenance Tension Skipped Stitches
What to Do If Your Sewing Machine Is Skipping Stitches
Don Ignore Your Sewing Machine Skipping Stitches Simple Solutions
May 24, 2017 | Sewing Machines
Okay, you've tried a lot of things. The question is this: is the thread snapping (where abouts in the path), or is it shredding at the needle? Here are a few more:
Remove the top thread, ALWAYS RAISE the presser foot, and rethread from the beginning.
Try different thread--perhaps a polyester thread like Isacord or Aurafil. (AVOID old or bargain bin thread.)
Try a different kind of needle (brand new needle!)--like a top-stitch, microtex, or embroidery. The top stitch needle has a larger scarf that will better protect the thread if shredding is the issue. (I use a special bobbin case that I've increased the tension for Isacord thread and I use the same thread in top and bobbin.) I also decrease the top tension a tad so the bobbin thread will not pull to the top. You may need to install brand-new needles several times on one quilt when they get dull.
Usually an 80 or 90 needle will work for FMQ through a fabric/batting sandwich.
Check that the needle's eye is the appropriate size for the thread (also a cause of shredding thread).
Set the upper tension at the midway point perhaps a bit looser for FMQ (this tension will probably need to be tweaked for your particular machine due to wear and age).
Use an FMQ foot and drop the feed dogs. A Supreme Slider (avlb on the internet) is very helpful in helping move the quilt while doing FMQ.
Work at a moderate but steady pace. I find a faster speed while FMQ gets me into spots I can't get out of, overlapping stitches, or outside the quilt edge.
FWIW, I still get some skipped stitches with FMQ. Usually, it happens when I move the fabric too fast, especially around a curve. I have a tendency of speeding up while going around a curve that will cause skipped stitches or eyelashing.
I'm also wondering if there is something to do with the fabric and/or batting you are is it Batik? Batik is very tightly woven and presents some particular challenges. The type of batting could be more dense, making it harder for the needle to penetrate the sandwich. Also, pulling or stretching the fabric can cause skipped stitches.
Here What to Do if Your Sewing Machine is Skipping Stitches
10 reasons for skipped stitches
If you see no improvement in your machine's stitching, you may want to have it serviced.
Apr 28, 2017 | Juki Sewing Machines
Wont pickup bobbin thread when sewing.
Make sure you are using a brand new needle. Bent/damaged/dull needles frequently will fail to pick up the thread.
If it continues to skip stitches, it most likely has a needle/hook timing issue--the needle arrives at the bobbin at the wrong time to intercept the bobbin thread.
There are web sites and videos available that discuss sewing machine timing, or you can take it for service.
Sep 10, 2016 | Sewing Machines
Skip stiches
Changing the needle may be helpful. A bent/damaged needle will tend to not pick up the bobbin thread properly.
Try a different type of thread--avoid old or bargain bin threads.
Could also be an incompatibility of the needle, thread, and fabric.
All About Needles
If it still skips stitches, then it may have a needle/hook timing issue that would require service.
Aug 19, 2016 | Sewing Machines
I have a XL2600I and the top thread is only picking up the bottom thread about every inch. What can I do or replace?
try a new needle--use the right needle for the fabric being sewed
rethread the machine, using every thread guide
take the bobbin out of the bobbin case and reinsert it, making it sure it counter clock wise in the bobbin case
also could be a timing problem
Mar 15, 2016 | Sewing Machines
How do I thread the 960 Bernina Bobbin?
I'm assuming you have a front loading bobbin. Look at your bobbin. Hold it so the thread is falling down from the top to the right side. Slip it straight in to your bobbin case, and pull up through the slit, until it snaps in through the side clip.
Generally, if you are missing stitches, the hook isn't picking up the thread from the needle, and you will need to take it in for service at a Bernina dealer.
Mar 03, 2015 | Bernina Sewing Machines
Skipped stitches
lower your needle. If up to high can't catch the bobbin thread.
Aug 31, 2017 | PfaFF Tiptronic 2040
Sewing machine not stitching
1.the needle is not inserted correctly
2.the needle is damaged
3.the wrong size needle is being used
4.the foot is not attached correctly
it's also possible that the machine needs to be serviced
May 31, 2012 | Singer Sewing Machines
I think the timing is out on my janome 2039 sewing machine
It is very possible that the timing is off, which often occurs with broken needles. A common symptom is that the needle will not pick up the bobbin thread. Missed stitches aren't necessarily timing related--be sure to install brand needles often and use the correct needle for the fabric & thread you are using. Using the wrong needle will often cause skipped stitches.
You can search for sewing machine timing or take it for service.
Apr 12, 2017 | Janome Harmony 2039 Mechanical Sewing...
Keeps skipping stitches and knots thread
Good day!
please try this simple tips:
Good day!
A sewing machine operator can often help themselves when their machine does not operate properly.
Here are some simple instructions, which if properly used can save time and mechanics service calls.
This could be trouble;================Do this;
1.Top tension to tight================loosen tension 1 turn
2.Machine improperly threaded=========check threading
3.Thread twisted on guide post========"
4.Thread twisted out of tension======="
5.Take up spring bent or broken=======Check action of spring
6.Thread jumped off pull off finger===Check threading
7.Needle bent or burred===============new needle
8.Bad cone of thread==================try another cone
1.Bobbin tensionspring to tight=======Loosen tension slightly
2.Bobbin threaded wrong===============check threading
3.Bobbin wound to tight or uneven=====try new bobbin
4.lint or thread on bobbin case=======clean inside case
5.Lint or thread inside hook==========clean inside hook
6.Bobbin case nicked bent or burred===check/change case
1.Needle bent or burred===============change
2.Needle set in crooked===============Check
3.Thread jumped off take up spring====check threading
4.Thread jumped off pull off finger===check threading
1.Forming loops on top of cloth=======Tighten bobbin tension
======================================or loosen top tension.
2.forming loops on bottom of cloth====Tighten top tension
3.Bobbin placed in case incorrectly===remove and replace
4.Bobbin thread slipped from under====check threading of
tension===============================bobbin case
5.Lint or thread in top tension=======clean between tension discs
Thank you and good luck.
Jun 06, 2011 | White Sewing 2037 Mechanical Sewing...
Sewing Machines Logo
271 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
