Question about Frigidaire PLMV169DC Microwave Oven
Control pad does not repond
This is a Microwave Frigidaire 1000 Watts Model PLMV169DCD, the control pad is not working, it illuminates,but the start button and others don't work.
Only the clock works.
  • Anonymous Mar 13, 2009
    had the same problem. There are two switches that engage when the door is closed. One of them is bad. Sorry to say but you will need to either do this your self or get a repairman. The switch needs to be replaced. This appears to be a very common problem with these Frigidaire microwaves. Will cost about $125 (parts/labor) to get it fixed if you get a repairman. It is not the clock.
  • robertsala Mar 29, 2009
    This is similar to my problem. I have a Samsung microwave. Everything lights up but it doesnt let you do anything. I opened the microwave and everything seems to be in its place. I unplugged many wires and plugged it back again in case it "resets" itself but no luck. Abhishek, how do you reset the timer? Perhaps I should try this.
    Thanks!
    Genius:
  • 1,239 Answers
Hi
i think the timer has to be reset,,and make a hard reset..
than k you............
Posted on Mar 06, 2009
I shorted out the counter lights on my frigidair microwave. The microwave works but not the lights. I've replaced the bulbs. What next?
The metal base may have fused together from electrical arcing when the old bulb was removed. The entire bulb receptacle (socket) will have to replaced. If you cannot do that yourself, the cost would be excessive. Just live without the light as long as the microwave gets the job done.
Dec 10, 2014 | Frigidaire FMV157GB Over-the-Range 1.5 Cu....
My Frigidaire oven model PLMV169DCD has developed a defect
The only real issue with the control board that could cause that is a failing relay or bad connection, both of which I can repair on a control board for $54.95, which includes insured return shipping.
The first thing I would do is test the outlet. A toaster or hair dryer are good devices to use.
A microwave must be on its own breaker, or at least not on the same breaker as a high-current device (stove) or a device that causes spikes on the line (fridge, freezer).
It's possible you have a failing magnetron or high-voltage transformer, but I would need to discuss it to narrow it down.
For free additional DIY help and details, feel free to e-mail me directly from my site. Remind me of your full model number and detailed symptoms.
William E. ("Ed") Miller
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 26, 2017 | Frigidaire PLMV169DC Microwave Oven
THE START BUTTON WILL NOT START THE OVEN, WE HAVE GE-JVM1790
the start button uses carbon pads and they could be worn out or not contacting properly you try and replace the control pads
Jul 26, 2010 | GE JVM1790 1000 Watts Convection /...
How do I unlock the key pad? The display shows locked and I don't know how it locked.
Here you go.
The Child Lock shuts down the control panel pads to prevent
unintended use of the microwave oven.
When the control is locked, only the Vent Fan and Light pads will
function.
To Lock/Unlock Control: The microwave oven and Timer must
be off. Touch and hold START for 5 seconds until 2 tones sound
and a lock icon appears on the display. Repeat to unlock and
remove the lock icon from display.
May 10, 2010 | KitchenAid KHMS155LSS 1000 Watts Microwave...
How do I get to the control panel of my Frigidaire PLMV169DCD?
When you open the microwave door, on the right side should be two philips head screws. Unscrew those to remove plastic cover and there will be control panel behind which is secured with 4 screws.
Jan 05, 2010 | Whirlpool GH7145XF Microwave Oven
The microwave turns on radomly
call kitchenaid
you will need a touch pad and control... touchpad is shoring out causing it to turn on...
hope it helps
Sep 26, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Fan Button doesn't work
HI, in most cases, the button will be fine. there is an error code that will illuminate on the control if the touch pad starts to malfunction(sticking buttons). this is more likely an issue that concerns the integrity of the fan motor. have it tested. replace it if found to be defective.
Jul 21, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169
the internal fuse has blown, if your capable undo the screws on the casing and the check all the fuses
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169DCD
You most likely had a power surge and blew a fuse. First unplug the unit,then remove the top grill. There will either be one screw on top of the control pad or 2 on the left side. open the control panel and look for a fuse that has a ceramic center and replace it with a 20 amp one. You can find these at the hardware store
Frigidaire FMV158FM over the range microwave 1000 watts
everything works on microwave but does not heat
Sep 18, 2008 | Microwave Ovens
Frigidaire PLMV169DC Microwave Oven Logo
857 people viewed this question
Top Frigidaire Microwave Ovens Experts
William Miller
William Miller
Are you a Frigidaire Microwave Oven Expert? Answer questions, earn points and help others
