Question about Kenmore Washing Machines
Washer stopped spinning
Washer will turn on but will not spin. (the bucket does not move)
  • 1,239 Answers
then the tub may be blocked /.....or the belt may be worn,,better to check motor also,
thank you......
Posted on Mar 06, 2009
Washer will fill and drain but will not wash or spin
you have a motor problem. do you hear the motor working? if so it may just be the belt.
Nov 11, 2013 | GE Washing Machines
How can I get my washing machine to spin and empty with bad timer
Emptying the tub is easy, just lower the drain hose into a bucket on the floor, or into a floor drain. If the timer can be operated manually, turn it to spin, then drain after spinning a while. If this is an electronic timer, you will need to remove the clothes and take to a laundromat or a friend's house to spin the water out.
Dec 03, 2009 | Washing Machines
Kenmore 70 washer will not spin in some washing modes
Has this Washer got a drain water filter ? if so check it first. also some washers have a 'delicates' program which leaves water in the drum to stop creasing, check you manual.
Feb 07, 2009 | Kenmore 22422 Top Load Washer
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
Front load washer wont spin
it must drain before it will spin.if water is standing in it .remove power take off frount panel.remove screws that keep pump onthe washer move towards bucket and open pump and clean out.God bless tom
Dec 31, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Cold water will not shut off at end of spin cycle
electriic inlet valve is obstructed, try removing cold water hose direct the hose into a bucket and fill the tub on the warm setting (flushing the cold valve) then try the washer again ..If that doesn't work a new valve is needed
Dec 25, 2008 | Maytag Neptune FAV6800AW Top Load Washer
WM1832CW, wont drain and spin, has LE error, was able to drain water, using spin only function, still would not spin, sounds abnormally, drum is not moving at all. I know LE means motor overload, but what...
This a common problem for all front loaders. Your washer will not drain or work 'cause your outlet filter is clogged or an unusually heavy load. The small door is on the left side front bottom of your washer. Remove the door with a putty knife or thin butter knife inserted in the middle top of the access panel door. Drain the water from the filter housing by pulling the tube out of the clip and unplugging, allow it to run into a bucket while the machine is in spin only mode. This mode is acheived when the washer is first powered on press the spin button until no spin is reached then run. Run in this mode until no water is draining from the tube in the bucket. Keep the tube as low as possible. When water has stopped coming out of the tube turn off the washer and unplug from the wall. This step is important because this resets the fault. Expect some water to come out when you open the filter housing by turning counterclockwise until you can pull the filter from its housing. Clean out your filter, return to housing turning clockwise until seated and recap the tube and place in the holder, refit the cover and plug back into the wall. Fixed. You may also need to lighten the load a bit but I always try full on load anyways. If it fails again just lighten, unplug wait >1 minute then replug and run.
Dec 12, 2008 | LG WM-2077C Front Load Washer
Kenmore top loader washer
check the pump is not obstructed and can turn freely. if it is free then a new pump may be reqd...after you have drained the water out try to put it in the spin mode if it spins ok then there is a good chance it is the pump if it does not spin out then the pipe work to the limit switch may be blocked at the base that is the clear small plastic pipe if this is blocked the machine thinks it is still full of water so it wont spin out if this is clear then your card may be damaged.its a question of elimination hope this helps.
Dec 01, 2007 | Washing Machines
Kenmore Automatic washer -110.24862300
sounds like may be in clutch see if you can help the tub start spinning when trying in spin setting...if trying to turn or turns some and stops most likey clutch slipping
Sep 02, 2007 | Kenmore 22422 Top Load Washer
Washing Machines Logo
16 people viewed this question
Sal De
 Brian Main
Brian Main
