Question about Hotpoint Aquarius WF000 Front Load Washer
Hotpoint WT740 Error Code F-08
Can anyone offer a solution?
  • paddyd63 Mar 11, 2009
    Hi machine goes through wash cycle - and then when it starts rinse program the error code F-08 appears - drum is hot, however water has drained and it doesn't finish the whole cycle
  • chunky113 May 11, 2010
    Whats the problem?
  • 74 Answers
SOURCE: have a hotpoint wt761 washing
http://www.recommendedbuys.co.uk/household-appliances/washing-machines/hotpoint-wt761.htm
as you can read in these site that is a grate problem with the model allso the company tech is talking about to chage the machine insted repair so all I can say is that you have problem with the computer board of the machine,,,,good luck and rate me
Posted on Jan 01, 2008
  • 5 Answers
SOURCE: Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Posted on Apr 16, 2008
jonniewalker
  • 1031 Answers
SOURCE: hotpoint washing machine WF860 F-08
F08 error code: for hot point washing machine indicates Heater control or NTC (Thermistor) temperature sensor problem.
hope this helps
Posted on Sep 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Hotpoint Aquarius WT740 Fault Code
Hi. F05 means pressure switch jammed on full.
Check pump for blockage and that it is working, if no joy you will have to call an engineer
Posted on Nov 20, 2008
SOURCE: hotpoint wt761 error code f-08
call in hotpoint
Posted on Oct 07, 2009
Testimonial: "a"
Hotpoint wt740. When starting a wash cycle the machine tries to fill but shows the H20 code and the water goes straight out of the drain tube (it appears to have normal pressure and flow rate).
Indesit (Hotpoint, Ariston) Error code H20
(Quote)'If the machine is not in the demo mode and this error is displayed it means there is no water being supplied to the machine.
To cancel press and hold start/cancel then press again to cancel the drain and the machine should now be reset and display 'ON' as usual.'(unquote)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 04, 2011 | Washing Machines
I have a code on the display f-08
hotpoint washing machine WT740 1400 code erroe F-08 flashing machine stops working after 20 minutes please help
Jan 19, 2011 | Hotpoint Aquarius WD640 Front Load...
Error code f-08
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Hope this helps.
Dec 13, 2009 | Washing Machines
The start button on my hotpoint wt740 washing machine wont click on.
Hotpoint had a problem with a control panel design where if the start button is pushed too hard, it snaps off the panel. This is most likely cause but it might be a faulty door lock.
Dec 09, 2009 | Hotpoint Washing Machines
Fault code stopping washer from working
My washing machine will not spin and in fact turn around at all, i did a wash earlier and it was making a funny noise...like some thing was caught in the drum. It is about 3 years old....It does still fill with water thou!
May 24, 2009 | Ariston Technologies Washing Machines
Hotpoint Aquarius WT740 Fault Code F-05. What does this mean?
Nov 18, 2008 | Washing Machines
Hotpoint washing machine WF860 F-08 error, does anyone know how to fix this
hope this helps
Sep 29, 2008 | Hotpoint Washing Machines
Hotpoint error f10 on model wt740
F10 us usually a stuck key on the keypad. Turn the power off to the machine or kick the breaker off, press each button a number of times to make sure they are not sticking. If you find one sticking try to pop it out. Turn the power back on and try to use it. If the f-10 code returns you will need a new touchpad. Good luck to you and I hope this helped you. Mike Anderson
May 08, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius WF000 Front Load Washer Logo
475 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
