Question about Weber Spirit? E-310 Propane Grill
The temp/flame on my weber grill won't get hotter
No matter what the flow of gas is and no matter what setting the control is on the temp won't get above 200 degrees
  • jjcyr Mar 15, 2009
    Mine only gets too about 300
  • 24 Answers
Check the excess flow safety device, which is part if the barbeque to cylinder connection, may have activated. To reset the excess flow safety device turn all burner control knobs and the cylinder valve off.
Disconnect the regulator from the cylinder. Turn burner control knobs to high. Wait at least 1 minute . Turn burner control knobs OFF. Reconnect the regulator to the cylinder. turn cylinder valve slowly.
Posted on May 24, 2009
Weber genesis silver B won't get hotter than 450
Yes diaphram could be split causing vent to pass gas .
Aug 08, 2012 | Weber Genesis Silver B Grill
My weber grill doesn't seem to be getting enough gas thruogh the jet to heat to proper temp.
The most likely problem is that food drippings have clogged some of the pin-hole gas outlets in the burner tubes. If those are clean and open, then either your propane tank is not releasing the gas or the controls on the grill are not releasing the gas. If you look at the flame level, probably best done with the flavorizer bars removed, and they are all the same with the controls on high, then it it probably the tank valve. If the flame heights are different, the lower one(s) are the ones where the control valve(s) are not working and need to be replaced. Good luck!
Jul 25, 2011 | Weber Genesis Silver C Grill
Can a weber summit s-440 built in grill that is natural gas be switched to a propane?
The easy answer is yes. Unfortuantely Weber no longer sells conversion kits, even to me, and I am an authorized Weber waranty service company. The only thing you can do is try and find a competant grill company in your area who has the expertise to buy the correct orifices and then the expertixe to drill them out to the correct size for LP gas. NG orifices are to large and will give you wild, uncontrollable flames if just hook the grill up to LP. LP orifices are smaller because LP gas burns hotter.
Jun 21, 2011 | Weber Summit S-440 Gas Grill
Burner flames don't get hot, like not enough gas.
Try this, Turn off the tank. Disconnect it. Reconnect it. Turn tank valve back on very slowly and then see if you get bigger flame size.
May 15, 2010 | Weber Genesis Silver B Grill
Low flame
Next time you use the grill turn the gas on slowly. For some unknown reason when turned on quickly the regulator reduces the gas flow.
Another problem with some gas fittings is an auto shutoff if detects the slightest leak. Sometimes the shutoff is not 100% and allows a small amount of gas causing the weak flame.
Apr 27, 2010 | Weber Genesis Silver B Grill
Temperature will not reach past 180 degrees
you may need a grill clean or you need to adjust the air flow to your burners
Apr 20, 2010 | Weber Genesis Gold B Grill
Flame is low
try opening the tanks slower so the overfill protection device in the tank won't kick in and restrict the gas flow.
Nov 10, 2009 | Weber Genesis Silver A Grill
My weber Baby Q grill has a low flame.
Agree with rjmbridge. I called the Weber support people and was told that there is a built in safety feature on the regulator that will cause the flame to burn at a low setting if the gas within the extension tube to the large tank and regulator is not allowed enough time to equalize. They suggested turning on the gas from the tank very slowly, allow about 2 minutes with the temperature control knob turned off, then turn the temp knob on and light. This worked for me.
May 27, 2008 | Weber Baby Q Grill
Weber Spirit? E-310  Propane Grill Logo
1,162 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
