Player doesn't display the music that is synced on it
Every time I sync music to this device, when I try to find the music on the player it self, it says list is empty. If I go to windows explorer and look directly on the device, I see that all of my music is there. I have tried deleting all music off and copying it back on, also deleted all the music off, and synced the music back on with no success.
    Genius:
  • 1,550 Answers
Maybe you don´t get the right format on the music you put on your device sometimes you need to convert the music archives to mp3 before you put in
Posted on Mar 06, 2009
Where can i get a sofware for my ifp-390 so i can put music from my compurter?
to load music onto your iRiver iFP-390T, simply open windows media player then follow the following steps
  1. Start the Player, turn on your device, and then connect it to your computer. If prompted, select the AutoPlay option to sync the device using Windows Media Player.
  2. Do one of the following:
    • If the Player has selected to sync your device automatically, click Finish. When you do so, the Player will sync your entire library to your device. After that, your device will automatically sync every time you connect it to your computer while Windows Media Player is running.
    • If the Player has selected to sync your device manually, click Finish. Then, in the Sync tab, you can select the files and playlists you want to sync manually.
Jan 10, 2011 | iRiver iFP-390T MP3 Player
Trying to syn music to my mp3 insignia
It may not be anything you are doing wrong. You will have to see how your player is seen buy your computer. Go to your control panel -> System -> device manager --> Look for your player there, does it show up as a Portable Device? NOTE: The player should show up on the Device Manager's right pane as:
1. USB Mass Storage device (if the player is set to MSC)
2. Portable Device (if the player is set to MTP mode.)
It should sync with Media player if it shows up as a Portable device - but if it shows up as a Mass storage device all you have to do is drag and drop what you want into the right folder on the player.
Apr 29, 2010 | Insignia Kix MP3 Player
Bought a gpx8gb digital media player for my daughter for christmas. I have downloaded her cd's into itunes library. Now how do I get those songs onto her media player?
Check to see that when you rip a music CD that your music is not copy protected. The RIP function in your Windows Media Player will allow you to convert the music CDs you have purchased into either an MP3 or a WMA format.
To adjust the copy protection setting on your ripped music files,
  1. Open the Tools tab at the top of your Windows Media Player.
  2. Select Options and then select the Rip Music tab.
  3. Choose the type of music file as well as the quality with which you would like to save the music. (Your GPX player has the ability to play music files in both the MP3 and WMA format.)
  4. Make sure to use MTP when transferring copy protected WMA files.
If you are using Windows Vista with Windows Media Player 11, you will need to follow these instructions.
Note: You will be able to download purchased/subscribed songs to the unit.
  1. Start Windows Media Player 11 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In Device Setup - Configure Sync, write a name for your mp3 player.
  3. Click Finish. The window closes and the Sync feature in the Player is displayed.
  4. From the left pane of this Sync feature, you can select from Playlists or Library and you will see the content of these folders in the center pane.
  5. Select the songs or entire albums from the center pane.
  6. Drag these songs or albums into the Sync List, which is the right pane of the Sync feature.
  7. Click the Start Sync button on the Sync List pane.
  8. Repeat steps 4-7 for any other items that you want to copy to your unit.
If you are using Windows XP with Windows Media Player 10, you will need to follow these instructions.
  1. Start Windows Media Player 10 and then connect your unit to your computer. If you have not set up synchronization between your computer and this device, the Device Setup Wizard starts.
  2. In the Device Setup Wizard, select Manual.
  3. Click Finish. The wizard closes and the Sync feature in the Player is displayed.
  4. Select the Library option. On the left pane select Sync List.
  5. From the left pane you can select All Music or My Playlists and you will see the songs located within these folders in the center pane.
  6. Select the songs from the center pane, and drag them to the Sync List.
  9. Good Luck, I hope this helps
  10. Please rate me, Thank you
Dec 09, 2009 | GPX MW3836 MP3 Player
No database msg displayer for my NW-E005F mp3 player
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the manufacturer?s website. Make sure that you back your music up first because when you do this you are setting it back to factory settings. then, If you have a large playlist to transfer, you may prefer to do it from your media player, such as Windows Media Player. Once your MP3 player is connected to the computer, open Windows Media Player. Click on the "Sync Music" tab. Drag songs that you want from your Windows Media Library over to the "Sync Music" column to create a playlist. Click the "Begin Sync" tab at the bottom once you have all of the songs on your playlist. This action will sync all of the songs to your MP3 player with one click. Disconnect your device once songs have been transferred by clicking on the "Safely Remove Hardware" icon in the bottom-right side of the desktop tray.
Oct 26, 2009 | Sony Network Walkman NW-E005 MP3 Player
Music is syncing to my ipod from media player
Don't use window media player as that will sync the music files as WMA which is not playable on you device.Use itunes and inport tracks and then sync.
Apr 18, 2009 | Apple iPod touch
HAVE AN IRIVER E10. CANNOT SYNC SONGS USING WINDOW MEDIA PLAYER.
I can only guess that you are using windows media player to sync. So, just use the iriver program or open 'my computer', click onto iriver device icon, and paste in music.
Mar 12, 2009 | iRiver E10 Digital Media Player
Sync Music
try looking for certain folders in the sansa that say things like "MY music" or "go list" if they're not in their try syncing using windows media player
Apr 19, 2008 | SanDisk Sansa e200 MP3 Player
Unable to sync music
What happened when you tried to sync? it could be a device certificate error...what i would recommend you to do is to sync using your windows media player...assuming that you have windows media player 11...open up your windows media player and click on sync..then you can drag the tracks you want to sync and then click on start sync...if you are not able to transfer the songs to it..use a song that is not from yahoo like the sample one that came with your computer and see what happen...if that doesnt solve the problem check your usb mode..it should be under MTP mode or auto....then open up your windows media player and format the device there...after you have done that..that should solve the problem you are having..let me know what the outcome is....
Jan 06, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Pearl mp3
This question is listed under the wrong device, but:
Here's what happened: When you first synced your player to Windows Media Player, you may have set up the automatic sync option. When this option is selected, Windows Media Player will add EVERY song, picture, etc from your Library on your computer to the player. Now, every time you sync you device, it adds every new file from your computer into the player automatically. It will even delete songs from your player that were on there before.
Go into Windows Media Player 11 with your player connected to the computer (it will automatically sync and add new files one last time), move the mouse cursor over to the sync tab; a small black arrow will appear under the word "Sync"; click on the small black arrow and a dropdown menu will appear; select "Portable media device" from the dropdown menu, and another dropdown menu will appear; select "Set Up sync"; a window will appear with some information on your device - uncheck the box that says "Sync this device automatically"; click Finish; This will eliminate the problem of Windows always adding/deleting songs/files you don't want into your player.
-Tha Mp3 Doctor
Dec 27, 2007 | Philips GoGear SA178 MP3 Player
When I sync files to My mp3 player, it says "no file" when I diconnect.
I unchecked in the advanced sync setting the box to have windows media player create the drive hierarchy. Then I deleted all files on the player and did the sync again. This time only the mp3 files get written.
Jan 28, 2007 | iClick DMP 7.0 MP3 Player
202 people viewed this question
 Grubhead
Grubhead
