Question about Radio Communications
I have a set of sylvania 2 way radios which came with rechargable AAA batteries(Peaceboy 550 mah, 1.2v Nimh). These batteries no longer charge, so I purchased AAA rechargable Nimh batteries to replace them, but they don't work, and I'm not sure why.
vrc_tech
  • 109 Answers
SOURCE: Batteries won't charge on new cobra 2VP 270 radios
If radios are brand new then I would take them back to the store for warranty exchange. The other opton is to vist a local radio service center and ask the tech to jump the battery. if the battery falls below a certain voltage it might need a quick jump sart from a power supply with a higher voltage normally 12 volts works well...
Posted on Aug 20, 2008
beergut707
  • 79 Answers
SOURCE: initial charging time
hi there
the first charge should be around 12 hours, this then teaches the battery its max load.
ignore the charger if tells you its charged after a couple of hours.
after the first charge use as normal.
hope this helps
beergut707
Posted on Oct 09, 2008
  • 157 Answers
SOURCE: Midland rechargeable battery packs won't recharge and vibrate
Hello batterbum, from the info you listed you have the right battiers & charger, with alkaline the radios work leads to wrong or a bad batch of Ni-MH battiers. Vibrations from a battery pack states too much current being drawn for battery capacity. Note: depleting a battery and recharging with a charger will place the battery in a false full charge state. Recharging a depleted battery with a DC power supply with current limit can reboot the battery to a 90% cycle. I suggest returning battiers for correct replacements, if they are correct 'by the book' ask for the highest in mAhr specs. Please inform me of your outcome. Good Luck
Posted on Nov 07, 2008
SOURCE: Re: Tevion Sound Wireless Headphones
CHARGE THE NEW AKUS IN ANOTHER CHARGER AND THEN USE THEM AS USUALY.
SEE THE CURENT SUPPORTED BY THE ORIGINAL GHARGER,
IF IT IS AT LEAST 100mA , IT SHOULD CHARGE YOUR NEW AKU ! BUT MAYBE THE CIRCUIT INSIDE TX DO NOT SUPPORT
AKUS BIGGER THAN 500mAh .
YOU SHOULD RESPECT THE SPECIFICATIONS GIVEN BY THE PRODUCER AND IT WILL BE OK !
Posted on Apr 19, 2010
  • 333 Answers
SOURCE: I have a problem with power on Olympus SP-550UZ
Try using regular batteries. I did with my camera and seems I can go a lot longer on the regular batteries verses the re-chargable ones
Posted on May 16, 2010
I am wondering if anyone could help me please, i have bought some 2600 mAh AAA batteries for my video camera. I was wondering what kind of battery charger i would need to get to recharge these batteries?...
You dont need anything very advanced. 2600 is a nice high capacity for Ni-MH AA's and 1100 is really high capacity for AAA's. Here is a little panasonic charger that would do the job just fine.
Panasonic BQ CC17SBA eneloop Advanced Individual Battery Charger with 4...
Jan 30, 2015 | Cameras
I need a new battery (BP-HP550-1 1/2.4V 550mAh) for my sony headset. Regular batteries will work (non-rechargeables and rechargeables) but I found that the cradle will not recharge the rechargables only...
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make them work in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
NOTE: I am not an electronics expert so I do not know if there would be any problem using other rechargeable AAA batteries (with higher mAh ratings). So I decided to be safe than sorry and ordered the 550 mAh batteries through Ebay.
Nov 01, 2010 | Sony MDR-RF960RK Consumer Headset
Will this charge 2450 mah battery?
Yes, this will charge any AA-AAA Batteries. Typical charge will be about 14 to 18 hours
Oct 01, 2010 | Duracell AAA NiMH Battery Charger with 4...
I need ni-cad battery specifications for Acoustic Research AW-721 headphones. I bought replacement ni-cads but they don't charge when the headphones are placed on the headphone cradle/charger.
The AR AW721 headphones require 3 AAA NiMH batteries, not Ni-Cad. The original batteries are 1.2 volt, 550 mAh. I replaced mine with Energizer 850 mAh AAA batteries, which work well and actually last longer per charge than the originals.
Sep 20, 2010 | Acoustic Research AW-721 Consumer...
Sony batteries BP-HP550
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 27, 2010 | Sony MDR-RF960RK Consumer Headset
Where can i buy a sony battery bp-hp550 1 1/2 4v
Even though you can use regular AAA batteries (that you would have to replace often), there is a huge convenience factor with using the charging cradle that comes with the Sony headset. A solution I found was that I ordered some 550 mAh AAA batteries through Ebay (they came from England and cost me $8 total for four batteries). To make the charging cradle work with the new batteries installed in the Sony headset you MUST use the bottom part of the plastic battery holder piece (all you need to do is peel off the BP-HP550-11 label and the bottom half of the plastic battery holder piece slips off of the Sony batteries). Then just slip in the new AAA batteries into the plastic battery holder bottom and then insert into the headset. The reason why you must use the bottom of the battery holder plastic piece is because the plastic piece pushes on a little switch. This switch activates the charging mechanism to enable the cradle charger to charge the batteries.
Jul 11, 2010 | Sony MDR-RF960RK Consumer Headset
May 16, 2010 | Olympus SP-550 UZ Digital Camera
I bought KODAK NiMH 2400 mAh and it isn't rechargeable when I recharge it it jus work for few minutes.
NiMH tends to have a "memory". What this means is that the batteries will get used to being only charged and discharged a certain amount. What could be happening is that the battery THINKS it is charged when it is not... or.. it THINKS it is discharged when it is not. You can try to recondition them:
  1. Charge them
  2. reset the charger and charge again
  3. put them in your device and drain them
  4. let them sit, drain them again
  5. recharge them
  6. drain them again
Do this a few times. If you don't notice an improvement, you may want to consider getting a new set of batteries - I would recommend lithium rechargeables.
Jul 11, 2009 | Duracell NiMH AA/AAA Battery Charger with...
Radio Communications Logo
56 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
