Question about Norcent Technologies LM-760 17 in. Flat Panel LCD Monitor
Monitor is very dim until warmed up
Norcent LM762 16 '' monitor is very dim until warmed up New bulbs needed? Where can I get replacement with instructions?
  • 741 Answers
Well LCD monitors don't have bulbs, per say. They have two tubes called inverters that supply a backlight. They are on each side of the monitor, about 8 inches long and pencil thin. You can buy them off of the Internet on sites like NewEgg if you are experienced in electricity. Otherwise, it would probably be best bringing it to a shop or to the manufacturer to get it checked out. Reason I say that is when monitors have problems they are reverse of what you are experiencing. They start bright and dim versus start dim then bright. If the inverters are bad then you get no light at all, as opposed to dim then to light. But it is a very high quality monitor and you should not be having any problems..finally there are other little things that can cause it, for instance I have a monitor that is always dim and I have to press the keyboard arrow keys from dim to bright each time. Its a faulty keyboard not monitor..So nothing major on your monitor but it would be worth it to have someone at least ensure you it is working correctly. Good Luck. Please rate this solution.
Posted on Mar 06, 2009
    Genius:
  • 1,550 Answers
Maybe you got some capacitors dried on your monitor
Xl 2400 replacement bulb---dim after replacement
did you use a genuine sony replacement bulb or aftermarket? Often the aftermarket lamps are not up to par with the OEM versions.
Nov 01, 2012 | Televison & Video
HP Laserjet 3330. Scanner bulb warming up doesn't go away. I have done the "solution 1" as discribte but nothing is happening. It goes like: - i put the power on, hewlett packard is flashing, the...
How does the bulb look? Is it bright or kind of dim. The bulb warming error is designed to halt use of the machine until the scanner bulb reaches the correct output level. As these are basically a flourescent tube, they will dim over time and at a certain point they will not generate enough light to enable proper scanning. If the bulb is dim, it will require replacement.
Mar 14, 2011 | Office Equipment & Supplies
My OCD LOCKED keeps popping up on my LM-965W Norcent LCD display how do I fix it. I have no manual or instruction book.
I am having about the same problem with my monitor. The solution I was given, was to take my monitor to a repair shop and have them mess with the rubber behind the buttons, because they are sticking. Or save your $ and do it yourself.
Jul 13, 2010 | Norcent Technologies LM-965W 19" LCD...
The tv has dimmed suddenly and the yellow color is almost completely gone. I have reset the color with no luck. Can I replace a bulb to fix this? If so, where can they be purchased?
Not something you can replace yourself - your LCD uses a backlight - sounds like a bad circuit board - not really a backlight problem.
Try unplugging your unit for 10 minutes, plug it back in and see if that solves the problem otherwise you will need to get it repaired or buy a new one - don't attempt to open or repair yourself there are sensitive electronics inside.
Oct 07, 2009 | Norcent Technologies LT-2025W 20 in. LCD...
Sumsung 930b goes dim,and flickers after about 3 min.
This sounds like the inverter has gone bad. If the bulb were bad only, you would see a faint image on the screen with a flashlight.
The problem is on this monitor, it will probably cost about $100 or so to take it to a shop to get it fixed, and that is nearing the cost of a new monitor.
If you are a little bit handy, and can disassemble the monitor, you can replace the inverter. The hardest thing about this, is getting the monitor faceplate open. Just use something firm and softer, such as a nylon spudger (this is something you can find online) or you can carefully use a thin scredriver. You just have to be careful, those cases are really tight.
Here is a good guide for general ideas on how it is done.
http://www.instructables.com/id/Replace-LCD-Backlight-Inverter-on-Any-Monitor-for-/
Paul
Apr 09, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
How to Change the headlight bulbs for my 1992 Buick Regal
A torque bit screw driver are a philips screw driver should be all you need. JUST MAKE SURE NOT THE TOUCH THE BULB (new bulb) WITH YOUR FINGERS. Your body oil will make the bulb burn out quick!!!! Wear rubber gloves when installing the new bulb. f one is dim, you better change both sides. are the other side will also be dim.
Feb 06, 2009 | 1992 Buick Regal
Norcent Monitor problem
yea just let it work i mean when it says auto config it means its adjusting monitor settings accordingly to your hardware nd display so just stay back and wait until it does
Sep 02, 2008 | Norcent Technologies Computers & Internet
Dim screen on a flat panel monitor
the LCD has gone dimmer, is there a way I can find new LCD to replace the old LCD on SGI 1600SW? Preferably new LCD like Apple imac glossy or Matted screen.
Nov 09, 2007 | Computers & Internet
Monitor stays dim
Chances are it's not the actual CFL back-light bulbs themselves, but the back-light inverter board. If it was the bulbs you would have not had the "warm up and it get bright" issue. The board IS replaceable, (as well as the bulbs) ViewSonic charges about $36.00 USD for the board when they have them in stock. (out of stock as of yesterday 11/14/2006) It should be covered under warranty if you got longer than one year. (I know the warranty was only one year on MY VA800 but I have seen longer offered since i got mine) Good Luck I hope this helps! El Duderino
Nov 11, 2006 | ViewSonic VA721 17" LCD Monitor
Norcent Technologies LM-760 17 in. Flat Panel LCD Monitor Logo
299 people viewed this question
Top Norcent Technologies Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Piyal Perera
Piyal Perera
Brandon Murphy
Are you a Norcent Technologies Computer and Internet Expert? Answer questions, earn points and help others
