Question about Sharp AL 1631 Copier
Sharp AL1631- Paper will not feed through
When we make a copy code P comes up. When we open the drawer sometimes paper will be stuck and sometimes it won't. If paper does feed through we will sometimes here a noise.
Please advise
  • foxmachineof Mar 06, 2009
    Also when we use the document feeder copies come out with a line on them
  • 29 Answers
Black lines in the feeder but not on the glass- means there is some dirt on the **** glass just clean this glass on the right side of the main glass and the line will go away , if it does not go away u must clean the optics , p jams can be fixed buy cleaning the moon paper feed rollers inside the paper draw but replacing them would be better, this is a 20 minute jod and should cost no more than $120.00 remmeber this copier toner until can be refilled for $6 and is one of the only units left that can be so keep it. this copier is worth fixing
Posted on Mar 09, 2009
    Scholar:
  • 136 Answers
First off I seen these problems so many many times as an sharp dealer, I think I may drop the support however, the reason why your are getting the misfeed is beacuse your paper feed tires are worn and need replacing, r u in Ct f so we can helpif not call your indepenant dealer , remember Staples will not support this machine, and tell him your paper feed tires are bad and needs replacing
the Noise could be anything let's fix one problem at a time ok.
Posted on Mar 08, 2009
Sharp calculator EL-1197P III paper feed stuck
Hi
I trust you are well.
This might be trivial however when you replace your paper roll the edge of the edge paper must be cut straight otherwise the paper will not feed correctly.
Hope this solution is as easy as that, If not open the claculator paper feed compartment and check the gear mechanism for chipped teeth or foreign objects stuck inside.
Hope this helps you
Kind regards
Aug 15, 2014 | Sharp EL-1197PIII Calculator 12-Digit...
Problem with the Konica Minolta bizhub C450P Laser Printer Bizhub C450 error (C-0212) , HOW TO FIX IT?? PLEASE GIVE ME THE FIX STEP!! TKS!!!!!
This code is for LCT (Large Capacity Tray) lock release failure. This means there is a problem with the LCT, usually the large paper drawer at the bottom. This code is usually reset by opening then closing the front door. Sometimes turning off then on the main power switch on the right side will clear it. Try releasing the LCT and get it open. Then check the paper in the tray. Most of the time when there are problems with these LCT's it is because too much paper has been loaded or it has been loaded improperly. If you get it open, remove all paper. Then load smaller amounts of paper at a time to insure that it is loaded perfectly. Only load the tray half full at first and then close the drawer and allow it to lift. Then make a copy from that drawer to be sure it feeds paper. Then release the drawer again and finish loading if you want. If you continue to have the code then you can leave the drawer open an inch or so to de-activate it so you can still use the printer from the other drawers until you can get a technician out ot service it.
Good Luck and Thank You for using Fixya.
Wheatland Services
Feb 16, 2011 | Konica Minolta bizhub C450P Laser Printer
Can't get top feed to sense paper and copy, it will copy from bottom
the reason for this could be that you have run the feed tires and seperation tires bald by only using the upper paper tray. i would suggest getting the feed tires replaced and that should fix the problem. you might also check behind the paper drawer to make sure that a piece of paper did jam and get shoved up behind the drawer and is keeping it from working
Jun 11, 2010 | Sharp Office Equipment & Supplies
Kyocera mita j11 error code
On most Kyocera Mita copiers a J-11 code indicates a possible paper jam when paper is being fed from drawer #1, but sometimes a J-11 will be indicated when the paper fails to feed from the drawer. Check the paper stops and paper guides in the drawer and make sure that they are flush against the paper, also cleaning the paper feed and pick-up rollers with a rag dampened with just plain water will help sometimes unless the rollers are completely worn out. If all this doesn't help you may have a paper feed clutch or lift motor that has failed.
Sep 18, 2009 | Kyocera Mita Office Equipment & Supplies
SF2030...post transfer, flat jam ... symptom occurs between 1-15 copies ... not consistant ... in addition when theexit switch is activated during the copy cycle, a jam is not indicated #!@?
FYI... The copier will show a jam for 3 reasons. 1 Paper never got to the sensor, 2 Sensor sees paper there all the time or 3 Paper doesn't arrive at the right time. Alot of times paper feed rollers are dirty or worn, often ignored and overlooked, and these will give intermittant jams that show up anywhere in the paper path, often looking like a differant problem. Sometimes sensors are dirty with paper dust and will show a jam when there isn't one, in which case a can of compressed air is good to blow them out. Question, is this jamming out of all drawers and bypass or just one drawer. This would help in eliminating possibilities. Good luck, let me know if you have more questions. Please rate this. Thanks
Jul 01, 2009 | Sharp Office Equipment & Supplies
Paper drawer is stuck open?
there is a piece of paper stuck behind the paper drawer, remove the drawer and then look inside, also open side panel and you may be able to see part of the paper there also .
http://www.websitetoolbox.com/mb/copierquestions
Jan 27, 2009 | Ricoh Aficio 1027 All-In-One Laser Printer
Sharp copier al1631 , putin new toner sometimes shows CH
the drum might not be rotating due to either the drum gear is wornout or the drum drive gear on the machine main drive unitis wornout.
Nov 26, 2008 | Sharp AL 1631 Copier
Copier jamming
One of your feed tires or rollers may have come off or be worn out. You may also have paper stuck behind one of the drawers, does it do this out of all the drawers?
Oct 23, 2008 | Canon imageRUNNER 210S Copier
Can not copy from tray/drawer, but get copy from multi-bypass tray
Regular copy paper that I got from the Staples. Same paper in the paper tray/drawer as in the multi-bypass tray. Thanks.
Jun 25, 2008 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
171 people viewed this question
Top Sharp Office Equipment & Supplies Experts
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
