When cleaning my print nozzles a message apears stating my waste ink absorber if almost full. How do I correct this problem?
  • virgilrueck Mar 07, 2009
    I have a Canon iP3000 printer. Recently, when I was cleaning my nozzles in the color cartridges, a message appeared, stating that my waste ink absorber was almost full. I need to have someone tell me what I need to do to get rid of this excess ink, so that I don't have to keep pushing the reset button.
    Brigadier General:
  • 8,619 Answers
Hi
First try to reset :
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not,
press the Power button once more.
8. Your printer should respond as normal.
Also check for the two small pads (oval, about 3/8 x 1 inch)under where the ink cartridges sit. They might be grundgy, take them out, try to clean them with a kleenex, also clean out the slot that they sit in.
The waste pad can also be washed out with repeated warm water, dried over night and refitted . It depends on your DIY skills in getting to it, and then replace the pads
For sure that'll do the job..
Please revert for any clarifications.
Thanks
Rylee
Posted on Mar 07, 2009
    Scholar:
  • 73 Answers
According to the service manual
See page 5 by the bottom.
You need to replace the bottom case unit / and or the ink absorbers. Part numbers are listed in service manual.
I hope this helps you out.
  • 583 Answers
Here this step by step to resetting waste ink counter printer Canon Pixma ip 3000
1. You will include printer.
2. press button MENU, then SCAN, COPY and again SCAN - they entered into the service regime.
3. select NVRAM ACCESS and further BY OK.
4. select SET Abs- m level and advance value equal to zero.
5. select SET Abs- r level (if there is) and also you will establish into zero.
6. you will turn off printer by button POWER
if this does not solvbes then its quite necessary that the waste ink absorber needs to be removed and replaced with new absorber.contact local printer repair shop or local printer dealer for the new absober.
  • 13,433 Answers
The waste ink tank would need to be cleaned or replaced and then the waste ink counter should be reset, the manufacturer offers this service.
Posted on Mar 06, 2009
    Genius:
  • 1,550 Answers
You need to reset the counter . what is your model ?
  • SAM ANDERSON Mar 07, 2009
    You can find two small pads (oval, about 3/8 x 1 inch)under where the ink
    cartridges sit. It will be in bad condition ,Take them out clean it with
    a kleenex, clean out the slot that they sit in, and replace the pads.
    Reset procedure after replacing the pads
    1) With the printer power turned off, while pressing the
    Resume/Cancel button, press and hold the Power button. (DO NOT release
    the buttons. The LED lights in
    green to indicate that a function is selectable.)
    2) While holding the Power button, release the Resume/Cancel button. (DO NOT release the Power button.)
    3)
    While holding the Power button, press the Resume/Cancel button 2 times,
    and then release both the Power and Resume/Cancel buttons. (Each time
    the
    Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
    4) When the LED lights in green, press the Resume/Cancel button 4 times (Each time
    the Resume/Cancel button is pressed, the LED lights alternately in orange and green, starting with orange.)
    5)
    After the function (menu) is selected, press the Power button. The LED
    lights in green, and the selected function is performed. (When the
    operation completes,
    the printer returns to the menu selection mode automatically.)
Why does it indicate error: ink box full and won't detect the black ink cartridge even when the cartridge is full?
The ink box full message on an ink jet printer means that the waste ink absorber counter has reached the preset limit. When the printer does a cleaning cycle or recharges the nozzles when a new cartridge is installed, the excess ink is left on these sponges. Using the printer after this point may lead to ink spilling out of the printer. The ink absorbers are usually at the bottom of the printer and difficult to reach. (They can be cleaned if the printer is disassembled. However, this is messy and you have to make sure to reassemble the printer correctly. Then there may be a way to reset the counter.) Unless the printer is still under warranty, it is probably better to replace the unit.
The printer probably can't run the cleaning step to flush the ink from the new cartridge to the nozzles unless the waste ink counter is reset. That's why it doesn't register that there is a new black cartridge.
I wish that I had better news for you.
Apr 29, 2015 | Office Equipment & Supplies
Canon pixma ip8500, on third print head in about 4 years. will not print yellow despite repeated head cleaning cycles, now waste ink absorber is full. need instructions for emptying/replacing said...
the waste ink absorber cannot be replaced mate. you have to buy new printer.the waste ink absorber is the sponge part where head cleans all its ink. its a common problem in cannon.
Oct 01, 2010 | Canon PIXMA iP8500 InkJet Photo Printer
I own a canon w8200 pigment large format printer. I replaced two cartridges, Magenta and Yellow. The printer did a nozzle check that seemed to take too long. I then received a 'waste ink tank full'...
<Remedy>
1.Waste ink absorber
Use SERVICE MODE>COUNTER>PRINTER>W-INK to check the waste ink
absorber. Replace if the waste ink level is near the limit (14400).
After replacing the tank, perform SERVICE MODE>INITIALIZE>W-INK.
Apr 04, 2010 | Canon IMAGEPROGRAF IPF8000 InkJet Plotter...
Message" waste ink absorber"
There is an absorbent sponge in the bottom of your waste ink container to help contain the waste ink your printer generates when it cleans the print head nozzles. That sponge is probably full and has triggered a "most informative" error message!
Check your user's manual about the procedure for changing the absorber and where to buy new ones.
Dec 01, 2009 | Canon PIXMA MP150 All-In-One InkJet...
I have cleaned the waste ink resavoir but I keep getting the message that it is almost full. How can I reset it?
HI ...
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible by pressing the <Resume> button on the printer. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. We are aware that there are many "do-it-yourself" Web sites that offer instructions for making this repair. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset. Be aware that if you attempt this procedure, it is at your own risk.
Please vote if this helps .... cheers :)
Aug 07, 2009 | Canon PIXMA iP1600 Printer
Waste Ink near full shows on screen. Won't print!
Hi ...
Cannon Pixma MP780 have an absorber and this error is related to this absorber.
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <Stop/Reset> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Canon recommends having the printer serviced before the absorber becomes full. Replacing the ink absorber is a complicated and potentially messy procedure. Even if the ink absorber is successfully changed, the ink absorber counter must be reset.
I would suggest that you take your printer to the nearest cannon service centre and get it repaired.
Don't forget to vote if this helps ... Cheers :)
Jul 17, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Canon i550-turn on-orange/green 8x then long green
From the Canon website:
Issue: Alarm / Power light flashes orange 8 times consecutively (Waste Ink Nearly Full Error)
Solution: Ink Absorber Replacement Options i550
For the Waste Tank Reset Code, and how to repair or replace the Waste Tank, see this website:
http://www.bioscomputers.ca/CanonWasteTankCodes.htm
Jul 16, 2009 | Canon BubbleJet i550 InkJet Printer
Waste ink absorber almost full. What do I do?
Hi ...
Please vote if this helps ... Cheers :)
May 04, 2009 | Canon I960 InkJet Photo Printer
The waste ink absorver is almost full
It's time to replace 3's WASTE INK ABSORBER KIT & reset waste ink counter.
You have to send it to your nearest service centre to do the service job.
The WASTE INK ABSORBER KIT is approx. USD10/pcs
Jan 23, 2009 | Canon PIXMA iP90 InkJet Printer
Waste tank absorber is almost full ~ message
This printer has an ink absorber that takes in ink during the printing and print head cleaning processes. The cleaning process is necessary in order to keep the print head nozzles from becoming clogged. Over the life of the printer, the amount of ink that the ink absorber has absorbed is calculated by the printer. Eventually, after substantial use, the printer will enter an error condition when the ink absorber is nearly full. At this point, printing is still possible. Press the <OK> button to cancel the error. You will still be able to print for a short period. To protect the printer from damage, you will not be able to print at all once the ink absorber is full.
Personally, I wouldn't do it myself, I'd inquire w/ Canon about how much it would cost to have it done first...
Maggie B
Feb 10, 2008 | Canon PIXMA MP530 All-In-One InkJet...
16 people viewed this question
jasbo
jasbo
