Question about Whirlpool Washing Machines
WASHER WILL NOT DRAIN IT GETS TO A POINT IN THE CYCLE WHERE IT STOPS AND SHOWS FP CAN ANYONE HELP I LIVE IN FRANCE AND SERVICE HERE IS IMPOSSIBLE TO FIND
    Genius:
  • 1,239 Answers
Hi
first way to check whether the dry hose are blocked or what
second thing is that the water pump malnufacation...
these are the basic causes for draining issues...
thank you........
Posted on Mar 06, 2009
My Roper top load washer stops in mid cycle and will not drain or do anything else
Most of the time that is lid switch failure. The lid switch must be engaged before the tub can spin. You can bypass the lidswitch to see if that is the problem. The lidswitch has 3 wires. 2 live wires and one ground wire which is green and bolted to the frame. Tie the 2 live wires together and see if the washer will work. You can use it that way but is could cause harm if anyone was to try and grab clothes out the tub while it is spinning full blast.
Sep 23, 2012 | Roper RAS6233KQ Top Load Washer
I am having problems with my LG Washer. There is an error code that flashes at the spin cycle and this stops the cycle from being completed. The UE light flashes and the spin cycle stops and will not...
Don't wait- follow these;-0)
It is necessary to ensure absolutely that the machine, even when empty, has all 4 feet very firmly on the floor, and I mean firmly ;-0)
Doesn't matter whether it is empty or not but switch it off then-
very firmly push one front corner diagonally into the centre of the machine and see if the machine moves or rocks AT ALL, even the slightest. If it does you will need the open-ended spanner which came with the (new) machine........which of course went missing a long time ago?!! An adjustable spanner will suffice.
Adjust the foot under that corner downwards until it is very firmly- almost pushing- against the floor but not so far that the corner lifts up!
If this corner did not rock do the same to the other.
Once you cannot rock the machine the slightest little bit, screw the locking nuts up tight to the underside of the machine so that they will not move. Ideally the rear feet should also be locked.
If this has not cured the problem it is possible that the internal suspension is malfunctioning.
Good luck,
John C
Mar 22, 2011 | LG WM1812C Front Load Washer
My washer on the "drain/spin"
This is a suds error.
The drain pump needs to be cleaned out behind the lower front panel.
Also use less soap when using a front load washer.
Dec 26, 2010 | Washing Machines
I have bought a fisher and paykel model DW60CSX1 second hand... i have connected all the relevant pipes and taps, the washer gets to a point in the cycle where it stops and thw 1st, 2nd and 4th lights...
My manual says that this means the drain hose is crimped or bent, or the drain hose is too high. In other words, the drain can't drain for some reason.
Dec 13, 2009 | Fisher Dishwashers
Fp fault
The problem is pump is either broke or there maybe something is caught up in the impellor, easy to fix, remove front cover undo spring for door seal unplug electrics, remove both hoses on pump and undo bracket, then check pump, had same problem myself it was an elastic band and coins got it fixed myself saved a fortune hope this helps.
Dec 14, 2008 | Washing Machines
Whirlpool AWO 3761/S
Faulty pump (most likely clogged).Remove the pump hoses and clean out the pump.Please leave a rating.
May 16, 2008 | Whirlpool AWZ410 Front Load Washer/Dryer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
Washing Machines Logo
27 people viewed this question
Dan Webster
Dan Webster
Sal De GO PATS
