Question about Cycling
How do I fit a new chain on my mountain bike?
The chain is on but it seems too long!
  • Anonymous Apr 13, 2009
    i can't get my chain back on the correct way
  • Anonymous Mar 31, 2014
    I need help with putting the chain back on my bike. I can't seem to get it on properly . Please assist with my problem
    Novelist:
  • 91 Answers
You can always get yourself a master link kit for your chain and cut the chain then lay it around the sprockets until the chain overlaps , count the number of links that overlap and leave just enough so you can cut off the excess chain and have enough links to splice the two ends of the chain back together so it will have enough slack to fit back on the sprockets , or you can also just purchase a shorter chain at any bike shop , bring your old chain with you so you can compare how much shorter your chain has to be , hope i was able to help you sincerely glenn mayer , please leave a nice rating if i was of help to you, thanks again for the question
Posted on Mar 06, 2009
You will need a chain break tool to shorten your chain to the correct length see http://www.youtube.com/watch?v=bsU2nEf2Tpc for a video tutorial.
Posted on Apr 06, 2009
    Problem Solver:
  • 5 Answers
Here is an article on how to fix a chain.
Bicycle Chain Repair
Rick
www.sagecycles.com
www.directbicycleparts.com
Posted on Mar 18, 2009
2 Suggested Answers
  • 26 Answers
SOURCE: on mountain bike the chain
It sounds like your chain is loose. Flip the bike over and loosen up the nuts on the back tire and tighten the nuts as you are pulling the rim back making the chain as tight as you can. You might need someone to help you pull as you tighten the nuts.
Posted on Aug 26, 2011
How do I tighten the chain on my son's 24 Next PX 4.0 Boys' Mountain Bike? It seems very loose
Hi Mitchell:
I looked at some pix of this bike and they showed a shifter. As long as the springs on the shifter mechanism are moving it as intended, the chain tension should be fine.
It's a good idea to occasionally clean the gear change assemble with a spray solvent, wipe it down, and then lightly oil it.
Jul 06, 2015 | Mountain Cycling
I need to find a part # for a chain ring for a Mongoose XR-75 mountain bike
Mongoose didn't make the chainring. They're generic (like most bike parts) and have many substitutes. Determine the parameters and then go looking for one that fits.
http://www.sheldonbrown.com/gloss_bo-z.html
Other parts may also be worn, like the chain.
http://www.sheldonbrown.com/chains.html
Aug 09, 2011 | Mongoose Cycling
How do i install a chain for my mongoose
Here is a quick video that does a decent enough job of explaining how to install the chain on a bike similar to yours.
Note: you need to have the special bicycle tool that installs and removes links from your chain. If you do not have one, and this is something you don't plan on doing again, it will be less expensive to have your local bike shop fit your chain than buying the tool.
Dec 11, 2010 | Mongoose Exile 26 Men's Full-Suspension...
Chain Broke on a Huffy Tundra 18 speed 26" bike. I need to know the size chain to replace or the master link/chain connector to fix the chain.
if the bike has gears it does not have a master link, that is for single speed bikes only.
You will need an 8spd chain for your bike (1/2" x 3/32), these will fit any 6,7 or 8 spd bike. This requires a special tool to install ($8-$25), I would recommend taking into a bike shop and have them do it if you have no experience with this type of chain.
Side note: if you do own the tool, you can repair a broken chain for a temporary fix in the future, so may be worth buying. Check around, many bike shops offer basic repair classes and cover this.
Nov 14, 2010 | Huffy Men Mountain Bike (26")
When peddling bike seems to try to shift gears
There may be some chain links that do not move freely. turn the pedal slowly backwards and check for siezed links, as it goes through the deraileur.
A worn chain can do this as well, unfortunately you usually have to change the chain and sprocket cluster as a pair. If you just put a new chain on a similar problem can occur.
Apr 22, 2010 | Schwinn Mesa Gs Mountain Bike
I have bought an Alivio front gear. Do I have to break the chain to fit it?
The easy answer and solution is yes, which will give you the opportunity to fit a handy little device called a missing link, which will allow you to remove your chain for cleaning in the future. They are available at bike shops and cost about $6.
Dec 30, 2009 | Mountain Shimano Alivio Front Bike...
Can i remove a 5 gear sprocket from 26" tire, and replace it with a 7 gear sprocket from a 20" tire? my roomates touring bike is currently a 15 speed, she loves the bike and does not want to replace it....
Several scenariosto consider here. First of all the compatibility with the hub. Second is the deraileur tarvel and the actual shifter. Components are normally matched in sets from factory and do not transfer over unless the entire set, shifter, deraileur and sprocket. Then there is the issue of chain wear fitting the crank and new hub together. Chains and gears seat into each other as they wear so a crank set should stay with the original hub as well, even if you were to install a new chain the wear pattern would be different.
So the short answer is unless the brands all match and are in new condition and the hubs are the same thread and diameter, you will not get good results
Sep 14, 2009 | Blackburn Mountain Air Mountain Bike Pump...
Slipping while cranking
The rachets in the rear gear cog have gone bad.  Buy a new gear cluster and have it installed on your rear wheel.  about $30
Mar 26, 2009 | Mountain Bike Bmx Fit Gt Haro Chrome...
Installed new chain on nakamuru 21 spd now chain seems to want to skip when under load at rear sprocket
They are called coggs if they are at the rear, and sprockets at the front. What has happened is your old chain has worn dwn the metal on the rear coggs and there is'nt enough metal for the new chain to grab on to. You need a new coggset or a new freewheel
Mar 25, 2009 | Hawk Tony 's Huckjam Series 21 Speed...
I have a pacific usa mountain bike and the chain broke an i bought a chain and I cant figer out how to put it back together
well usually all chains have a link that comes off. if you get that to come apart, then you put the chain on the teeth were the teeth come through between the links. then you link back together the two chain links. it might be a little hard though
Mar 08, 2009 | Mountain Bicycle Chain Press Fit 42 In ...
Cycling Logo
1,351 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
