Question about Hitachi 26LD6600 26 in. HD-Ready LCD Television
When switched on the set gives a picture for 2 or 3 seconds and then goes black but sound remains. Remote changes channel but still no picture.
    Genius:
  • 1,239 Answers
Hi sir,,
there are only three things to check which causes these problems...
first check whether the cathode ray tube is ok or not
second whether the fuse is damaged
third is the colour wheel,,,
if these are not defnility the circuit problem,,,diodes capacitors
thank u,,,,,
Posted on Mar 06, 2009
Sanyo TV - black screen, sound find
The black screen on your Sanyo TV is symptomatic of power supply failure
Jun 03, 2013 | Televison & Video
Alba tv picture appears but then disappears sound stays on
these tv's are prone to several problems involing the backlight inverter power supply...the main symptom is the one you are describing....tv goes on lights up for a second then goes dark even though the sound remains..and you can switch channels..n they change too....the most likely cause of this failure in my experience is several high voltage electrolytic capacitors in the inverter power supply have dried up and place a high esr value on the circuit ...causing it to shut down...most of the sets I have repaired with this problem have 2 electrolytics rated 10 uF at 450VDC...and replacing these with high temp/high frequency electrolytic capacitors usually does the trick
Jul 17, 2011 | Televison & Video
Lcd32880hdf 10 months old. When switched on the picture disappears after 2/3 seconds and will not come back on. Sound still remains un-effected.??
If you can quickly get to menu before picture goes blank, then go picture / backlight / set backlight to minimum and it will work fine.
Jul 04, 2010 | Albatron LNX-21TIS-3 Television
With my Sony Bravia 46" xbr the screen keeps cutting out. I'm usig hdmi cables and can't find a reason why te tv keeps cutting out. The sound still remains but picture doesn't. Not even out technician can...
Usually this happens to my set when I am in HD cable channel mode after being on a non-digital ANALOG channel.
I basically reset the TV by changing to a DIGITAL cable channel -- stay on that channel for ten-twenty seconds -- then I switch back DIRECTLY to a HD channel (key in channel number directly on remote).
TV works fine -- seems to be a glitch when the TV changes modes from Analog to HD
Jun 29, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
Big black box in the middle of the screen
The black box is there because your closed captioning is on and set to text mode. Some channels send the signal even when there is no actual text to display. You can get rid of it by either turning off closed captioning or changing it to CC1 or CC2 mode instead of text. If you can't find those settings, then restore factory settings as directed in your user manual.
Jun 04, 2008 | JVC AV-32230 32" TV
Screen goes black after unit is turned on.
Contacted Mitsubishi directly and found out that QV9 on the remote control resets to factory defaults, clearing the Parental lock out someone had put in place. The TV is in a Retirement Home and some of the folks are sneaky about wanting to control the TV in their own fashion. We will be watching the remote a bit closer now!
May 01, 2008 | Mitsubishi VS-50802 50 in. Rear Projection...
Cannot change channels in digital mode
Solution that worked for me:
Beware: Although the process should be safe, it technically voids your warranty.
Enter the service menu:
1 - turn of tv with remote
2 - press and release in the following order on the remote: Info, Menu, Mute. Make sure remote is pointing at the tv
3 - turn on the tv from the remote
4 - you will see the service menu. using the down arrow on the remote select the Reset option. Using the right arrow button at this point will do a hard reset.
5 - Wait a few seconds, turn TV on
6 - you will have to rescan analogue and digital channel but it should be working now.
Jan 29, 2008 | Samsung LE26R73BDX 26 in. HD-Ready LCD...
Sony FWD-50PX1 no picture
try changing the channel with the original remote or by the tv's physical controls. It sounds like it has switch to an AV channel.
Oct 09, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Black screen - sound works
westinghouse_w32701_27_in_hdtv_lcd
power on no picture good sound and channel page up and down works
on background u can see dark picture
Aug 15, 2007 | Westinghouse W32701 27 in. LCD HDTV
Hitachi 26LD6600 26 in. HD-Ready LCD Television Logo
182 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
