Question about Ovens
Going from gas to electric how do i install it
Stove is kenmore 911.9352190 model. what type of wire do i need and breaker pigtail outlet.
  • 10,865 Answers
You will require a 40 amp breaker and 8/3 wire with ground which totals 4 wires and requires a 4 wire outlet.
make sure you purchase a receptacle that fits the plug on your range.
please mark this answer as a fixya! thanks
Posted on Mar 06, 2009
Do I need special electrical outlet?
You need to check with a licensed electrician for your area that would know the electrical codes. Most houses will all ready have an outlet for the stove and you will have to match it up with for the cord on your stove. Older homes that have not upgraded the electrical, typically will have a 3 wire outlet for the stove. Most newer homes, where the code requires, may have a 4 wire outlet. If you are replacing an existing stove I would recommend getting a new pigtail cord for the new stove so that you have new wires carrying the current instead of trusting old wires. Hope this helps!
Mar 20, 2015 | Ovens
I want to reset the oven
Gas or electric? If electric are you sure you have power. Double check the breaker. Turn of and back on. If it pops, you have a wiring problem, the breaker is bad (yes they do wear out). If Gas, make sure you have power to the outlet that serves the stove. If no power the system will not work. If no power to the outlet, again check the circuit breaker for that outlet. If these things don't help check your owner's manual and it's troubleshooting.
Feb 28, 2015 | Ovens
I walked by my stove and noticed heat coming from it and I opened the oven door and heat was coming from it. I did not turn on the stove top burners or the oven when I noticed it. The switch was OFF. I...
You most likely have a problem with the temprature contol knob and the thermostat.
This is all contained in one unit. The controller has a long metal "wire" that sends the temp info to the controller. The "wire" ends inside the oven.
This whole assemblage needs to be replaced.
I would need the type of stove, gas or electric age and model to give you replacement directions
Jul 01, 2011 | Ovens
When I plug oven into outlet the breaker trips.
there is a short somewhere there, you will have to ohm's check it
Jun 21, 2010 | Kenmore 33464 / 33465 / 33469 Gas Single...
I have a kenmore gas range with electric ignitors. My question is that my stove top doesnt ignite but lets gas by and I can use a lighter to lite them. However my oven doesn't do anything...no gas no...
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Nov 06, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore oven's led display works, but will not heat
pull stove out and check the volts either on the plug or terminal block on the stove where the wires are terminated. check the terminals marked L or line at the same time should have 240 volts if not your breaker which probably is a 40amp will need replacing
Sep 01, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore gas stove Model 790
It could be that the sensor wire that controls the main gas valve is out of position. It should sit in the pilot light flame.
Look, and adjust if needed.
If it's ok, then you need a replacement main gas safety valve.
This should only be fitted by qualified personnel.
They do give up eventually after years of heating, and fail safe.
Dec 31, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
My kenmore electronic stove is having a beep with code F1 on the
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore ultrabake lights up when stove top is on but wont heat up
Hard to know...First thing I'd check is the power supply to the unit.  Turn off both breakers.  Check wiring all the way through for tightness.  Turn both breakers on.  Next, you'll need to check the elements for continuity...with the power off.
Nov 28, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
FEFL78CQA FRIGIDAIR ELECRIC STOVE
Unplug your power cord from the socket outlet.
remove the back cover where the power cord connection is housed. visually check the connection, expose wire harness might touches the cover somehow. or the cover was dent that causes the bare wire to touched the cover. correct the dent if any, or tighen loose wire.assemble back cover. Reset your circuit breaker to your Stove because the pop sound might trip off your breaker. That should solve the problem.
Jun 28, 2008 | Frigidaire FGB24S5A Gas Single Oven
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
