Question about Samsung HT-DB600 System
How to achieve surround sound through my blue ray player and tv
I've just recently purchased an Samsung LE40A656A tv, Samsung BD-P1500 blue ray player and a Samsung HT-TZ215 surround sound system. How do i connect all three systems together to achieve surround sound when the tv is on and when playing a blue ray.
2 Suggested Answers
  • 151 Answers
SOURCE: advice on the best way to connect
If your system has hdmi in puts put the blu ray player into it then from hdmi out on system to hdmi in on your tv.Now take a phono lead from tv out put to a input on your system,could be marked "aux,tv,sat".For tv sound set the system to prologic2,blu rays should decode themselves,if not check settings for audio out on player.
hope this helps.
cable guy.
Posted on Jun 29, 2008
dunnbiker
  • 8546 Answers
SOURCE: I'm Tryin to connect a samsung blu-ray
Find the manuals and refer to them.
My personal spin on the instructions:
NO signal ever benefits from multiple connections or 'hops' and it gets expensive zig-zagging a signal all over the room. K-I-S-S is the word of the day. Run the BEST version of any signal directly from its source to the BEST electronics that will present it to you for consumption. The separation of audio and video inputs and outputs on a device is what allows and ENCOURAGES the direction of each signal to the BEST electronics that can process it. Example: your TV does not have the best speakers in the room so why send it any high-end audio?
Posted on Aug 21, 2011
How do I connect my DISH, TV and Blu-ray. Right now I have my DISH satelite HD cable connected to the TV, and a HD cable connected from my TV to the Blu-Ray. The problem i'm having is the sorround sound...
hi,
Is there is any optical digital output in your satelite HD. Then connect that optical digital output of satelite HD to the optical digital input of your surround system (blue ray player) using an optical cable.
Then press the function button on the remote of surround sound system (blue ray player) and select D.IN. (D.IN means DIGITAL IN). You will get the audio through the surround sound system. if you need any more assistance fell free to contact me through fixya.
ok
Jan 27, 2011 | Samsung HTC5500 Theater System
I can't control the HT-C6530 unit with the remote. The remote is controlling the TV instead of the samsung HTS and i can't seem to switch it back. Seems to be something to do with the BDReceiver/TV button...
hi,
press bd receiver / tv button to select the remote for any one. u can use the same remote for tv and blue ray receiver. when u want to control blue ray with the remote, select remote for the same by pressing bd receiver / tv button and wise versa.
ok
Dec 27, 2010 | Samsung HT-C650W Theater System
Cant get led tv to play sound through surround sound on blu ray
you have to have a connect going back into the player, the hdmi is only one way there should be and analog the red and white
or
an digital optical out from the tv
May 08, 2010 | Samsung HTC550 Theater System
Hi I have a Yamaha yht 292 surround sound system with a model htr 6230 reciever. I have a panasonic (42'') plasma HDTV (model TC P42X1) attached to the receiver by a HDMI cable. I also have a Samsung Blue...
As per HTR-6230 specifications (http://www.yamaha.com/yec/products/productdetail.html?CNTID=5028494&CTID=5000400&ATRID=1020&DETYP=ATTRIBUTE) the HDMI function is only "audio-passthru", which means your receiver is not able to get the audio from HDMI cable, it can only pass it forward to TV. You would need a receiver with "HDMI switch" to be able to listen to audio via HDMI cable. You can find such receiver by looking if it supports TrueHD audio (which can be transferred ONLY via HDMI cable).
With your current receiver, you can connect it to the Blue-ray player via Optical SPDIF cable. I have checked the specs and both receiver and BD player supports optical connection.
Feb 25, 2010 | Yamaha YHT-390 Theater System
How to hook old surround sound sound up to new lg
if your old surround has either optical or coaxial connections you should be fine. if not you'll have to go with the audio in jacks (video 1,2 etc.) you'll get sound but not true 5.1 sound
Oct 22, 2009 | Audio Players & Recorders
I have a new 52" Samsung HD TV with a new Sony Blue Ray player and a Shaw PVR cable box all connected with HDMI cabes. I also have a older digital RCA model RTDVD1 sound system with no HDMI connection and...
I have the same situation....what I have done is connected my Blue ray to the TV via the HDMI connection and the audio to the RTDVD1 via an Optical cable. I find this is the best connection and sound reproduction so far. The input of the RTDVD is the SAT/Optical input and then switch the source to SAT/OPT. You will have to make adjustments in the BlueRay player's audio setup to enable the 5.1 DB digital sound etc.
Jan 24, 2009 | RCA RTDVD1 System
I have no surround sound when watching normal T.V
Hi there, in order to listen to t.v you need to purchase an optical cable and plug this in the optical out of the tv to the optical in on the blue ray then select D.IN.1 on the blue ray and press mode on the remote until it says matrix . This will allow you to listen to the t.v through all speakers. hope this helps. Also remember to take the rubber protectors off the ends of the optical cable, a lot of people forget this :)
Nov 17, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Remote code SAMSUNG
I have a samsung HT-AS720S surround system it is 21 months old. the right speaker has popping and static coming from it, had to disconnect it. Moved wire to another speaker-same thing. Contacted samsung tech to help, went through a number of test they said I have to send it in for repair. Warranty is only one year.
I also have a problem with the sound when watching tv it goes from normal to very quit, it's irritating-no matter how high I turn it up the base goes up but volume stays down. On shows that are on DVR all sound is good. Watching a DVD is also good.
Please help
Nov 05, 2008 | Audio Players & Recorders
Advice on the best way to connect
hope this helps.
cable guy.
Jun 29, 2008 | Samsung Audio Players & Recorders
Samsung HT-DB600 System Logo
182 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
sonic boom...
sonic boom...
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
