Question about Kenmore Dryers
My dryer doesn't heat at all. It runs fine but blows cool air. Kenmore dryer model 96278100
  • 159 Answers
SOURCE: roper dryer won't heat
first thing is check the voltage between the black and red terminals at the back of the dryer. you should read 240v. then check the voltage between the balck and the white and the red and the white. there should be 120v at each. if all that is good remove the back of the dryer. make sure you unplug it first. then no the lower right you will see the heater. near the top of the heater you will see a red wire and a red/with a white stripe wire attached to the high limit cutout. remove one wier and check the switch for continuity. if you read nothing its bad and thats why there is o heat. Ifnit checks good replace the wire and then remove one red wire from the heater. then check the heater with your meter. most times on the whirlpool products its one of the two that is bad. check the two thing I described and if you still need help feel free to get back to me and we can go from there.Good luck
Posted on Aug 22, 2007
  • 83 Answers
SOURCE: maytag dryer not blowing hot air (2yrs old)
If the vent is blocked, it will not stop the heat, it will only restrict the air flow.
Generally a couple of things can cause the heat to stop.
Either the thermostat or the element.
I would first suggest the element.
It may be fatigued therefore the internal wire within the element becomes fragile and eventually breaks down. Although it is an electrical item, it is mechanically built and can fail.
In some dryers the element is held in clips.
These clips can cut into the element.
The thermostat maintains temeperature but again, it is mechanically built and can also break down.
If you are not capable of inspecting or troubleshooting the internals of the dryer (i.e remove the cover and look for the failurer), then have it inspected by a repairman. There is not too much that can go wrong with a dryer. The most expensive part wuld be the motor that spins the drum.
Posted on Sep 17, 2008
  • 734 Answers
i am sending you all the possibilities for your problem, check either of these causes ----and than let me know if it is solved----
Power from the house
Check to see whether there's power getting to the dryer. Is it plugged in? Check for blown fuses or tripped circuit breakers--your dryer uses two fuses or circuit breakers. The dryer could tumble but not heat if only one of the two fuses is blown. If you have circuit breakers, one of the two circuit breakers can trip, even if the two for the dryer are connected.
Heating element
Often a dryer heating element burns out, but doesn't trip the circuit breaker or blow a fuse. The heating element is simply a long coil of special wire. You can check it for continuity with an ohm meter. No continuity means the element is bad and you need to replace it--electric heating elements aren't repairable.
Thermal fuse
On many dryers, there's a thermal fuse mounted to the exhaust duct inside the back cover panel. The fuse--which is about an inch long--is usually embedded in black resin and mounted in a white plastic housing. If the fuse has blown, you need to replace it. (You can't re-set it.)
A common problem is for the main wiring connection from the house, at the dryer, to burn and break its connection. Because the dryer can still tumble with partial power, the connection may be only partially defective. You may need to replace both the power cord to the dryer and the terminal block inside the dryer that the wire is attached to.
Posted on Dec 12, 2008
SOURCE: Dryer only blows cool air
my dryers works just blows cold air,can you help?
Posted on Jan 02, 2009
  • 5911 Answers
SOURCE: kenmore model 76712 does not blow heat just cold air
The following link explains how to troubleshoot and dryer "no heat" problem and the common causes:
Read through the link thoroughly, paying particular attention to the section that discusses proper ventilation. Most dryer heat related problems are caused by insufficient air flow which, in turn, causes the dryer to overheat to failure. More commonly, the Thermal Cut-Off (TCO) fails. You will need to check all the components mentioned in order to be sure. If you haven't had your dryer ventilation cleaned or inspected in a while, now would be a good time to do so. Failure to correct any potential existing problems, can cause premature failure of any parts you replace.
If you have questions, or require additional assistance, please let me know, so I can provide you with a viable solution. i hope this helps you.
Posted on Jan 22, 2009
Dryer stopped heating only blows cool air
you have to open the back off dryer,the r two thermostats. they are round held by 2 small screws. high heat- low heat. use volt meter to see which one is bad. if u put volt meter on wires,it will let you know which is bad. 30 to 35 a pc.
Mar 17, 2013 | Dryers
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Gas dryer will heat sometimes and not heat other times kenmore model 72802
sounds like bad gas coils,you have to send the whole model number,it will start with 110. or similar,if the bottom panel comes off,remove it,start the dryer, or in the front panel down near the bottom pop off the cover and look in,if the flame lights and then after 10 to 20 minutes the flame doesn't light you have bad gas coils.when the coils are starting to fail they will work correctly until they heat up and then they won't work until they cool down,the coils are what opens the gas valve.the coils are on top of the gas valve,remove the two phillips screws,pull off the cover,remove the wires from the coils and install the new coils,put it back together and you'll be fine,also while you're in there,get a shop vac and vac out the cabinet,stick it on blow and blow all the lint off of the motor and out of the gas tube,then clean out the duct that the lint filter slides into.if your vent line is a long run from the back of the dryer to the outside,i use a leaf blower remove the vent line from the back of the dryer and blow all the lint outside out of the line,do this once a year,you won't have any fires,your clothes will dry on time and your motor and parts will last longer
Oct 28, 2011 | Kenmore 72802 Gas Dryer
Older dryer just stopped heating. Air still blows
Sound like you need to replace the heating elament you will need to take your model number and make to repair shop for replacement parts or have a repair person come out and fix it for you . thanx for using fixya
Jun 16, 2009 | Kenmore 64742 Electric Dryer
Dryer heats, tumbles clothes, blows air out exhause vent, but wont dry clothes
what type is this electric or gas? have you removed the exsaust from the wall and ran a load like this? if you have heat and this is an electric dryer it sounds like you have a blockage in your house. if the dryer runs fine without the exsaust attached then that is your problem. let me know
Jun 02, 2009 | Kenmore Dryers
Dryers Logo
124 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
