Question about Nokia N95 Cellular Phone
Hi,I have the n95 and the slide is very stiff when i open or close it. can you please tell me why? and the solution to fix it. Thanx in advance, Al.
Two solutions here. Don't try the second one if your phone is still under warranty or if you're bothered about invalidating the warranty. 1) Take your phone to a Nokia service centre, it should be free of charge to fix. 2) With the slide open, from the sides of the numerical kepad, carefully prise the back cover off, if you have thumb nails this is really easy. Spray a small amount of silicone spray, NOT wd40 as that attracts dust, onto a cotton bud, the type that would be used to clean ears, and dab the spray on the runners that are visible with the cover off. As you are applying it, keep moving the slider to spread the silicone spray along the whole mechanism. Do this on both sides. The rear cover will just click back in place.
Hope this helps.
Posted on Mar 08, 2009
Nokia n95 slide strip problem
That is the problem of your connector which connect from your motherboard to your display. It like a tape and called ribon. After using the mobile many days then it can be occur. Don\'t worry. Just change it from mobile servicing center. Then it become ok. Thank you.
May 24, 2014 | Nokia N95 Cellular Phone
When i open or close slide upward on my n95-1 (it has fully updated firmware), between the opening or closing slide the screen becomes white for a few seconds? What can i do? What is the problem with it?...
make sure you got enough memory available on both phones internal and micro sd card. also try to delete suff from internal memory
move the sms contacts to memory card... along with apps..
Close any active app (Press and hold menu key to see open apps)
if any of the above doesnt fix, then you need to format your phone..
1. Switch off the phone.
2. Hold down the following three buttons: Green (call answer button, * button, and '3? button.
3. While holding these buttons, press the power button and switch on the phone.
Apr 12, 2011 | Nokia N95 Cellular Phone
Gprs settings of my n95
To get the
GPRS/INTERNET setting please call your service provider.
They will send you the
GPRS/INTERNET setting.After you recieve please save the settings to your phone and make it as default setting.
You can start using this service
Thanx
Jul 27, 2010 | Nokia N95 Cellular Phone
Error 01 I did **** control et al and even so
The information your browser stores is sometimes incomplete or corrupt. Deleting your browser's cache and cookies will often fix Gmail issues.
For instructions, please select your browser below:openm Internet explorer click on tools>internt option and then delete cookies, Temporary files and clear history then click on ok and exit out of internt explorer and the relaunch it and it will fix the issue.
May 09, 2010 | Google Talk
Slider or ribbon problem
its a flex problem. The flex that connects the screen to the phone board is probably weak or has loosed contact.
This kind of problem is common with slide and flip phones. The flex worn out or get damaged because of the constant opening and close of the phone.
I would advice that you take the phone to a repairer to fix the problem for you.
Take care.
Mar 18, 2010 | Nokia N95 Cellular Phone
Mic problem n95
Hi there
Your mic has shifted position.
Open your phone,look at the bottom part of the phone i.e the part where you speak though in your phone.
Align it with the hole of the mic on your phone case,
Close your phone and put it on, you wont experience this problem anymore.
If you cant do this yourself,get someone with experience to do it for you
cheers
Mar 02, 2010 | Nokia N95 Cellular Phone
Can anybody tell us how to remove quinny zapp seat unit?
Hi it's a bit stiff but you need to unlock the buggy as thought ur gonna close the buggy and slide the footrest part off first and then the botttom half and work ur way up it is REALLY stiff especially first time you do it. Hope this helps and good luck
Feb 23, 2009 | Quinny ZAPP Stroller
Unlocking N95 8gb on 3
T-mobile will supply an unlock code after 3 months for a fee usually. Don't know about Voda but should be the same!
Oct 14, 2008 | Nokia N95 Cellular Phone
N95 keeps connecting to the net
That used to happen to me, however it was more user error!
This may not be true in your case however i'll explain anyway: As i'm sure you know by pressing down or the right command button you open the internet application. This would occur for me when i put the phone in my poket as there is a lag between closing the slide and the keypad locking. I suppose the way to tell is to change those buttons functions and see or check the keypad locks before putting it in your pocket. That is if it has anything to do with that! Hope this is a help anyway.
Apr 20, 2008 | Nokia N95 Cellular Phone
No lights in the touchpad when slide up
its probably the sensors inside your phone. most manufacturer uses magnet or sensing... if you can open your phone check if its still in place... if not visit your service center...
Oct 24, 2007 | LG KG800 Cellular Phone
Nokia N95 Cellular Phone Logo
120 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
