Question about Sewing Machines
Kenmore sewing machine model 1340281
The thread is loose on bottom. I have tried very thing. Can you tell me how to fix bobbin assemly
  • 26 Answers
Just replace the bobbin holder assembly as the adjustmentspring to try and fiddle with the tension on it may be worn out I just replaced mine and it is not that expensive
Posted on Mar 08, 2009
The bottom thread in my sewing is looping and baggy.
Hello, If the thread is loose on the bottom then it is the tension on the top. If the thread is loose on top then it is underneath.
Dec 11, 2014 | Sewing Machines
Kenmore sewing mechine
If it a problem on bottom you need to work on the top of machine. Try adjusting your top tenisons. Also rethread machine.
Sep 02, 2012 | Sewing Machines
I have a Singer Sewing Machine Model 4562. The machine will not pick up the bobbin thread. I was told by a local sewing repairman that the timing was off. Can anyone tell me how to fix it myself, a
have you tried changing the needle? usually flat side goes to the back of the machine
rethread the machine top & bobbin
make sure the bobbin is inserted correctly into the bobbin case
clean under the needle plate & in the bobbin area for lint or loose threads
try these sites about timing
Apr 10, 2012 | Singer Sewing Machines
I have a Kenmore sewing machine - 12 stitch model which I bought in the 70's. I am having a tension problem and can't seem to fix it. What is the normal setting for the top, and bottom?
Load your Kenmore sewing machine with the right thread and bobbin thread for your project. If you use the wrong weight thread for your fabric or severely uneven weights of thread, this can cause the appearance of a tension problem when it is, in fact, a thread weight problem or a problem with your sewing speed. If you go too fast, you will break the thread. If you go too slow, you can cause loops. Uneven pressure can cause stitches to vary greatly.
Test your Kenmore sewing machine's tension by sewing on a piece of scrap fabric. If your tension is way off, then test on some basic cotton or a firm blend simply to get your tension right. Do not try to start adjusting your tension on silk or leather. Get a base adjustment on a more standard fabric first.
Look at the top threads and bottoms threads. If the tension is off on one side, it will usually affect the other side slightly. So select the side that looks more maladjusted to start adjusting the tension.
If the top thread is too loose or too tight, you will need to adjust the tension dial. This dial is usually located a few inches above the needle on the Kenmore machine body. Usually, your machine will have markings to indicate which direction tightens the tension. If these have worn off over the years, watch the dial as you turn it. If it appears to move toward the machine body, then it is tightening.
If the bottom thread is too loose or too tight, then you will need to open the door to the bobbin case. On some Kenmore models, there is a little screw near the bobbin case that can be adjusted slightly to adjust the tension. On other Kenmore models, there is a screw on the bobbin case itself--not on the bobbin, but on the bobbin's casing. This will also adjust the bottom thread tension. Adjust the bobbin thread tension to make slight changes.
If the thread is looping severely on one side, the thread weights might be off. For instance, look to see if you have a lightweight thread on the bobbin and a heavyweight one on the top. If the thread keeps breaking, the top tension or bottom tension could be too tight or the thread is too lightweight for the material you have selected. Check your combination of threads and material. Also make sure you are using the right weight needle and the right foot for the sewing step or project you are working on.
If your Kenmore sewing machine's tension is off severely or if you have not used your Kenmore in a long time, then you might need to take your machine in to be serviced. Sometimes, the inner parts need to be oiled or the entire machine might need to be cleaned and calibrated by a professional. If you sew a great deal or if your machine sits idle a lot, both situations will usually require some servicing to keep your Kenmore sewing machine and its tension in perfect working condition.
Jul 11, 2011 | Kenmore 15358
Bobbin thread is too loose. Need service and cleaning
you can go to the nearest sewing machine store, to asked an assistance, but u can do your self to fix it, just get the bobbin and tight the small bolt of the bobbin.
Mar 31, 2010 | Kenmore Sewing Machines
I have an older kenmore sewing machine. It's been
When I have run into similar problems with my older Singer, it's because there is a bit of thread caught somewhere in the bobbin mechanism that doesn't allow the shuttle to run freely. Take the bobbin assembly apart and use a bright light to see if you see any bits of thread in there.
Good luck and let me know if this works!
Jan 14, 2010 | Kenmore Sewing Machines
How do I adjust the bottom thread the stitches are too loose?
if stitches on top is loose then remove bobbin case and tighten small screw on it. if stitches on bottom of fabric is loose then tighten top thread tension.
Nov 03, 2009 | Kenmore Drop-In Bobbin 16231 Mechanical...
No bobbin tension
If the thread is loose on the bottom of the fabric, it's actually the top thread is too loose. Think of 2 little elves playing tug of war in your machine, one on toip and one underneath. If you have loops on bottom, the top needs to pull harder (tighten top tension)
Mar 18, 2009 | Kenmore 15516 Mechanical Sewing Machine
Sewing Machines Logo
160 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
