Question about Intuit QuickBooks Pro 2007 Full Version (299116)
Installed a new n router..now quickbooks error QB has a problem reading this registration file. remove file and reinstall QB's??? i have no clue how to locate the file c:programdatacommonfilesintuit/quickbooksqbregistration.dat i tried everything i could think of...please help if you can :o)
  • 41 Answers
The extension is wrong. The extension .dat usually happens when a file become corrupted. Maybe this link will you out.
http://filext.com/faq/open_dat_file.php
Posted on Mar 30, 2009
I am trying to instal quickbooks pro 2008 but error 1603
Error 1603 is related to insufficient rights to install QB. Please follow these steps to resolve this issue. Assuming you have Win XP. 32 Bit OS.
1. Remove QB from Start>control panel>Add/remove programs. {IF YOU FIND ANY QB INSTALLED].
2. Rename all intuit folders to Intuit-old. You wil find these folders here:
  • C:\Program Files\Intuit
  • C:\Program Files\Common Files\Intuit
  • C:\Documents and Settings\All Users\Application Data\Intuit
  • C:\Documents and Settings\All Users\Application Data\Common Files\Intuit
3. Then install QB using QuickBooks.msi . You will find it inside QBooks folder in your QB disc. Right click on the DVD / CD drive and click Open/Explore. Then go to Qbooks folder, find Quickbooks.msi and then run it. Follow the wizard and then install it.
IF STILL ISSUE IS UNRESOLVED, THEN REMOVE AND INSTALL MICROSOFT .NET FRAMEWORK 2.0 SP2. To do it, please follow.
1. Download and install .NET removal tool from:
http://public.blu.livefilestore.com/y1pM-hUF1x_Oqpme4sYbkLY1eFfh7z7FTyANwGAK1PQgJMwhILtFzMj7WXQJtjfH39GalpsBeQRzeQHXRlbO9w1gA/dotnetfx_cleanup_tool.zip?download&psid=1
then save it and unzip it . Then run it. Select Allversions in the box where it will ask to remove .net framework from the computer.
2. Download .NET framework 2.0 SP1 and then install it . you can download it from:
http://www.microsoft.com/downloads/en/details.aspx?familyid=5b2c0358-915b-4eb5-9b1d-10e506da9d0f&displaylang=en
click on DOWNLOAD next to NetFx20SP2_x86.exe. download it and install it.
3. Restart your computer and then again install QB.
IF STILL YOU GET ANY ISSUE, REPLY WITH FOLL :
1. WINDOWS VERSION.
2. are you installing QB using a disc or downloading from the Internet?
3. Any Antivirus on the computer?
Oct 30, 2010 | Intuit QuickBooks Pro 2008: Windows
I get an error when I'm closing Quickbooks Simple Start, The instruction at "0x56461f49" referenced memory at "0x036c4360". The memory could not be "read". Do you know what this means and how to fix it?
Assuming you have Windows XP, please follow these steps:
1. update QB . To update QB,launch Quickbooks and then go to Help>Update QuickBooks. In the windows, click UPDATE NOW.
2. Then go to Start>Control Panel>Add/Remove Programs. Then check mark SHOW UPDATES.
Then find Microsoft .NET framework 2.0 SP1 or SP2. Find update KB976576 or KB576976 and remove it.
3. Restart your computer and then launch and close QB.
ISSUE WILL GET FIXED
In any situation, this issue will never ever effect your QB data file.
If issue remains, reply with QB version and Windows Version?
Jul 10, 2010 | Intuit QuickBooks Simple Start Edition...
Reinstall QuickBook Pro 2008 after clean reinstall of XP Pro SP3
Once you reinstall Quickbooks, you should be able to copy your QB files to the My Documents folder then open that file in quickbooks
Mar 25, 2010 | Dell Latitude D830 Laptop Computer PC...
Same msg "This file was not closed in the previous session. Ro..
I unfortunately have to use quickbooks as well in my personal life & in my professional life. After an exhaustive search I finally found a solution to my problems which are not exactly the same as yours but sound very similar.
It was all down to .Net Framework. I completely removed it from our systems using this I also uninstalled Q.B. Ran a free registry cleaner and reinstalled everything and it worked first time no problems.
Not sure if this will help too much but hopefully should get you on your way.
Aug 31, 2009 | Intuit QuickBooks: Pro 2005 for PC
1)I can not install my update of Quickbooks Pro 2005. Get error message "File ComponentsHelpCacheqbhelp.qcd can not be located" What does this mean and how do I correct it? + 2)When clicking on the help...
Assuming you have the install files for QB 2005, reinstall it with the original parameters and then un-install it. The missing file is stopping the un-install, and assuming that you cannot edit the uninstall parameters, about the only way to actually uninstall is to make sure the 2005 install is complete before you unload it.
Apr 19, 2009 | Intuit QuickBooks: Pro 2005 for PC
Quickbooks 2008 will not load, it says that it is installing and then goes to error 1325
Assuming you have Win XP, please follow these steps:
1. Remove QB from Control Panel>Add/remove programs.
2. First rename all folders of Intuit. rename Intuit to Intuit-old from the following locations.
3. Then disable your Antivirus / Online Security.
4. Then install quickbooks using quickbooks.msi . You will find quickbooks.msi in the foll location:
>right click on ur QB disc and click open/explore.
>Double click on QBooks folder and run quickbooks.msi and follow the wizard.
If you still get any more issues, please reply with following:
1. Which windows version you are using ?
2. Are you installing QB for the 1st time on this computer?
3. Did you install any other software rrecently ?
P.S : this issue may also be because of Microsoft .NET framework on your computer. PLease help me with your reply to help you.
Feb 19, 2009 | Intuit QuickBooks Pro 2008: Windows
Error message when installing QuickBooks 2005 to new 64 bit compu
Hello, I found this on another web site intuit community. I tried this and it works. A couple of people said they had to run this each time they signed on but i have not had to.
Welcome to the community forums. One thing that I notice with your error log is that all the missing files are .dll files. I would suggest running Reboot.bat which re-registers the QuickBooks .dll files.
Do a search on your computer for reboot.bat (there is a seperate one for each version) and run the reboot.bat that corresponds to version of QuickBooks you are having a problem with.
It worked for me and I am so happy because as stated QB not longer supports 2005.
Lorene renie1954@yahoo.com
Le me know how it goes for you
Jan 06, 2009 | Intuit QuickBooks: Pro 2005 for PC
I have installed quickbooks 2003, i cannot load a company file, qbw, which was saved under a previous version, error message "qbw is not a quickbooks file or is damaged". i have tried changing op...
U may find a solution on the quickbooks website, but not likely. The solution may be to resave the older file in some other format that the new QB can read.
Jun 02, 2008 | Computers & Internet
Intuit QuickBooks Pro 2007 Full Version (299116) Logo
160 people viewed this question
Top Intuit Computers & Internet Experts
Alun Cox
Chris Larocque
Mike
Are you an Intuit Computer and Internet Expert? Answer questions, earn points and help others
