Question about Sony STR-DE597 Receiver
Sub Woofer will not work with my other two speakers.
A cheep sub woofer once worked with my two JBL speakers, but only in DVD mode playing CD's. The sub stopped working so I purchased a Polk sub and it too will not work. The Sony only lights up the SB ( Subwoofer) box in Movie mode for 6 Channel, but I only have a pair of speakers. The sound is faint in this mode compared to 2 CH or stereo mode.
Any suggestions? Thanks
Ok SB is for surrond back. but i think i now what the problem is. if your receiver is in multi channel decoding some times the bass will olny come out of your main speakers. and how to change this is go to SET UP in main menu on your receiver make sure you got NORM SET on and then go over in tell it has your main speakers highlited and change that to SMALL not LARGE and sarry for the spelling hope i helped
Posted on Jun 27, 2009
My powered subwoofer no longer works through the receiver
if you have your front and centers set to 'small' you want your Bass out to be subwoofer only, and the rca jack labeled 'sub out' is the only place to connect your sub to if you want to control the frequencies with your reciever. I dont know the brand of your sub, or the inputs on the back of it to advise you where to connect, but it sounds like it worked for you at one time, but suddenly it does not
Mar 05, 2013 | Audio Players & Recorders
I have a JBL TLX CSS-SUB1 sub at the back are where you connect the speaker wires to the receiver but i don't know witch wire goes in what? i have no clue
The connection on the receiver would be the sub woofer out. Not a sub woofer out LFE, a sub woofer out with speaker wire connection. From there you plug it in to the top section of the available terminals on the sub you are referring to (speaker level input). One in positive and the other in negative matching what you did on the receiver with correct ends. The speaker connections underneath the top connections is for additional speakers like surrounds to be able to be connected directly to the sub woofer speaker level out for sound. This of course would be for an older receiver connection. I do not think it is possible to convert this connection to an LFE and have it work properly. If the receiver does not have sub woofer speaker connection and only a RCA out then you can try to connect both rear speaker connections from the receiver to the speaker level inputs on the sub and then connect your rear speakers to the speaker level output on the sub to power them. This is an active sub woofer but for some reason they made it connect as if it was passive. I am not sure if this sub is designed for really low frequencies required for movie or if it is better for music.
Nov 01, 2010 | JBL Audio Players & Recorders
I been having a problem with my JBL TLX CSS-SUB1, I don't have the manual. Connecting speaker wires from the JBL TLX CSS-SUB1 to the a Digital Audio/Video Control Center ( it's a reciever) I confused,...
Nov 01, 2010 | Audio Players & Recorders
It will not power on
henrylshelt,
Your sub should turn on into standby mode when plugged into AC power without being attached to the receiver. If it does not follow the list below. If it does, the sub needs a signal from your receiver via either by line-level (RCA) or the speaker wires to turn on out of standby. Ensure that the cable or wires going to your sub is in fact sending a signal while the receiver is on. To Test, (speaker wires) hook up a different known working speaker; (line-level) Some receivers have a menu option to turn the LFE output on and off, ensure that it is on and producing a signal.
Diagnose the problem:
1) Remove all wiring to/from the unit except for the AC plug (use a different known working AC outlet), will it turn on? If so the other outlet is not working.
2) Remove the woofer, does the amp have a fuse that need to be changed? Change the fuse. If it blows again after replacing and turning back on, the speaker is blown; go to #4.
3) Unplug the woofer from the amp, does it turn on? If so, go to #4.
4) The sub need to be serviced. http://www.jbl.com/EN-US/Support/Pages/SupportOverView.aspx
-Hope this helps, Chris.
Aug 29, 2010 | JBL PSW-D112 Speaker
Cannot get the sub woofer to work.
Now tell the NAD you have a subwoofer. Page 15, Figure 13, etc. and Page 18 - 19.
Mar 05, 2010 | NAD T770 Receiver
No Sound
This might very well be a fuse - check by setting the sub woofer to "On" to see if it powers up. If it does, there may be a problem with the sub woofer audio cable(s) or connection(s).
Don't forget to check for a tripped circuit breaker or blown fuse on the stereo's speaker output. If your sub is connected to a low level output - this shouldn't be a possible cause - as circuit breakers & fuses are usually on amplified (high level) or speaker outputs.
Another possibility is that the settings of the stereo has been changed from a *.1 system to plain stereo 2.0 or some other setting that disables the LFE (low frequency effects) or sub woofer audio output.
Sep 18, 2009 | JBL Venue SUB10 Subwoofer
Jbl sub woofer
Has nothing to do with the signal or source - it is a failure of the turn on circuit - I repair this amp - can help if you find my add here or I am located on ebay as well. Juust do a search for We Repair JBL and find the model :)
Sep 03, 2008 | JBL Northridge E 250P Subwoofer
Sound problems through subwoofer
check all speakers wires andcheck test mode. every thing ok, may be input wiring problem ,check every thing after that internalcircuit may be problem..
Oct 08, 2007 | Audio Players & Recorders
VM9311TS Subwooofer problem
you wired the remote wire up to the solid blue wire on the dvd player.....you need to put it on the blue wire with a white stripe......that should make it come on for everything....the solid blue wire is if you have motorized radio antenna. it turns it on
Sep 04, 2007 | Jensen AM/FM/MP3/DVD/CD iPod-Ready...
Sony STR-DE597 Receiver Logo
170 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
