The TV was on, and left the room for a few minutes..came back in, and the TV was off. No power LED showing, moved it to a different power source, however it acts as though it isn't recieving any AC. is there a reset button somewhere?
  • 294 Answers
TRY UNPLUGGING YOUR T.V. FOR ABOUT 15 MINS THEN PLUG IT IN AND SEE IF ANY OF YOUR LED'S LIGHT UP
Posted on Mar 07, 2009
Please Help!!! Logic 32' LED. L32HE23. STUCK IN STANDBY MODE???
Assume you have lost remote. Look on reverse of both sides to see the manual operation buttons. These will operate all the functions of the normal tv operation, and should be able to select different source feeds, dvd ect. If you still have remote try unpluging tv, wait for a few minutes then plug back in. Hope this helps.
Aug 25, 2016 | Televison & Video
Crown ctt3207w LCD TV won't recognize the PC source anymore
I would check the cables inside the unit. One of them could have come loose during the move.
May 20, 2016 | Televison & Video
My Panasonic led tv just shuts off , wait 10 mins
It could be the room temperature or the TV is placed in a box type cabinet, thus restricting the air circulation at the back of the TV. Flat screen TV's generate a lot of heat and without proper air circulation, they usually shut down to prevent damage to its components. Are you in the middle of a cold spell? Usually when it's cold, you have the heaters on hi heat, yes? Try and reduce the heat or place the TV on a cabinet with ample air circulation and then see the difference.
Oct 17, 2014 | Televison & Video
No Video Error on TV Screen
Select SOURCE on tv to dvd or component or dvi or auxilary etc
Aug 24, 2014 | Sony DVP-SR210P Progressive Scan DVD...
Tv won't turn on
Check for input power in outlet. Try connecting the TV to a different power outlet you are sure works. Switch off TV manually, switch off power, remove plug and retry after 48 hours. If problem persists, please refer it to a qualified service technician.
Jul 25, 2012 | RCA L22HD31 22 in. LCD HDTV
I just moving my tv from different room and stop working no power.
Check the power source?Tries unplug,replug the tv back like an hour later.The tv now is resetting itself back to the factory setting.The tv should be working now.If still have no power,than some how ur power supply board got shorted and died.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Nov 15, 2010 | LG 42LC2D 42 in. LCD HDTV
This just happened to our TV as well. TV was working, we left the room for a few minutes, and when we came back it was off and we couldn't get it to come back on. Green light flashes for several minutes...
try unplugging the tv for a few minutes and see if that does it. if not sometimes there is a reset button on the back. there could be dust inside the back cover that is also shorting out...last resort though. Good luck1
Dec 06, 2009 | Televison & Video
Panasonic th-42px60u plasma tv not turning on
Power LED on front panel blinks several times, there is a delay, then repeats. After fiddling and fuming (mostly fuming) I found that changing the input signal source allowed the TV to be turned on. When I changed the input signal source back everything was ok.
In other words...
My TV is connected to my PC's video card via an HDMI connector. My card has 2 HDMI connectors. I moved the connector (the part that comes from my computer) from one HDMI out to the other. The screen powered up. When I changed the connector back to the original HDMI out I got my display back.
So yeah, try changing your input signal source. If you're using cable try switching to your Xbox/PS3/whatever, or vice versa. If you only have one possible signal source then I have no clue.
It's almost like the TV doesn't get any signal from the current cable then goes into sleep mode until it gets another signal. My problem had to do with me changing a bunch of sleep/timeout/screensaver settings on my TV/comp.
Hope this helps someone.
Dec 30, 2008 | Panasonic TH-42PX60U Television
Televison & Video Logo
32 people viewed this question
Top Televison & Video Experts
