Question about General Electric GE SmartWater Household Water Filtration System - GNWH38F
Water not getting hot / Kenmore Economizer 6 / Electric
I recently worked on my my A/C and had my breakers off. Upon switching them back on the water stopped getting hot. I keep flipping the breaker on and off, without results. Is there another breaker I should be checking?
  • Thomas F. Schneider May 11, 2010
    You should check with a volt meter or test light to see if you have electricity to both legs of tyou water heater. In other words 240 volts
    between there two lines or light to ground on both lines.
  • 659 Answers
Did you check to make sure that the breaker is good on the unit? Check to make sure you are getting voltage. If not, check to make sure that the thermostat located in behind the panel on the heater is getting voltage and also sending voltage to the elements. If the elements are getting voltage but aren't heating, the element(s) is bad.
Posted on Mar 16, 2009
We just installed a hot water heater that's
1) Test elements, and if elements are good, then replace both thermostats.
Takes about 20 minutes. Power is off.
http://waterheatertimer.org/How-to-test-water-heater-element.html
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
2) Label on side of water heater shows volts and watts.
For 4500 watt elements, you need 30 amp breaker and 10 gauge wire.
Move water heater wires to different same-size breaker.
http://waterheatertimer.org/Color-codewire.html
3) Open the links and do the work, or call plumber to do work, or call manufacturer for warranty coverage.
If your wire and breaker are problematic, then service is not free.
Feb 07, 2013 | Water Heaters
Have a reliance electric water heater model 606; have no hot water. I am having a problem finding the reset switch.
If it was working and recently stopped working, the heating element that heats the water probably went bad, no longer functioning. Check to make sure that there is or is not a reset button, and if there is, press and reset the heater. It's not difficult to remove the old heater element and replace it, but make sure the circuit breaker power to the water heater is off when you remove it. Take it to a water heating supply store, or large hardware store with the Brand and model number of your water heater (Reliance RELIANCE ELECTRIC WATER HEATER,model 606 ) to buy another one.
Sep 21, 2012 | RELIANCE ELECTRIC WATER HEATER
Water got extremely hot and then tripped a breaker. now if i reset the breaker and turn on the hot water switch on the wall, all is good. but when i turn the switch on the hot water heater itself it trips...
Sounds like you have a short in wiring for 120VAC system of water heater. Shut breaker at panel off, and remove cover on back of water heater to look for any burnt wiring at connections such as switch, or thermostat/eco assembly.
Jun 10, 2011 | RTO Atwood Water Heater - 6 Gal LP
No hot water on electric but burning hot on lp gas,what can my problem be.
Need to confirm hydro to water heater, all switches breakers etc on, and check to make sure switch at back of water heater at connection box on as well. If power to back of water heater, then check for reset in center of ECO on back behind cover. If power going to element ( behind cover as well) then replace element. Be careful when removing cover on back. Shut breaker off at main panel until you can get cover off and ready to test voltage.
Feb 26, 2011 | RTO Atwood DSI-RV Water Heater-6 Gallon
I replaced all parts but water heated won't get hot
You have electric water heater.
You replaced elements and thermostats but heater still won't work.
And tank was completely full of water, and water was running out of a faucet before turning power ON.
If elements are not fully immersed in water, they will instantly burn out.
If upper element is burned out, then tank will have NO hot water.
If lower element is burned out, and upper element is not burned out, then tank will have some hot water.
http://waterheatertimer.org/How-it-works.html
If elements did not burn out, then that leaves 1 main suspect: the electricity.
1) Push in ECO red reset button on upper thermostat. If ECO is tripped out, then heater will not work.
2) Click circuit breaker all the way one direction and then back the other direction to make sure breaker is latched.
3) If tank has 2 elements, then it is 240volt.
If 1 leg of 240Volt circuit is not working, then 240V appliance will not work.
240Volt circuit needs both hot wires to complete the circuit:
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#120-240
Buy cheap multimeter from Home Center and set dial to 240-250-277VAC
Tape tester leads to woods sticks to keep hands away from power.
Power is ON
Test across top 2 screws on upper element should show 220-240 volts.
If you have 240 at top two screws, then skip down to step 6.
If no reading across top two screws, then move to top of tank.
4) Open connection point where wire connects to heater.
Test across both insulated wires should get reading of 220-240 volts.
If no reading, move to circuit breaker box.
5) Mark water heater breaker.
Turn off all breakers except water heater breaker and main breaker. (and breaker to light fixture where box is located)
Do not hold or touch or lean against anything metal.
Stand on dry boards and wear dry clothes.
If main breaker is OFF, the big wires that connect to main breaker are still HOT.
Remove box cover.
240Volt breaker has 2 wires connected with screws.
Test across both screws for 240Volt.
See if wires are loose.
If there is no reading, then breaker is not working on one leg.
To double check, move water heater wires to another same-size 240V breaker and then put ear against water heater to listen for bubbly-fizzing sound.
6) If you are getting 240 to water heater, then wire inside tank could be loose.
Do 30 minute troubleshoot:
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on timer.
Jan 09, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Electric/gas. Will not get hot on electric setti...
Re: electric setting. Are you sure all switches are on, breaker in panel, any wall switches, plus switch usually at back of water heater where hydro connects as well. If yes, you may have to remove cover where power cable at back is connected (shut off breaker and any switches, and test to be sure power /hydro is off to water heater before removing cover) Are you experienced in this area? If not, it may be smart to get a technician or electrician to test for power from there.There should also be a reset as well in there on thermostat. Thermostat and ECO can be tested as well for continuity while cover off.
As far as gas not shutting off on gas, thermostat and ECO should be tested for proper operation as well as proper positioning.They should be up against the tank in order to work properly,
May 21, 2010 | RTO Atwood Water Heater - 6 Gal LP
Electric heating not working
Make sure switch on water heater at back where electrical wire is attached is in the on position, as well as any breaker marked for water heater. Some RV's also share a connection at a switch by counter in kitchen that only allows either microwave, or water heater, not both at same time. Possible that ECO, Thermostat assy in behind black cover on outside may be faulty, but not very likely. If you verify that there is hydro to connection at back of tank, I would suspect element is faulty. Not uncommon to burn element out if it was on, before tank was full of water, or when tank was emptied for some reason.
Mar 27, 2010 | RTO Atwood DSI-RV Water Heater-6 Gallon
Kenmore Electric Water Heater/ Economizer 6
it usaly takes a few hours to heat up depending on water size check our breaker to see if it tripped out make sure all your wire connections are good u could take the front plate off and hit reset if you dont get hot water in a few hours ull probibly have to replace the trermostats and maby the elements its not hard to do good luck
Mar 06, 2009 | General Electric GE SmartWater Household...
General Electric GE SmartWater Household Water Filtration System - GNWH38F Logo
716 people viewed this question
Top General Electric Water Heaters Experts
Paul Carew
Are you a General Electric Water Heater Expert? Answer questions, earn points and help others
