Question about Maytag Dependable Care LAT9416
Maytag Dependable Care LA4910 washer. How to check the motor?
The problems persist.
Question 1:
Is my check switch okay? Between the white/green stripe and the redwire, it is 0 ohms when depressed (lid open position). This is what itshould be. However, there is 2000K Ohms between the black wire and thered wire when the white plunger is let out, which should be zero (doorclosed position). Pushing the white plunger in (opening door) does notchange anything.
Question 2:
If the check switch does not have continuity when the door is closed, then why is my fuse blowing?
Question 3:
Is my motor the real issue? How do I test the motor/motor overload protector?
(My lid switch moves freely and the resistance between terminals whenthe white plunger is depressed is 0 ohms and more than 200K ohms whenthe white plunger is let out. I think it is okay)
(Please note that while I was testing the tub for water drainage in thespin cycle, I filled the tub to the top and measured how much time ittook for the tub to empty in the spin cycle. It took more than 2 minsand hardly emptied (there was a sock stuck which has been removed).While this test was going on the motor sort of labored trying to spin atub full of water. It did for 2.5 mins and then stopped which is whenthe fuse blew)
5 Suggested Answers
tzweeb
  • 318 Answers
SOURCE: Maytag washer is full of water and is dead
this washer has a 2 switch system for making sure the lid is closed. you wont be able to just "bypass" it as they designed it to not allow that. what you need to do is replace the whole switch assembly. it comes with both switches and a fuse all together and that should make your unit run again.
you can change this yourself but be careful to get the wires onto the new assembly n the right places.
Posted on Dec 28, 2008
dh1200s
  • 335 Answers
SOURCE: Maytag Neptune Top Load FAV6800AWW -- tub/motor will not spin
Hey Cameron,
I saw you post today on another forum and did not have time to put my thoughts down before work. I agree not a clutch issue I had to :), you would be so lucky. I own the machine and can’t offer any more troubleshooting then what you have done, good job of that. Unfortunately the FAV6800AW/FAV9800AW SM doesn’t have a whole lot of support for troubleshooting beyond what you have done for this issue. I found more info from the MAH3000 manual on the technical operation of the motor controller (slightly different controller). Both machines use the same troubleshooting paths. Remove JP4 which is;
P1 Motor Control common
P2 Torque (to Motor Controller) see page 1-11 MAH3000
P3 Motor Control Tach (to control board input)
My WAG is replace the Motor Controller 1st, then Control board 2nd and a possible tach issue related to the motor. That’s enough WAGing,…. but with troubleshooting not a complete WAG :).
Take a look at pages 2-5 thru 2-11, I keyed in on page 2-11 in the MAH3000, it may give you some additional insight, I know we are dealing with different machine designs but I think the designs are close regarding motor controller, the motor and what the Control Board is doing and looking for with input from the Motor Controller. I wish the FAV6800AW/FAV9800AW SM gave this kind of detail for troubleshooting. There is a nice little troubleshooting table on 2-11.
I keyed in on this note;
The motor control monitors the signals and communicates this information to the machine control (control board). The purpose of this signal is to tell the motor when to energize each winding in the motor and to tell the machine control the actual motor speed.
Then this note;
Note: If the machine control board does not receive an input signal from the motor control/tachometer circuit (JP4 connector), the motor speed will rapidly accelerate for 5 seconds then shut down. The machine control will sense a "locked rotor" condition and the motor will stop. If the motor control does not receive an input signal from the motor, the motor will "****" for 5 seconds then shut down.
I don’t believe you have that condition. I have worked with a forum member who had an issue with the motor controller related to an Lr error, locked rotor error and replacing the Motor Controller fixed the issue. Form here I vote for an issue with the Motor Controller. Not having known good parts makes this a difficult job.
The control board is under warranty for 5 yrs from DOP, the Control Board is 2 yrs. Ebay is a good source 25001079
I would push Maytag CSV for both. I got them to send me a Control Board after discussing my troubleshooting and that I had a neighbor (me) that was a repair tech who would install. I also had to send them copy of my warranty not sure why they beeded that my machine was on file with them.
In your console you will find a Troubleshooting guide if you haven’t pulled it out already. It has the schematic for the machine which I find handy. If you want a soft PDF copy of the schematic I can e-mail you. Just ping me at dh1200s@yahoo.com. I use that for one-way contact, just respond back on this post if you ping me, I don’t check the account for month’s at a time.
With my limited knowledge I will try to help you. Good luck. Rich
Posted on Jun 20, 2009
Testimonial: "Awesome help and advice -- thank you to everyone!"
  • 37 Answers
SOURCE: Maytag Washer lid switch
Ohm out the blue/ blk terminals on the sw (remove wire harnes first and notate wire color connection) with an ohmmeter-- Reading should be zero (closed lid position)
Then ohm the ylw and white sw terminals-- reading should be 0 as well.
If I am not mistaken this sw has a plunger that sticks out, if hte unit goes off balance this could push the plunger in. to reset- pull the plunger out
Lou
AFFORDABLE APPLIANCE REPAIR
(949) 855-0788
SOURCE: I have a Maytag washer model # LAT9304AAE. The
My May Tag washer don't spin and it washs continously
Posted on Sep 10, 2009
Maytag dependable care plus washer. Top Loader works through all cycles, but will not initiate or complete final spin.
Bad lid switch wore out needs replace ment or you have bad pump and takes to long to drain send us a model #
appliancexchange@gmail.com
Jan 30, 2013 | Maytag Dependable Care LAT9706
WON'T PUMP DOWN OR GO INTO RINSE AND SPIN CYCLE
what about your lid switch?...have you checked it already?
tnx 4 using fixya,
drcool
Sep 27, 2008 | Maytag Neptune FAV6800A Top Load Washer
Dependable care model no LAT9806BGE Dependable care Heavy duty Now very noisey when spin drying.Have to stop machine. Viabration bad in the tub. Belts have been replaced. thanks
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Maytag Washing Machines
Old Maytag Dependable care washer - LAT8506
Need to replace the belt going to the transmisssion powered by the motor. these act like a clutch for the unit. It is worn out and needs replaced.
Jan 26, 2010 | Maytag Dependable Care LAT9206
Where is the lid switch for reset on a maytag dependable care washer
where is the lid switch for reset on a maytag dependable care washer
Dec 19, 2009 | Maytag Dependable Care LAT9706
Maytag dependable care plus washer (Model LAT
The belt turn the pulley, but the height of the pulley is worn out so it didn't push up a mechanism to release the brake and to engage with the clutch to make the spin.
You have to takethe shaft out to study how it works then it makes sense on what I 'm talking.
The pulley cost only $11 but it is a major laboring exercise. It is a good learning to have hands on to this problem. Good luck on replacing the pulley.
Aug 08, 2009 | Maytag Dependable Care LAT9706
I have a maytag washer (model -dependable care) and when we start the wash the motor just hums, the water does not fill, if we move the timer switch to rinse the motor engages and the unit works entire the...
Check your fill tubes remove the hoses and see if the filters are plugged, you are not hearing the motor humming. You are hearing the watervalve humming, the motor will not start until the tube is full of water.
Jul 16, 2009 | Maytag MDB6650A Built-in Dishwasher
My Maytag washer fill too slowly
There's a little screen at one end of the inlet hose that will clog up; remove that and clean it. Don't forget to reinstall it. You can buy a replacement at the hardware store; take the old one along, there are a lot of different sizes.
Jun 09, 2009 | Maytag Dependable Care LAT9706
Washer stops spinning in the middle of the spin cycle
Doe,s the water come on when it stops, it may have something to do with the balance of the washing load, if the water comes on it,s trying to rebalance it self.
Jun 01, 2008 | Maytag Dependable Care LAT9706
Washing Machines Logo
60 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
