Question about Air Hogs Havoc Heli Helicopters
My heli wont hover, takes a large spiral downward, always to left
It will hover for 2 seconds, then take a downward left spiral until it crashes... No combo of throttle or turning can make it do anything else. This has happened to 3 different heli's of mine (over time) but i'm just curious if this is their way of going to that special heli place in the sky, or if it can be fixed. I've tried weights on the opposite side... no avail.
    Problem Solver:
  • 6 Answers
You either need to charge the battery, or just keep tapping the r trim button.
Posted on Jun 30, 2009
Mini phantom helicopter operating problems
Throttle slowly push on, until you fly the plane slowly so far (oneself fumble balance hovering position. But the movement wants slow, after all, the air force and reaction force have a reaction time)
Trimming is your plane total 360 degree turn the regulation has two screw rotation speed, let autobiography speed equal, also will not autobiography, how to adjust to the half empty when hovering in the opposite direction to the plane of the autobiography twist
The direction of the plane is you another joystick control and control is go around and control is to adjust the direction
Dec 07, 2012 | Toys
My helicopter will not hover!
If I understand what you're describing, the heli will fly properly at the start of each flight then becomes non-responsive and crashes. When you begin again, the same thing happens.
If that's correct, then it sounds to me like the heli is flying out of range of the transmitter. Check the batteries in the transmitter. If the batteries are ok, then check the distance to be sure you're staying within range. If you are within range, are you remembering to turn on the transmitter before connecting the heli battery? Did you properly bind the heli to the transmitter? Any other flyers in the area that could be causing interference? Power lines nearby?
Another thing, if it does fly out of range, and if your heli is properly trimmed, it should stop and hover. If it's not doing that, then check that your controls are in the proper position before connecting the battery.
Hope this helps.
Randy
Please remember to rate my response.
Aug 08, 2012 | Align T-rex 100x Microhelicopter Super...
I have a kenmore elite model 23022100 type 111 - The problem is the top part to my agitator wont do the complete downward spiral spin.. It just hesitates and goes back, hesitates and goes back.. I was told...
It is supposed to spiral the clothes downward ,the part in the top of the agitator called the dogs are wore out and need replacing. Watch this youtube video for step by step directions of how to replace the dogs. The exact part number you need is also in the title of the video .
http://www.youtube.com/watch?v=0GQh8JLqVv8
Gene
Aug 04, 2011 | Kenmore Washing Machines
My Syma 107 will not lift off the ground. It lifts a little bit and thats it. Its only a week old.
r u charging from the controller? if so put luthium aa batterys in controller the ones you have in there now may not be giving a full charge, you r turning the controller on when charging heli right? wait for the chareer light to turn back to green from red will tell u charge is done. u must have a computer 2 have posted this so charge ur heli from computer wait 4 it 2 light up red (the usb plug) b sure heli is off when charging the little swith should b forward toward nose of heli if it still wont lift off after a good charge b sure the top part of the blades are tight on shaft, its the two screws just under the top blades 1 of the 2 must b tight on the shaft or it wont get enough power if it is slipping, if it still wont lift off u may have a bad li po battery never run it way down!! always stop flying when u c the heli start to not have enough power to hover, always stop and let batt cool dn then charge, then after charge try 2 wait 4 a little bit b 4 flying 2 let batt cool from charging, i know it is very hard 2 wait, hoppfully u have not fryed the battery if u still cant get it e mail me and i will help u get up and flying good luck the s 107 is my main bird i work on them 4 friends all the time if i had it 2 look @ u would b fly n n 5 mintues my e mail is pznuraz@yahoo.com
Jul 29, 2011 | SYMA Toys industrial New Syma S107 Mini...
My S107 does not hover very well. It moves in a large circle on its own. It isn't the trim as it doesn't spin around the axis of the rotor. It points in the same direction but slowly moves left, back,...
The upper shaft 'T' head has a broken pin in it (the part that holds the blades. You can flip the heli upside down and slightly rotate the blade housing back and forth and IT SHOULDN'T do that. Another way to instantly identify it is dislocate the rotor head links and the upper blade housing should instantly separate) It's made of plastic.
Anyway, It's also called the "T.B.E." Toilet Bowl Effect. It's not 'really' what's taking place, it's move of a cyclic issue but the effect looks like it's swirling in a toilet bowl... You need to replace the inner shaft basically on the upper rotor. They cost anywhere from $4-7.00 bucks. It took me about 2 days of researching and purchasing another one to finally figure it out. There was another website that says the balance bar is it or the gyro has gone bad; this simply isn't true.
Cheers!
Jan 05, 2011 | SYMA Toys industrial New Syma S107 Radio...
Hi i have a futaba gy401 gyro with a s9254 tail servo, i had a crash and since then my tail servo constantly wags from left to right every time i switch on heli, i have tried putting the gyro on another...
Hi
If you put the gyro on another helicopter and have the same problem then you'll need to replace it. I've tried repairing these in my lab but just not worth the effort. Good luck
May 02, 2010 | Toys
Air hog havoc goes up and down just fine, no steering control
The steering control only makes the copter rotate.
But if the heli is properly balanced a right turn should get you some forward motion. A left turn should just make it spin back to the left.
Adding weight to the front of the copter will give it continuous forward motion. Then you will lose the ability to hover.
If you visit the Air Hogs website (www.airhogs.com), select "need help" and then Havoc Heli, then crash course, the video will show you how it works.
I also find that climbing makes the heli spin left and descending makes it spin right. So full right for initial startup, then a little right when climbing, and a little left when descending helps to smooth things out.
Keep in mind that this is a very small and cheap helicopter. It took me a while to get used to flying in circles to the right but with practice I have been able to get it to go somewhat where I want it to. I can take off and land from the coffee table without crashing.
Jan 15, 2010 | Air Hogs Havoc Heli Helicopters
Spinning no matter what i do
Issue: Heli spins to the Left (counterclockwise) uncontrollably.
Problem: Tail rotor not turning fast enough, Dragging.
Background: My son's Heli Cage also started spinning to the left after he had flown it a couple 3 times. The trim and direction stick could not compensate. One time, the tail rotor came off during a crash. It was put back on and ran fine a couple more times until the dreaded left spin. I began to troubleshoot the issue. I checked for damage, hair and whatever else on the shaft. There was no obvious signs. When I pulled the tail rotor off, I noticed that it came off very easily. I put a new one on it and problem solved.
Diagnosis: the tail rotor shaft was spinning inside the rotor. This prevented the tail rotor from turning the correct speed.
Corrective Measures: replace rotor with new one. Avoid hitting the rotor while it is spinning...good luck! :-)
Mar 02, 2009 | Air Hogs Havoc Heli Helicopters
Air Hogs Havoc Heli Helicopters Logo
606 people viewed this question
Top Air Hogs Toys Experts
jasiel murphy
ray gallant
Are you an Air Hogs Toy Expert? Answer questions, earn points and help others
