Question about Cyberhome CH-DVD 300 DVD Player
I have a CyberHome DVD 300. It will not load disc.Indicates that no disc inserted. I have cleaned the disc to no avail. I have the problem of dvd not loading, or getting a "bad disk" or "no disk" readout. Occasionally, after much "coaxing" the disk will load and play. I removed the cover to clean the lens; however, there is a steel shield over the space where the lens is. The shield is mounted with jewelers screw and (apparently) lok-tite. I can't budge them - thus can't get to the lens.
    Brigadier General:
  • 3,614 Answers
HI THERE,
do a lens cleaning on the unit, the optical lens could be dirty.
Posted on Mar 06, 2009
I have a Cyberhome 300 DVD player and whenever I put in a disc it will say loading for 2 seconds then gives me the message of no disc. I took the outer casing off of the player to reveal the drive itself...
Good day!!!
That problem is cause of dusty or defective optical cd lens..
please try to clean it the lens or replace it to fix your problem..
if you need specific solution and more help...Please try to click this "
Fix No-disc error on DVDs" and try to purchse my service..
Thank you for using fixya..
Oct 06, 2011 | Cyberhome CH-DVD 300 DVD Player
MY CYBERHOME DVD PLAYER IS READING INSERT DISC AT ALL TIMES AND WILL NOT PLAY ANT DISC. HOW TO RESET CYBERHOME 300 DVD PLYER?
I am sure problem on Laser,may be it does not read any disk.So all times it say insert disk.You can better opportunity replace this damage laser.
Aug 10, 2010 | Cyberhome CH-DVD 300 DVD Player
My CyberHome DVD 300 says "bad disk" every time I load a dvd.
pls check ur dvd player optial pickup lense.try to clean or replace.
Dec 28, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 300 not stuck on main blue Cyberhome screen
It may not be able to read the DVD because the laser is dirty. First try to reset the system ( with no disc inserted, open then close the disc tray and hold the stop switch on the UNIT NOT THE REMOTE for six seconds). Then with the disc tray open using a can of "AIR DUSTER" - dry air in an aerosol can, insert the can nozzle into the disc tray cavity and spray away. That may blow off any dust on your laser eye. Try it again and if it still wont work,unplug the unit and remove the six small Philips screws that hold the cover on( it pivots up and off from under a lip in the front panel), plug it back in and open the disc tray exposing the laser and clean the lenses with Isopropyl alcohol and a q-tip. Do this GENTLY you don;t want to disturb the laser alignment. Dry with another Q-tip or the Airduster and re-assemble. Note well the unit will be POWERED with the cover off so BE CAREFUL. Just did this with mine and it now works like a charm again.
Dec 05, 2009 | Cyberhome CH-DVD 300 DVD Player
Failure to load a dvd.
un plug the the dvd and take top off, carefully clean the lasor with a cotton bud.
If still no good, lasor died.
Buy new dvd
Sep 29, 2009 | Cyberhome CH-DVD 300 DVD Player
The screen says no disc even when I put a DVD in
Dear friend,
Pls clean ur dvd palyer lense or replace ur lense
Mar 28, 2009 | Cyberhome CH-DVD 300 DVD Player
you will need to remove the cover and clean the laser eye with rubbing alcohol and cotton swab (q-tip)
Mar 04, 2009 | Cyberhome CH-DVD 300 DVD Player
Cyberhome 320 wont load discs
This dvd's fails because a dry capacitors on the alimentation source you need to send to a repair service center.
May 13, 2008 | Cyberhome CH-DVD 300 DVD Player
After loading every disc displayes "wrong disc'
are they bootleg dvd's? if not try getting a lense cleaner because wrong disc means it's reading your dvd's as .mov files which only play on quicktime in a computer. if it reads your cleaner as wrong disk too then get yourself a refund cuz it has a motherboard malfunction.
Dec 02, 2007 | Cyberhome CH-DVD 300 DVD Player
DVD Player stops in "Loading..." mode
1. Check that disc is encoded for your geographical region. A disc from Europe (Region 2) will not play in a North American (Region 1) player. 2. Turn off player with disc inserted, unplug temporarily from wall outlet, plug back in and turn back on. 3. If your player has a transportation lock (usually a plastic screw on the bottom of the unit), make sure that it is not engaged. 4. If you have an older player, check with the manufacturer to see whether an update to the firmware is available. Many newer DVD titles with lots of special features are famous for causing problems on older players. if nothing helps, call for service.
Sep 12, 2005 | Cyberhome CH-DVD 300 DVD Player
Cyberhome CH-DVD 300 DVD Player Logo
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
