Question about Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive
I can't fing my 2nd cd rom in my pc anywhere.
I had added one more cd rom to my pc. it is opening and can b closed also...but its not shown by my pc anywhere.
its samsung combo drive and was working earlier.......
  • Samsung Master
  • 5,345 Answers
The good thing is that you have power to the drive. Is it a SATA or IDE drive? Have you checked that the cables are fully seated on both the drive and the motherboard?
If it is an IDE drive, is it on the same cable as another drive? Did you set the jumper to match the master/slave connection of the cable? Consult your manual if needed. Most of my IDE drives actually have the jumper labels on the back of the drive (next where the IDE cable plugs in). There are 3 options - cable select, slave and master. I've never had much luck with the cable select jumper option.
If it is a SATA drive, you might have a bad cable.
Posted on Mar 06, 2009
My cd /dvd rom (dvd/cd burner) is hide..my pc doesnt recognize it..help please..i dont know if i lost a driver
Click start control panel administration tools computer management device manager scroll down cd-dvd rom drives you might see a yellow question /exclamation mark ? ! or a red X right click to update driver You might have to physically unplug the leads for this cd/dvd computer then plug them back in restart your this should activate the found new hardware wizard. If this does not fix the problem it might be a registry problem "you only need to do the following" if you cant see your disk drive in windows explorer Close all open programs Click on Start, Run, and type regedit and press Enter Click on the plus signs (+) next to the following folders HKEY_LOCAL_MACHINE SYSTEM CurrentControlSet Control Class {4D36E965-E325-11CE-BFC1-08002BE10318} This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column. Upper Filters Lower Filters Upper Filters.bak Lower Filters.bak If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Feb 26, 2013 | Acer Aspire X1200 PC Desktop
My pc does not recognizing optical drive
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone. Hope this helps.
Jan 19, 2013 | Dell Vostro 1510 Laptop
MY CD TRAYS WILL NOT OPEN ON MY HP PAVILIAN A1737C AND THE BUTTONS WILL NOT PUSH IN. PLEASE HELP
Try this:
Start>Computer>Right click on CD ROM drive> eject.
If you do not have a CD ROM drive in Computer (Vista & Windows 7) or (My Computer in XP)
Try This:
1) Close all open programs
2) Click on Start, Run, and type REGEDIT and press Enter
3) Click on the plus signs (+) next to the following folders
* HKEY_LOCAL_MACHINE
* SYSTEM
* CurrentControlSet
* Control
* Class
* {4D36E965-E325-11CE-
BFC1-08002BE10318}
4) This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
5) If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
6) After deleting the keys, close the Registry Editor
7) Reboot your computer
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone
Aug 20, 2012 | HP Pavilion Computers & Internet
Sony Optiarc AD-7261S Not detecting
click start Control panel administrative tools computer management device manager scroll to cd/dvd rom drives + to expand could be a yellow question or exclamation mark ? ! or a red X right click update drivers
you might have to physically unplug the leads for this cd rom then plug them back in this will activate found new hardware wizard
you need only do the registry check if you cant see the drive/s in windows explorer/my computer
to check the registry
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps you
Feb 24, 2012 | Sony Optiarc Computers & Internet
Bought a Sony optiarc AD-7261S, but have an IDE connection, so got a ADP-06 bridge board to connect the drive using my IDE cable. The Sony is the 2nd cd/dvd drive on this computer, and after plugging it...
you might have to physically unplug the leads for this cd/dvd drive restart your computer then plug them back in this should activate the found new hardware wizard or you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device Click start control panel administrive tools,computer management,device manager scroll down cd-dvd rom drives you might see a yellow question mark ? right click you will have options to update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall if this does not fix the problem it might be a registry problem if you cant see your disk drive in windows explorer
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Apr 30, 2011 | Sony NEC Optiarc Sony Optiarc...
My Optriarc DVD RW AD-7580s scsi cdrom device is not functioning. This built in to my loptop. I want to be functioned it now.
if this drive is not showing in my computer
hope this helps or
you might have to uninstall then reinstall your cd rom or uninstall the driver then reinstall for this device
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
hope this helps
Jan 14, 2011 | ASUS M2N-MX Motherboard
Code 39 dvd drive wont even reconize but will open and close
Hi. This is a registry problem which pertains to DVD/CD ROM drive. Please follow the troubleshooting procedure below.
  • HKEY_LOCAL_MACHINE
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • {4D36E965-E325-11CE-BFC1-08002BE10318}
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
8) Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
Jul 29, 2010 | Computers & Internet
The DVD/CD-Rom device does not work.
* SYSTEM
* CurrentControlSet
* Control
* Class
BFC1-08002BE10318}
* UpperFilters
* LowerFilters
* UpperFilters.bak
* LowerFilters.bak
May 07, 2009 | Dell Computers & Internet
Optiarc ad 7530a
  • SYSTEM
  • CurrentControlSet
  • Control
  • Class
  • UpperFilters
  • LowerFilters
  • UpperFilters.bak
  • LowerFilters.bak
Mar 18, 2009 | Computers & Internet
Fing load option
do u need insert option or not
download 2 softwares for to open cd rom or close cd rom in
www.softpedia.com
www.filehippo.com
+919985064600.
ur's kishore chowdary.
Mar 10, 2008 | Microsoft Windows Server Standard 2003 for...
Samsung (SHM522CBEWN) CD-RW/DVD-ROM Combo Drive Logo
53 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
