Question about Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper
Error message -no loop current
When faxing i get a line connection the fax reads but then an error message comes up saying-no loop current as well as an error report. What do i do to fix this problem?
  • anniewalklet Mar 16, 2009
    my machine says need new card and no loop current does anyone know whats wrong. thanks
    Genius:
  • 2,120 Answers
It can't find a DIAL TONE check the line with a regular phone.
Posted on Mar 07, 2009
Sending fax error message."Phone
No. Most of the time this "phone line error" can be caused by the telephone connection or issue on the phone line where the fax machine is connected.
Hope this will help.
Mar 27, 2011 | Office Equipment & Supplies
My brother mfc-490cw I can't send or recieve faxes.
According to the User's Manual for the Brother MFC-490CW:
  • Poor Line Connection indicates an issue with your telephone line (Page 136). If you are sharing the fax line with any splitters or computers, try connecting the MFC-490CW directly to the phone jack and send a fax. If you are still getting a Poor Line Connection error message, call the telephone company and have a repair technician check your telephone line.
  • Out of Memory error message means the machine's memory is full (Page 138).
    Try pressing Stop/Exit and wait until all current operations finish and try again.
    Try clearing the data in memory. To gain extra memory space. turn off Memory Receive (See Page 48).
    Try printing the faxes that are in memory (See Page 49).
  • System Busy error message wasn't in the manual, but I suspect it means there's a current operation in progress and the machine needs time to finish before moving on to another job. Just wait for the current job to finish, then try again.
May 05, 2010 | Brother MFC 490cw Color Inkjet...
When i receive fax my fax says line error
You configure you fax program.Such as line type,fax number,or you follow user manual,how can use it?
It is problem setup or configure not problem machine.
Dec 03, 2009 | Samsung SCX 4521F All-In-One Laser Printer
Error message says fax failure
Check your phone line to make sure you are connected. If this is a newly installed fax machine, make sure the fax application is downloaded.
Sep 28, 2009 | HP OfficeJet t45 All-In-One InkJet Printer
OKIFAX 4580 - Comms error
Hi just a note to say first theing to check is that the phone line is connected at both ends to correct sockets and that the connector to teh fax unit is connected to the line socket and not the phone socket as this is the main cause of line errors.. Good luck you could also check to see of you need to dial 0 or 9 first before you dial your number as you ma y be on an exchange line.. also check the fax settings to see if you have set the line type correctly either pulse or tbx..
Jun 30, 2009 | OKIFAX 4580 Plain Paper LED Fax
Error 4103
A loop current problem indicates that the phone line is not connected to your fax correctly, the cord is broken or where you have plugged into the wall is dead
Jun 22, 2009 | Brother IntelliFAX 4100 Laser Fax
Sending error
I try sending a fax then the paper goes through it makes a loud beep and the message says theres been an error try again this happens all the time no matter who I fax. then it prints out error confirmation stating Mode G3 send error
Jul 29, 2008 | HP 1040 Plain Paper Inkjet Fax
Dynamode Internal Fax Modem 56K
i had same problem trying to receive faxes until i changed phone connections.
according to a motorola manual (link below) this has something to do with being connected to a "proper analog phone line".
i had the phone line running from wall to a newer gateway (maybe 8 months) dec 07 to a maybe 2 year old compaq. kept getting that loop current error on the compaq when trying to receive a fax until i elimated the gateway connection and plugged the wall right into the compaq.
here's a link that might help: http://downloadmirror.intel.com/12655/ENG/Motorola.htm
see section 6, troubleshooting. hope this helps...
Jun 27, 2008 | Computers & Internet
No loop current
I believe that with this model there are 2 places to insert a phone line and you may have them backwards, also, it could be a bad phone cord that your using... check these easy things first...
May 05, 2008 | Office Equipment & Supplies
No loop current
Check the line cable. Try inserting that line to another telephone unit. And if there's still no dial tone the problem is on the line itself. You should call your line provider. But if the line is ok, check the LIU connectors if it is inserted correctly. It the connectors are ok, then the possible problem is on the tel. line circuit on its mainboard.
Sep 13, 2006 | Philips PPF-531 Plain Paper Thermal...
Philips Magic5 Voice DECT Duo - Fax / copier - thermal transfer - 50 sheets - 14.4 Kbps Plain Paper Logo
1,175 people viewed this question
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
