Find the short, could be in the switch or a wire itself...and if you have a bulb out it complicates finding it even morenew fuse it, then turn things back on one at a time...should tell u where the problem is
Its in the overhead light rocker switch...if your looks funy..like its out on one side...its blowing the fuse
SOURCE: Dashboard and tail lights out on 97" Nissan Sentra
I took my pathfinder to U-HAUL and asked them to check the towing lights. There was a pinched wire by my tail light and they cut it and changed it out for me, it was $5. I am so glad that I didnt take it to Nissan. My second step was going to be getting a new dimmer switch..but the guy who worked on my car said that wouldnt be the problem. He also told me that replacing a fuse that kept blowing out was dangerous and after the first time to get it checked out. Learn something new every day!!
SOURCE: tail lights on 2004 nissan maxima out.
hey i just fixed mine with the same exact problem, look, all you have to do is open your 3rd fuse box which is next to your washing fluid on the passenger´s side under the hood, for that you need to remove the cover wich is pretty easy (5 staples all you need is a thin flat screw driver to lift the center of the staple and then the whole staple) then you take off the cover and then you open the fuse cover, you are looking for the TAILLIGHT fuse wich is the first on the upper row from right to left if you are standing on the passenger side looking towards the drivers side (you can also look for that fuse in the fuse box cover diagram) remembre is a 15A fuse, replace it, jaja and thats how you save some dollars. saludos desde guadalajara mexico.
SOURCE: No tail lights, tag light, dash board lights in 97 Nissan Maxima
If you don't have a manual, just get a test light, and ground it to your door hinge. At the back of every fuse, you will see part of the metal filament showing through. Touch your test light to each side of the fuse. You should have power to both sides of every fuse (when your key is on). If no voltage on one side, the fuse is burnt.
SOURCE: replaced tail light fuse, which turned on tail
most likely you have a short in one of the bulb connectors or the hot wire from them is pinched on medal somewhere. Or you have water intrusion shorting one out. Inspect the bulbs. Leave both bulbs out. install fuse. Press brake pedal several times and hold. Inspect fuse. if its blown its the pedal switch that's bad or a pinched wire from there. If good put one bulb in. Test again,, then the next bulb. If you see something obvious fix it.
SOURCE: 2000 Nissan Maxima. Headlights work but tail lights won't.
your dimmer switch is the proublem it is loose or just worn they wear even if you dont ever use the switch a common nissian proublem iv had the same issue
