Question about BenQ FP731 - 17" LCD Monitor
No power/dead i have a gateway monitor model#900G product #FPD1960 that will not power up. I have checked the obvious possible problems(bad power cord, loose connections,etc)Any suggestions?
    Sergeant:
    Champion:
  • 245 Answers
Try to turn it on the power switch on monitor.....and make sure all connection are ok
Posted on Mar 06, 2009
Gateway 19" lcd color monitor, product no. fpd1960 model no. 900g
The most common cause of power up issues with the Gateway FPD1960 monitor is a failure of the filter capacitors on the AIP-0100 power supply board in the unit. Here is a link to repair information for that board.
http://www.ccl-la.com/catalog/product_info.php?products_id=206
Nov 14, 2012 | Computers & Internet
I got a Gateway LCD 900G monitor, it keeps flickering and making hissing noises, what can i do?
Flickering could be a loose power connection but the hissing is indicative of a potential short. for your own safety, I'd get this to a TV type repairman asap.
Dec 25, 2010 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway 900G does not stay on, has power
the_princes, On the rear side of LCD screen that you look at are two each long, straight, cold-cathode-fluorescent-tubes that need to "LIGHT-UP"and provide pure WHITE light to be reflected through the LCD glass panel that you look at from the front side! If you don't have any luck with Gateway providing warranty service or doing a swapout with them, then you should possibly look into having it Refurbished by someone locally in your area. I highly recommend that you go to youtube and watch some video clips of LCD MONITOR REPAIR to see exactly what you are getting involved with. When making a post to tthis site you should always give some "history" along with the trouble "symptom" such as how old is unit and approximate total amount of "ON" time the unit has. I hope you can use the info provided. I'm louie12fix on fixya or lmistyrel@aol.com Bye for now.
Oct 01, 2009 | Gateway FPD1960 19" Flat Panel LCD Monitor
IC Power 19'' LCD-Will not Power Up- No Lites.
This is a follow up to my last submission about my discovery of bad caps on the FPD1960 LCD flat screen Gateway 19" computer monitor. To recap: After two and a half years of excellent graphics quality, my monitor suddenly went blackout. After pushing the power-on button, the screen would come on for 1-second, then go black. Repeat, again and again, same result; comes on for 1 second then blackout. THE REPAIR: After carefully but forcefully prying open the case, I unscrewed and unplugged then removed the screen and set it aside, then unscrewed and removed the power supply board. Sure as shootin, bulging (and slightly leaking) capacitors were immdiately apparant on this board. That other fella's submission was right on target. Search Wikipedia for "bulging capacitors" to get the inside scoop on this widespread problem. Major manufacturers are well aware of this issue, but fortunately for them it occurs some 2-years out'a the box, and after the warranty expires. This is one time I wish I'd bought the extended warranty! Anyway, I finally got my 5 caps from Ebay in the mail today. Specifically, they are 470uF 25volt 105-degree (use only 105's because some are right near a power transister heat sink---so I'll bet they get mighty friggin hot. After carefully replacing the old caps with the new (you'll need a solder ****** along with your solder iron), I reassembled, powered-up, and began to thoroughly enjoy the fruits of my labor. It's working like new once again. THE CAPS ON THE POWER SUPPLY BOARD ARE DEFECTIVE.
Nov 20, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Monitor doesnt work
You can check the fuse on the monitor and replace it. In case the fuse is OK check the cable connector, display card on the motherboard.
Thanks
Oct 17, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Gateway FPD1960 monitor power suply
Cleaning won't do it.
It probably needs all new capacitors on the board. are any canister looking components bulged up at the tops ? This is the most common problem on the ones I fix.
ebaysbammbammfran
Oct 10, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 power issue
I'm in the middle of moving so all my stuff is boxed up at the moment. If you want to send me your bad one, I can repair it for you.
Let me know.
Thanks.
Jul 30, 2008 | Computers & Internet
Gateway 19 in flat monitor Model 900G
Does the power button light up or blink at all ?
It probably is the power board/ inverter. I fix many of these.
To TeeKO, did you try moving it back to see if it was maybe a bad household receptical ?
ebaysbammbammfran
Jul 29, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
FPD1960 model #900G
Try running the factory reset on it.
Feb 23, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
BenQ FP731 - 17" LCD Monitor Logo
249 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
