Question about Kenmore 84052 Dryer
My Kenmore drier won't stop now! Perhaps timer isn't working?
Last weekend I posed the following question and got excellent advice:
My 2006 Kenmore electric dryer stopped running. We checked the plug and the breakers and don't see the problem. The codes on it are DWJR-ELE-2406028-FM54; 110.66652500. We can't find the owners manual. Any advice is appreciated! WE bought a new thermal sensor and now the dryer works, except it doesn't turn off when on the timed dry cycle. So the timer does count down from 40 min to 30 min etc down to 0 but then it just keeps running until we open the door. Can you provide a troubleshooting suggestion? Thanks in advance
  • g_tomkinson Mar 06, 2009
    This looks helpful. What does the relay look like? Where on the back of the drier would I find the relay?
    Thanks.
  • 6,784 Answers
Hi there. this is a timer issue. it counts down but, the actual shut off dial embedded in the timer mechanism is damaged for some reason. replacing the timer assembly will correct this issue. there are two parts to a timer. One, it times and last, it initiates the shutoff. the second action is not working properly. to be sure, check the relay before you purchase the new timer.
I have also provided you with a complete manual set that you can access and print out if you would like.
Click here for your manual
Click here for your instructions Guide.
Posted on Mar 06, 2009
  • 57 Answers
SOURCE: My 2006 Kenmore electric dryer stopped running.
if you take the back off of your dryer and look for a little white thermo fuse with 2 wires on it if you unhook the wires and plug them together than start the dryer if it starts shut it off and replace the fuse and clean your venting
Posted on Mar 01, 2009
vickygomar
  • 460 Answers
SOURCE: Kenmore electric dryer Mod. 100.66662501, type
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
Posted on May 13, 2009
erpaalai
  • 999 Answers
SOURCE: It appears the heating element went out on our
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
Posted on Jul 07, 2009
hunter19_46m
  • 7482 Answers
SOURCE: My dryer won't turn on
Make sure that the problem is not a broken belt, or a belt that has slipped off of the motor pulley or idle arm pulley.
Look to see if the motor is running first, sometimes you cannot hear the motor running but it is.
Also you can check your breakers to see if one is kicked out.
This problem can also be caused by a faulty start switch.
If this is not the problem than it may be time to call the repairman
Posted on Sep 26, 2009
SOURCE: Where do you find a heating element for a Kenmore
partsdirect.com They will have every part on it.
Posted on Nov 10, 2009
I have a kenmore washer model#110.29832800 that will not start.if i put it in the spin cycle it turns on but will not start at the beginning of any cycle.it was working fine yeaterday.
then perhaps the timer contacts are burnt .sometimes they can be cleaned and last awhile but usually will need replacement of the timer soon
Jan 02, 2016 | Kenmore Washing Machines
ASUS K54C won't power from battery
Take it back to shop if it's only 2 weeks old
May 06, 2017 | ASUS Computers & Internet
Kenmore 417.43142200 final spin is slow
obviously the timers contacts are bad so replace the timer.
May 16, 2017 | Kenmore 43142 Front Load Washer
I've changed the belt on my indesit is60v but now it will not start could it be a loose wire? my test pen says power is going from the start button to the timer
Just because power is getting to the switch doesn't necessarily mean the switch isn't bad. It is also possible that the motor or timer is defective.
May 12, 2012 | Indesit IS70C Electric Dryer
My S5211 is 5 months old and was running perfectly. Last weekend I took it out to vacuum house but it would not start. I checked the fuse in the plug but it was fine. I replaced the dustbag but still it...
if you put everything back in place properly it should be working,check dust bag properly seated, and cover reseated, still not working do as planed, take it backto the shop, hope this helps
Sep 01, 2011 | Miele S5211 Deep Black Vacuum Cleaner...
I have an Intermatic ML200RT outdoor timer. The timer moves correctly but the lights do not come on. It is less than one year old. Can it be replaced free of charge? It says it has a 5 year limited...
ML series power packs from Intermatic/Malibu have 5 year limited warranty.
Open following link for power pack troubleshoot checklist and power pack resources.
Intermatic links do not work on weekends, April 2011
http://waterheatertimer.org/Malibu-power-pack-stopped-working.html
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 28, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
Drier button does not work when push it to start machine
You need to check the dryer door switch. I may be bad. If the timer is clicking it is probably working fine. Also you need to check that the dryer is getting power to the unit. Check your breakers and also pull the unit out and look at the dryer cord. Check the terminals for a short or burnt looking one. Once you have established you have power going to the unit, you can find where the comunication stops within it.
Apr 09, 2009 | Kenmore Dryers
Kenmore C978-66792-1 fridge: defrost ices and stops fan
It should just be your ice maker wires and wouldn't be the issue with this fridge
Feb 10, 2009 | Kenmore Refrigerators
Kenmore Dryer Timer does not advance
Timer resistance is way too low. You may have misswired the new timer. Basically, when the dryer motor is running, the timer motor gets voltage 115 volts.
Apr 14, 2007 | Kenmore 64902 Electric Dryer
Kenmore 84052 Dryer Logo
445 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
