This refrigator makes a loud poping/cracking noise about 10 to 15 minutes apart 24/7 since purchased. Note, the ice maker and electronic board for the ice maker have been replaced due to very SLOW ice production, about one harvest of ice in 24 hours.The cause for the noise problem is unkown. The noise sounds as if the plastic interior is expending and contracting which is causing this on going loud noise.
Q: Is this a common problem with this model or is this something that can be fixed??? HELP!!
it sounds like the unit is in defrost. the noise is the souind of the ice breaking up. also you might be able to increase your ice produsction by setting the ice sensor to 17.5 degrees from the current 0 degrees
Was this helpful?
Yes
No
Popular Solutions for Samsung RM255LASH Side by Side
my side by side refrigerator SR-S22DTC control panel changes temperature by itself what could be the...
(More)
my side by side refrigerator SR-S22DTC control panel changes temperature by itself what could be the problem and how you you remove the control panel.
I change my water filter, and when I try to reset the change filter indicator light on the front...
(More)
I change my water filter, and when I try to reset the change filter indicator light on the front door, after touching the light for 3 seconds the light never change colors.
Lost power to the house but when power came back on, the control panel flashes with 98 on the left...
(More)
Lost power to the house but when power came back on, the control panel flashes with 98 on the left and A8 on the right. can not control or reset panel
ice not dispensing and the frozen food and ice are slowly melting.... fridge part is okay..this is...
(More)
ice not dispensing and the frozen food and ice are slowly melting.... fridge part is okay..this is for the samsung quattro..thanks
