Question about Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum
No liquid dispensed
When I sqeeze the trigger for relase of cleaner, nothing happens. I can see the rotating indicator not moving. I cleaned it out and all of the exterior openings. How can I get into the suspected clogged tubes?
Thanks.
  • 2 more comments
  • Anonymous Mar 13, 2009
    I can not get anything out either. The spinner doesn't spin. I can however get liquid out of the hand tools but the spinner doesn't spin.
  • scotts_lass May 01, 2009
    changed water pump and looked at the schematics and i seem to be missing two small pieces at the base of the trigger handle towards the bottom...and would like to replace them instead oof buying a new handle ...any suggestions?
  • Anonymous May 10, 2009
    Water won't come out of either of mine
  • jack1970 May 13, 2009
    I too have the same problem, no cleaning solution or water coming out when I squeeze the trigger. The flow indicator does not spin. How do I clean out the tubes and where do I find them?
I cleaned the water and cleaning liquid tubes and it solved the problem! Thanks.
GMC
Posted on Mar 08, 2009
Hoover floormate fh40160 won't dispense solution
Hi there! Sometimes it is necessary to prime the trigger to get the solution flowing. Try these quick steps.
1. Recline the handle.
2. Pump the trigger vigorously about 60 times.
3. Power the cleaner on and squeeze the trigger for 60 seconds.
The cleaner should start to dispense the solution. Be sure you are using only the recommended cleaning solution to avoid internal damage. If your Floormate is still not dispensing there could be an issue with your pump. We would recommend taking the cleaner in to a Hoover authorized service center for repair. Follow the link to locate the nearest service center to you. Service Center Locator
Hope this helps!
Jul 07, 2014 | Hoover Floormate H3000 Upright Wet/Dry...
Vax problems
Hi, it's Jeremy from Crucial Vacuum.
There are a few potential solutions you should try. First, check to make sure that the is nothing blocking the fluid on both ends of the liquid reservoir. Check to make sure there is nothing blocking the inside of your reservoir preventing the liquid from traveling out of the dispenser. If nothing is there, then check the other end of the reservoir on the outside of it where the liquid flows out to make sure nothing is blocking the flow. If each of these solutions do not work, the issue may be related to the trigger mechanism. The trigger may not actually be functioning and may need to be replaced. To determine this remove the reservoir and pour liquid straight through the dispenser and see if it comes out. If it does, the issue is most likely the trigger and you will simply need to swap it out for a new one.
You can purchase direct your replacement vacuum parts from Crucial Vacuum with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com
I hope this was helpful. If you would like further assistance, please feel free to give us a call at 877.750.9239. We have helpful and friendly customer care representatives on the line ready to assist you.
Jeremy Lerner
Crucial Vacuum Customer Care
Jun 29, 2014 | Domena Window Steam Cleaner Handheld...
Water and solution do not dispense.
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
wrh
Jun 30, 2010 | Bissell 8910 ProHeat Clear View Upright...
Water is not dispensing to clean carpet. Water
the problem is the heater is cloged you can drill it out to clean it
Dec 10, 2009 | Bissell 1699 ProHeat Clear View Upright...
The machine turns on and the indicator seems to be spinning but the water is not moving.
Operating the trigger does not dispense water into the spinning brushes - is that the problem?
If so, remove the clean water tank and look in the opening behind the black grommet that seal the water tank. Operate the trigger and look to ensure that the valve is operating (moves downward when trigger is pulled). If it does not move, the trigger shaft is stuck or broken and will need to be repaired.
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Steamvac will not stop dispensing cleaner. Once I pull the trigger it starts to dispence liquid and will not stop even when I release the trigger.
This sounds like a faulty solenoid that may be intermittantly working. I would take it to a repair shop for evalualtion
Sep 23, 2009 | Hoover F7431-900 SteamVac Vacuum
Bissell Carpet Cleaner pro heat- water doesnt come out
The screw that is located in the center of the handle, that holds the assecory hose holder must be tight. My screw was missing, put one in and cured the problem. Sounds stupid but it worked. Got this idea off the Bissell web site. Also if you have a pump belt it may need replacing.The cover is on the side of the machine. Go to the Bissell web site and look up by your model # and name of machine. There are several quick fixes that you can do yourself. Why pay for expensive repairs when the Bissell site will help you for free. Good luck.
Jun 28, 2008 | Bissell Carpet Cleaner Powerbrush Deep...
Flow Indicator Not Moving, Not Dispensing Anything
The water tank and the solution tank both have red gaskets that attach to the bottoms of the tanks. Make sure they are on properly, I just had the same problem and spent hours taking apart the machine and inspecting lines to find out it was a gasket.
On my machine the red gasket for the solution got stuck in the chasis for the machine. The bissel website alludes to this, but isn't very clear.
Other posters talk about the heaters, or the lines being clogged and I immediatley inspected these areas, turns out it was a gasket that was hiding in the chasis. Both the water tank and the solution tank should have one, and make sure they don't get nestled in the chasis!
Apr 13, 2008 | Bissell 9500 ProHeat 2X CleanShot Upright...
Does water squiret out of the hose, if it does, then check the heater inside the handle to see if it is clogged where the 2 water lines hook to it. The other reason, you may ghave a bad pump. But check the back edge to make sure the top isn't coming loose from the base. Check the bottom of the tank to be sure round seal is on the tank on the cap and valve. Sometimes they come off and wind up in the hole.
Mar 15, 2008 | Bissell 1699 ProHeat Clear View Upright...
Bissell 7920 ProHeat Pro-Tech Upright Wet/Dry Vacuum Logo
391 people viewed this question
Top Bissell Vacuums Experts
Jim Parker
Jim Parker
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
