Question about Epson Stylus C84 InkJet Printer
I just replaced all 4 ink cartridges on my epson stylus c84 printer. The 2 left buttons on the printer are flashing and it will not print. I have tried turning it off and then on but it still won't print. Thanks, Linda
  • lsweeten Mar 13, 2009
    I have the problem with the waste ink pads in my Epson C84. Or at least I think I do. I downloaded the SSC utility - download from
    http://www.ssclg.com/epsone.shtml
    But, I am not sure how to run it. The menu bar does not say anything about reseting the protection counter so I am afraid to try anything as it may make matters worse. Can you help
    Lee
  • 353 Answers
See the on-line handbook
http://support.epson-europe.com/onlineguides/en/sc84/index.htm
and look in Problem Solver, Diagnosing the Problem, Error indicators. If the two lights are flashing together, you have a paper jam. If this is the case, you should be able to pull the paper out from the front or top. If the lights are flashing together, and you can't see any paper jamming the printer, post a new comment to this effect for more help.
If the lights are flashing alternately (Unknown printer error), it usually means the Waste Ink Pads in your printer are saturated with ink and the waste ink "protection" counter has exceeded its limit. You can restore your printer to a working condition immediately by using the SSC utility - download from
and use it to reset the Protection Counter. This will stop the lights flashing and restore normal operation. However, remember that eventually ink will overflow from the waste ink area and make a dreadful mess, so you should change the waste ink pads before this happens. This requires the disassembly of the printer.
If you decide to have a go at replacing the ink pads yourself, report back with a new comment and I will provide further help.
Posted on Mar 09, 2009
  • 2 more comments
  • theresa May 26, 2011
    i WOULD LIKE FUTHER INSTRUCTIONS ON HOW TO CHANGE INK WASTE PAD PLEASE, P.S. SORRY ABOUT ALL CAPS NOT YELLING i FORGOT THEY WERE ON UNTILL NOW
  • Gerry Millward
    Gerry Millward May 27, 2011
    Hi theresa
    Can you confirm your printer model please
    Gerry
  • theresa May 27, 2011
    epson c84
  • Gerry Millward
    Gerry Millward Jun 02, 2011
    Hi Theresa
    Sorry to be tardy. Right click the SSC icon in the system tray (bottom right corner of screen) and a menu will appear which includes Protection Counter. Reset this and it will restore printer operation. To replace the waste ink pads will require you to dismantle the printer, which is far from easy with this model. However, if you are sure you want to give it a try, send your email address to test@millward.org.uk and I will send you instructions.
Both red lights are flashing on printer Epson Stylus C84. I did not go to the utility to replace a black ink cartridge (forgot), replaced it and now it is stuck.
You will need to get it to reset to normal. If you tried turing off/on and it does not clear, try the following:
1) Unplug the power from the rear of the printer for 30 seconds.
2) Plug it back in and press power button. if you hear the carriage moving, immediately pull the power cord out againg from the rear. If it does not move, open the lid as if to change cartridges...when it moves, pull the plug. The idea is to stop it where you can remove the cartridges.
3) If you are succesfull with steps 1 & 2, close the lid and plug the power cable back in.
4) Power on and see if it prompts you for cartridges.
5) If so, install the cartridges in the proper manner as instructed in the manual.
Apr 30, 2010 | Epson Stylus C84 InkJet Printer
C84 stylus - put new cartridges in and it doesn't print full text or all color
Did you use Original Epson Cartridge? I have learned from experience, that Epson does not like generic ink. You must use Epson Genuine Cartridges. Hopefully, you haven't screwed up the printer, like I did. I did try cleaning the heads and doing everything possible. Use 2 cartridges of ech set, for cleaning, cleaning, cleaning. ......But Nothing.
Had to go out and purchase a new printer.;
Good Luck :0(
Comments: Nov 12, 2009- Funny. hahahahah,
Me too! I would say, about 2 dozen cartridges to be exact.
lol :0) :0) :0) :0) :0) :0)
Asker's Testimonial " Thank you. Called Epson also and they didn't say it as directly, but advised real Epson ink too. Hope I didn't kill the printer! Generic ink for sale " - mclamemo
Nov 29, 2009 | Epson Stylus C84 InkJet Printer
Printer Epson DX6000 ... all new cartridges .... will not print any text. I can print the head clean test page as well as the head alignment page ... but no text
You said all new cartridges.. But are they Epson Genuine Cartridges???? I had the same problem when I replaced with new, but generic cartridges.
After finally, going thru 2 sets of each, removed them and put in Genuine., and finally, everthing started printing fine. Weird , but true.
I suggested my answer problem below.
Good Luck :0)
Problem for Epson Stylus C84 InkJet Printer
Re: C84 I'm using generic ink, but the red
By mclamemo on Nov 12, 2009 re: C84 I'm using generic ink, but the red doesn't work at all. I've done all the printer cleaning programs and swabbed inside the printer with alcohol, and re-inserted the cartridge multiple times. it still doesn't print at all.
Also now even the black every few lines prints the top half of the line or the bottom half of the line, or its smeared, etc...
Help!
Best Solution
posted on Nov 12, 2009
cns assoc
Rank: Wiz Expert
Rating: 84%, 22 votes
Good Luck :0(
Asker's Testimonial
Comments:
Nov 12, 2009
- Funny. hahahahah,
lol :0) :0) :0
Nov 15, 2009 | Epson Stylus C86 InkJet Printer
Epson c84 printer not printing after installing new ink cartidges
Hi, Linda
You may buy cartriges of different producers.
Depending on producer on them can be or be not special yellow detachable labels.
These are an yellow labels must be removed from them. Then put cartridges back. And try to clean head 4-5 times. And check nozzle test.
Good luck.
Mar 06, 2009 | Epson Stylus C84 InkJet Printer
Cannot get LCD screen to show Replace Ink message
try this
1. Make sure your unit is powered and not printing.
2. Press the SETUP button and then use the select arrows until you see REPLACE INK, then press the COLOR COPY button. The ink cartridges will move to the replacement position.
3. Lift up the unit's cover, to access the ink cartridges.
4. Pinch the tabs on the front and back of the cartridge, and lift it out of the printer.
5. Before removing the new cartridge from it's package, shake the cartridge 4-5 times. Do not shake the cartridge once it has been removed from the cartridge holder.
6. Lower the new cartridge into its holder, then press down on the top of the cartridge until it clicks in place. Caution: Don't touch the green circuit board on the back of the cartridge, as you may inhibit normal operation and printing.
7. Repeat steps 4-6 for any other ink cartridges that require replacement.
8. Once complete, please lower the scanner and press it down until it clicks into place. The EPSON Stylus RX500 begins charging the ink delivery system.
The On light flashes and the EPSON Stylus RX500 makes noise. Charging takes about 30 seconds. When it's finished, the On light stops flashing and stays on steady. At this point press COPY to move back to COPY mode.
Caution: Never turn off the EPSON Stylus RX500 while the On light is flashing, unless the Stylus RX500 hasn't moved or made noise for more than 5 minutes.
May 20, 2008 | Epson Stylus Photo R300 InkJet Printer
Epson Stylus C84
Sorry but It uses Durabrite ink which tends to turn into hard gel if not printed at least once a week. Its less painful and expensive to just throw the printer out and buy a new one. I recommend the canon PIXMA ip3500. It lets you remove the printhead for cleaning unlike the Epson. If you want to try your luck at unclogging the printer heres a link to a unclogging kit but be warned that results are not guaranteed!
http://www.fixyourownprinter.com/kits/Epson/K89
The durabrite inks that EPSON invented is brilliant when you print pictures but it tends to harden very easily
Thanks for reading!
Mar 16, 2008 | Epson Stylus C84 InkJet Printer
Printer does not print
An ink supplier advised turning off the printer for 15 minutes, turn it on and try again. That worked once. Next time he suggested turning off printer, removing all cartridges, waiting 15 minutes, replacing cartridges. I couldn't do this without turning the printer back on and going through the replace cartridges routine. Now the nozzle check routine printed magenta and yellow only. I've run the head cleaner a number of times with no success.  Hope one of these suggestions works for you.
Jan 06, 2008 | Epson Stylus C84 InkJet Printer
Installing ink cartridges
go on line and type in epson c84 uses manual
Jan 04, 2008 | Epson Stylus C84 InkJet Printer
BIG PROBLEM
If any of the ink cartridges are needing to be replaced, the Epson C84 will not print, you will have to change the cartridge, if you lift up the printer lid the carrier will stop at the empty ink colour.
Nov 14, 2006 | Epson Stylus C84 InkJet Printer
Epson Stylus C84 InkJet Printer Logo
190 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
