Question about Plumbing
Removing the hot & cold control knob from the shower.
My father has removed the actual knob, but there is some kind of stem or pipe that is sticking out now that we can't remove. Can you help?
  • 3 Answers
If you are referring to an old price pfister or Gerber faucet then you're probably talking about the faucet stems. Your local hardware should carry stem removers or "cow bells" in sets of 5 or 6. They will range in size depending on the stem you are removing. Insert into place then turn counter clockwise with a pair of pliers. Hope this helps.
Posted on Apr 07, 2009
    Problem Solver:
  • 6 Answers
You have to remove the large chrome nut that is holding the ball in the socket. Make sure you have the drain closed so you don't lose the cups and springs when they come out.
Posted on Mar 09, 2009
I have a mira duo shower why does it make a high pitched squeal when in use the shower is onley 3 months old and has done this from new
Hi Derek
I trust you are well
Sounds like it might be a air bubble in the waer pipes, try removing the shower head and run the hot and cold water together for a minute, then remember to FIRST TURN OFF THE HOT WATER then turn off the cold water and replace the shower head and test as normal.
Hope this helps
Kind regards
Aug 15, 2014 | Home
Climate control knob is backwards
Hi! Those knobs and stems are indexed. Most likely the knob is cracked and will go on in any position. Check knob/stem for a small metal D shaped sleeve that may have come off or stuck on the stem. Remove that and then buy a new knob.They can be purchased at most auto parts.They are in-expensive. Line up the D shape of the stem with the knob and push it on.
Apr 10, 2014 | 2005 Pontiac Grand Am
How to install a danco 10472 4z-24h/c hot & cold faucet stem
  • Shut off water supply
  • Open faucet
  • Remove knob
  • Unscrew old stem
  • Use flashlight to inspect seat for damage and corrosion. Dress or replace seat if necessary.
  • Install new stem
  • Reinstall knob
  • Turn on water supply and check for leaks
Feb 09, 2014 | Danco Faucet Stem
I can't seem to adjust the temperature once I've turned the shower on. Once it gets hot, I can't get it cooler.
is the cold water on! if yes you probably have to remove the cold water knob and stem, to investagate it. the rubber on bottom of the stem may have fallen off and blocking cold water flow. Just check it out !
Sep 07, 2011 | Graff Home
Middle valves not sending the water to shower head
the diverter screw has come loose in the diverter stem. It is the center knob that turns on
the shower. If it is american standard, they were noted for this. You may want to shut off
water to the shower itself at the shutoffs but USUALLY not necessary as long as you dont
bump the hot/cold knobs while removing the diverter stem.
Remove the cover and or screw from the handle and remove it.
then remove the decorative escutcheon cover and tube by unscrewing
it counterclockwise.
(There may be a small set screw on the underside of the cover to loosen)
The stem unscrews counter clockwise as well and may take a small pipe wrench to loosen
Sometimes the screw becomes lodged in behind the seat and requires patience and a
pick to extract it (a short burst of water may eject it into the tub). Sometimes part of
the stem body becomes lodged in the manifold but can be removed with an internal pipe
wrench set (home depot carries them for about 12 dollars).
Feb 27, 2011 | Plumbing
I have an american standard shower knobs for cold and hot with a center control that directs to shower. Tub faucet leaks. How do I fix this?
Pull the knob off...usually the screw is behind a cover in the center of the knob...
Behind the knob you will find a nut that is the packing nut ... this is what keeps the water from running out around the stem...turn that nut clockwise a quarter to a half turn or until snug...
this iwll fix your leak...
Aug 14, 2010 | Plumbing
New Pegasus shower valve that does not get hot water
single water handles are often put back in 180 degrees off, remove the shaft and turn it over
Aug 02, 2010 | Union Pegasus F1228100PBV Series 5000...
Temperature too hot on bristan art deco mixer shower even on lowest temperature setting.
if the water is that hot then lower [adjust] the temp of your hot water heater -if need to adjust the shower you can adjust the mixing by removing the handle and on the valve stem are the adjusting clips the red [hot] and blue [cold]plastic clips can move them around to adjust the mixing of hot and cold water
Jul 23, 2010 | Home
Have no Cold water coming out of shower/tub. Replaced the Moen cartridge and still, no cold water. When knob is turned right I get hot water when turned left I get a trickle of hot water.?????
Take the plastic knob off.Turn the brass stem with a pair of pliers until you get it in the proper position.
Off faces down
Cold faces left
Hot faces right
Once in the position screw pastic knob back on.
Mar 16, 2010 | Moen & One Handle Tub & Shower Faucet
Replace inside stem on hot water Eljer shower faucet
Sounds like you might need a gear puller -- hardware stores would have them -- or auto parts.
Spray with contact cleaner wd-40 first, then install puller, depress ring and crank away at the puller.
Apr 21, 2009 | Home
Plumbing Logo
108 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
